    RepRapFirmware 3.01-RC1 released
    Beta Firmware
    17
    81
    4.6k
      You can find it at https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC1 and the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
      1 Reply Last reply Reply Quote 4
      • chas2706undefined
        chas2706
        @dc42 Does this apply to Duet3 + SBC because when I do apt-get update, apt-get upgrade it does not upgrade to 3.01-RC1.
        • gtj0undefined
          gtj0
          @dc42 I think the change to set the axes unhomed on ATX power off got reverted.
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.01-RC1 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-02-08b1
          M408 S2
             "coords" : {
                "axesHomed" : [
                   1,
                   1,
                   1
                "extr" : [
                   0
                "machine" : [
                   0,
                   0,
                   4.9
                "wpl" : 1,
                "xyz" : [
                   0,
                   0,
                   4.9
             "currentTool" : -1,
             "params" : {
                "atxPower" : 0,
                "babystep" : 0,
                "extrFactors" : [
                   100
             <snip>
            dc42 administrators @gtj0
            @gtj0 said in RepRapFirmware 3.01-RC1 released:
            M115
            I've just tested it, and it's working for me. To be clear, it's the loss of VIN voltage (to below about 9.5V) that sets the axes to not homed.
            • chas2706undefined
              chas2706
              This is what I get from M115:
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
                For Duet 3 with SBC, for now you will have to update RRF manually by uploading the firmware binary on the System page of DWC. Make sure you are running the correct version of DSF, 1.2.4.0 or a more recent update.
                • appjawsundefined
                  appjaws
                  I have loaded firmware 3.01-RC1 and have encountered the following error.
                  Error: in file macro, line 31 column 39: expected numeric operand.
                  This macro worked with firmware 3.01-Beta3.
                  I changed the Object model variables move.initialDeviation and move.calibrationDeviation to move.calibration.initial and move.calibration.final.
                  It appears that move.calibration.initial and move.calibration.final is not working.
                  The column 39 is at the end of the line.
                  this is the macro
                  ; Conditional auto bed levelling using 3 Z motors
                  M561 ; clear any existing bed transforms
                  ;check heaters
                  M291 P"Preheating bed and nozzle for accurate probing"
                  if heat.heaters[0].current <=65 && heat.heaters[1].current <=195
                  if heat.heaters[0].current <60
                  M140 S60 ; Set bed temperature to 60
                  M116 ; waiting for bed to reach temperature
                  M140 S65
                  if heat.heaters[1].current <195
                  M104 S195 ; Set current tool temperature to 195C
                  M116 S3 ; waiting for heaters to reach temperature
                  ; If the printer hasn't been homed, home it
                  if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                  G28
                  ;Run an initial 3-point Probe
                  M291 P"auto bed levelling using 3 Z motors started"
                  M98 P"0:/macros/Conditional/bedlevel.g"
                  while true
                  if iterations = 6
                  M291 P"auto bed levelling FAILED"
                  M140 S0 ; Set bed temperature to 0C
                  M104 S0 ; Set current tool temperature to 0C
                  G1 X50 Y230 F24000 ; move the head to park
                  abort "Too many auto calibration attempts"
                  else
                  echo "Test = ", iterations+1
                  if move.calibration.initial < 0.01The
                  if move.calibration.final.deviation < move.calibration.initial + 0.005
                  if move.calibration.final.deviation > move.calibration.initial - 0.005
                  break
                  echo "Repeating calibration because initial deviation (" ^ move.calibration.initial ^ "mm) must be < 0.01"
                  echo "and (" ^ move.calibration.final.deviation ^ "mm) must be within 0.005 of initialDeviation"
                  M291 P{"Test No " ^iterations+1 ^" Initial Deviation " ^move.calibration.initial ^" Deviation " ^move.calibration.final.deviation}
                  echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm"
                  echo "Auto calibration successful, initialDeviation", move.calibration.initial ^ "mm"
                  M291 P{"Auto Calibration Success, Initial Deviation " ^move.calibration.initial ^" Deviation " ^move.calibration.final.deviation}
                  G28 Z
                  G1 X50 Y228 F24000 ; move the head to park
                  M291 P"Auto bed levelling using 3 Z motors completed, head moved to park position"
                  appjaws - Core XYUV Duet Ethernet Duex5
                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                  Ormerod 1-converted to laser engraver, Duet wifi
                  OpenSCAD version 2024.03.18
                  Simplify3D 5.1.2
                  • chas2706undefined
                    chas2706
                    @dc42 said in RepRapFirmware 3.01-RC1 released:
                    Ok will do Thanks.
                      dc42 administrators @appjaws
                      @appjaws said in RepRapFirmware 3.01-RC1 released:
                      This is line 31:
                      If that's really in your file, them I am not surprised that it doesn't work.
