Warning High temperature on drivers... - WORKBEE Duet 2 WiFi
566
    stweet
    Have a workbee 750x750 with duet 2 wifi and default workbee fw & settings.
    After machine is on for 5-10 minutes i get a "DWC warning: High temperature on drivers..." and it feels like the step motors start to get fairly hot..
    why do they get to hot so fast ?
    undefined 1 Reply Last reply 17 Feb 2020, 12:45 Reply Quote 0
      Veti @stweet
      what current are you running them at?
        aidar
        Workbee default setting is 2400mA. Maybe its too much for your motors?
        undefined 1 Reply Last reply 17 Feb 2020, 13:13 Reply Quote 0
          stweet
          @Veti @aidar
          M906 X2400 Y2400 Z2400 I100 ;
          motors: 2303HS280AW ( should be able to run 2.8a)
          ? 1 Reply Last reply 17 Feb 2020, 13:10 Reply Quote 0
            aidar
            Duet Wifi-s drivers itself are rated to maximum 2.4A, so to get max out of it you should use very good cooling for drivers i guess.
              A Former User @stweet
              @stweet said in Warning High temperature on drivers... - WORKBEE Duet 2 WiFi:
              and theyre rated for at temperature increase of 80C and up to 50C ambient i.e. they'll get hot, real hot. its normal.
              do you need to run such a high current?
                Veti @aidar
                @aidar
                if you run the stepper drivers at 2400ma you will need to actively cool them.
                a can that blows across the underside of the board should do it.
                  stweet
                  @Veti @bearer year it sounds like i need better cooling on the pcb
                    A Former User
                    cooling the board won't affect the motor temperature just if that was unclear.
                      stweet
                      @bearer yea i know but i set it to 1.8A motors are ok cool, but i felt drivers with my finger and they are pretty hot
                        https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board
                        10 out of 11
