Fan Sensor & PWM max extr. or bed
    Ludis
    • The fan speed (sensor) displayed is always @0. it's known ? or a config has to do?
    • Where is the setting for the PWM max for extruder and Bed ?
    Thanks
    Ludis
      StephenRC
      For the fan see https://www.duet3d.com/forum/thread.php?pid=6412#p6412
        The max heater PWM setting is in the M307 command.
          Ludis
          Many thanks for answers 😉 , good job.
          Ludis
            Ludis
            What are modification setting when i switch my power supply 12V to 24V.
            All my material is 12V (Heater, Bed, Fans..).
            • What Gcode for Max PWM fan ?
            • When modify M307 to "M307 H1 S0.5" , my heater has not good behaviour (high overshoot)
            Can you solve my problem ?
            Ludis
              To switch to 24V you should get a new bed heater, new hot end heater cartridge, and new fans. I don't advise running a 12V heater on 24V at low PWM because of the fire risk if anything goes wrong. It's possible to add a 24V to 12V converter so that you can go on using 12V cartridge heaters and fans, but cartridge heaters and fans are so cheap that I don't think it's worth the hassle.