                      • appjawsundefined
                        appjaws
                        No sorry that "the" is not in the file, so that is not the problem
                        Simplify3D 5.1.2
                        • appjawsundefined
                          appjaws
                          It looks as if these objects are returning null
                          Simplify3D 5.1.2
                          • DaBitundefined
                            DaBit
                            Great, continue works now. Now I can implement 'M116 with wipes over silicone during waiting' without too much fiddling.
                            Question: we do have state.currentTool. Is there also a previousTool somewhere or a workaround for obtaining the previous toolnumber?
                            Current (yet untested) tpost0.g:
                            ; Make sure we are at the purge position
                            M98 P"purgeposition.g"
                            ; Start toolchange cooling helper fan
                            M106 P2 S255
                            ; Wait until the current tool has heated up and the previous tool has cooled down. Wipe every 5 seconds
                            while iterations < 20
                            	G4 S5
                            	M98 P"wipe.g"
                            	if heat.sensors[tools[state.currentTool].heaters[0]].lastReading < {tools[state.currentTool].active[0]-2.0}
                            		continue
                            	if heat.sensors[tools[1].heaters[0]].lastReading > {heat.coldExtrudeTemperature < tools[1].standby[0] ? tools[1].standby[0] : heat.coldExtrudeTemperature}
                            		continue
                            	break
                            ; Stop toolchange cooling helper fan
                            M106 P2 S0
                            ; Undo retraction and prime extruder (200mm/min is 8.02mm^3/s)
                            M83
                            G1 E3 F1500
                            G1 E5 F200
                            ; Retract, wipe once more
                            G1 E-1 F1500
                            M98 P"wipe.g"
                            ; Return to pre-toolchange location, and unretract
                            G1 R2 X0 Y0 Z0.5 F12000
                            G1 R2 X0 Y0 Z0 E1 F1500
                            In the 'has the previous tool cooled down enough yet?' logic (second if() in the while() loop) I have fixed tool numbers now. I would like to split the code in a macro that can be used for any tool.
                            I could put the waiting for cooling down in tfree and waiting for warming up in tpost, but I would prefer to do both in tpost for the new tool.
                              @appjaws, I just ran the following on my delta (before I ran auto calibration) running 3.01RC1:
                              09/02/2020, 12:49:41 	echo move.calibration.final.deviation
                              0.000
                              09/02/2020, 12:49:17 	echo move.calibration.initial.deviation
                              0.000
                              So they are working for me. What do those commands return on your Duet?
                              Are you certain you are running 3.01-RC1? What does M115 return? I get this:
                              09/02/2020, 14:45:29 	m115
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC1 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2020-02-08b3
                                dc42 administrators @DaBit
                                @DaBit said in RepRapFirmware 3.01-RC1 released:
                                Not yet, but I can add it in a future release. My thinking is that it would only be applicable if you switched directly from another tool to the current one. If you did T-1 followed by T1, then previousTool would be -1. Do you agree that it should work like this?
                                • Danalundefined
                                  Danal @dc42
                                  Yes.
                                  • appjawsundefined
                                    appjaws
                                    From the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
                                    Object model variables move.initialDeviation and move.calibrationDeviation are renamed to move.calibration.initial and move.calibration.final. If you use these variables in bed.g or in other macro files then you will need to update those files.
                                    I cut and pasted the new code, not realizing that I needed to put".deviation" at the end.
                                    So my fault, my macro now works.
                                    Thanks for your help.
                                    Simplify3D 5.1.2
                                      I'm glad you got it working! Each of those values has both .mean and .deviation components, although the mean of the final value should always be zero if calibration was successful. the same was true in 3.01beta3, but possibly not in the very early 3.01 betas.
                                        dc42 administrators @Danal
                                        @Danal said in RepRapFirmware 3.01-RC1 released:
                                        Yes.
                                        I have implemented state.previousTool in the internal RRF3 builds at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                                        • gtj0undefined
                                          gtj0 @dc42
                                          M115
                                          I just retried it with your binary. I do get the "12V under-voltage event (9.5V)" message but the axes still show homed. Also looked using M409 K"move.axes"with the same result.
                                            I've just tried it on a second machine (E3D Tool Changer). It's working correctly on that machine too. With both USB and VIN power applied, I home the printer. Then I turn off VIN power. All axes go to "not homed".
                                            The code that does this is at Platform.cpp(1015):
                                            #if HAS_VOLTAGE_MONITOR
                                            		if (currentVin < driverPowerOffAdcReading)
                                            			driversPowered = false;
                                            			++numVinUnderVoltageEvents;
                                            			lastVinUnderVoltageValue = currentVin;					// save this because the voltage may have changed by the time we report it
                                            			reprap.GetGCodes().SetAllAxesNotHomed();
