3.5" Displays
Are there any plans to support 3.5" displays at any point in the future?
There is a desire to change to Duet Maestro and Duet2 WiFi boards on some of my projects, but the printers have no way to fit a screen other than 3.5" due to factory default enclosure design and I'd like to avoid destroying the enclosure at all cost.
I know there isn't any support at the moment, but from surfing the web there seem to be panels around using the same connector as the PanelDue at 3.5" with a different resolution.
If someone could point me in the right direction I'd happily try to assist development / take a shot at implementing it myself. I just have no clue where to start..
https://github.com/dc42/PanelDueFirmware
and
https://github.com/dc42/PanelDue/tree/master/PCB/V3.0(might be easier to go with Duet3 and a SBC like Raspberry Pi w/ screen than adapting PanelDue)
In fact I first started writing PanelDue to use a 3.5" display. However I soon realised that the 4.3" display was able to display a lot more data, because of its higher pixel count.
I think the driver code for 3.5" parallel interface displays is still present in the PanelDue code. However, to use a 3.5" display you would need to adjust the screen layout. The 4.3" displays have 480x272 pixels.
@dc42 I just picked up this (displaytech-us.com/7-inch-integrated-tft-driver-boards) 7 inch SSD1963 resistive touch 40 pin display/display-controler and I am struggling to get it to hook up to my Duet2Wifi, any advice on going from panelDue connection on duet to 40 pin?
@StoneZone said in 3.5" Displays:
It looks similar to the 7" one we used to sell with the PanelDue controller board, except the pinout is different and it appears that it doesn't have a backlight inverter on-board. You would need to:
- Purchase a PaneDue controller board (without display) to drive it, available from Duet3D and some of our distributors;
- Match up the pins on the 40-pin connector on the PanelDue controller with the 40 pins on that display, and make up a custom cable to connect the two;
- Work out how to drive the backlight. Looks like it needs 20mA @ approx. 9.6V. So you could drive it from 12V through a series resistor. Or use a constant-current boost converter to drive it from the 5V supply (which is how most displays do it).
Edit:
A few thoughts later: I could however just mount a 3.5" HDMI screen and drive it off a Raspberry/cheap Android Device and adjust the DWC for that resolution.. I'm a webdev after all..
Edit2:
Actually the DWC looks like it meets exactly my competence.. Vue.js + Vuetify.
