    Rippels and Ghosting on Y-Axis of converted Ender 3
    My Duet controlled machine
    8
    74
    14.3k
    • devleonundefined
      devleon @4lathe
      @4lathe said in Rippels and Ghosting on Y-Axis of converted Ender 3:
      @devleon after all this, I would love to find out what the ender was like that produced this cube you posted above. That is a great print imo. Was it pure stock? If do we know its not the wheels or the bearings or sag, etc. My ender 3 has only been modded with direct drive and the duet maestro. It definitely printed at least simple things better before the mod. https://cdn.thingiverse.com/assets/c9/8d/6f/3e/d5/featured_preview_speedDrive_cube.jpg
      This is where I got the picture from, a direct drive mod: https://www.thingiverse.com/thing:3816051
      They definitely done plenty of upgrades to his printer already, as it's outlined in the description.
      I wonder what you mean with when you say your ender 3 printed better before you did the mod. Are you saying it's printing worse with the Duet?
      @DocTrucker said in Rippels and Ghosting on Y-Axis of converted Ender 3:
      What country are you based?
      I'm from Germany.
      • DocTruckerundefined
        DocTrucker @devleon
        @devleon here is the premium supplier of v-slot wheels:
        https://openbuildspartstore.com/xtreme-wheels/
        Ooznest probably ship to Germany without much issue - but you can probably find that in germany too:
        https://ooznest.co.uk/?product_cat=&s=Xtreme&post_type=product
        Here's the Tom3D video about installing linear rails to the bed of a mk3 prusa:
        https://youtu.be/J_RcgixLbAI
        • 4latheundefined
          4lathe
          @DocTrucker that pic was the one devleon posted above. Not from my machine. @devleon yes other than retraction issues on complex parts which were improved by the direct drive, the surface quality is worse. I use duet wifi’s on my railcore zl and some deltas with no issue for years. However myfirst maestro
          • 4latheundefined
            4lathe
            Sorry. The first maestro and direct drive together have created a poorer surface finish than previously. Anyway I don't want to interrupt your thread but I still see small micro interruptions on your surface finish. They may be less than .5mm but still look like small vibrations or fluctuations in extrusion. I have something similar and was just hoping to get a finish like that cube you posted. Watching your results.
            devleonundefined 1 Reply Last reply Reply Quote 0
            • devleonundefined
              devleon @4lathe
              Hmm. Wierd. Maybe it's related to different speed/accel/jerk settings and how Duet probably handles things like acceleration differently in comparison to marlin?
              Regarding the very small surface artifacts, that's my cheapo 5015 blower fan vibrating. Without the fan running, it's gone, but of course I can't print PLA without any cooling. I have a replacement in the mail.
              • 4latheundefined
                4lathe
                Just went and read the thingiverse page you referenced. Did you look atthe before and after photis in the tl smoother section? His theory was bowden tubes absorbed some of the extruder fluctuations that got highlighted with direct drive. Tl smoothers fixed it for him. Not that we need tl smoothers with the duet boards (well the maestro drivers are different from the duet wifi) but maybe theres something there?
                  DocTrucker @4lathe
                  @4lathe yes sorry I was trying to say I don't doubt that you have had good results, and secondly that the shared photo wasn't ideally lit to show z-wobble defects. I wasn't saying ir was your part.
                  • devleonundefined
                    devleon @DocTrucker
                    @DocTrucker
                    I'll try to print a part in a similar color and hold it just like it was held in the photo. Then we'll see if it hides the Z-wobble or not 😉
                      DocTrucker @devleon
                      @devleon I've found it very difficult to photograph these patterns myself. Not got great lighting yet but I have had to get macro extensuons and cheap tripod!
                      • devleonundefined
                        devleon @DocTrucker
                        Well, I do have a macro lens and a tripod, and can probably mcgyver some lighting, let's see what I'll come up with
                        • devleonundefined
                          devleon
                          Also, that print doesn't seem like it's printed with a 0.2mm layer height, the lines seem quite thick. Maybe 0.32?
                          • Corexyundefined
                            Corexy
                            Do we have a Z isolator designed specifically for Ender 3?
                            All the designs on Thingiverse seem to aimed at the Prusa or other models...has anyone actually made one for the E3?
