Duet Wifi board. Can i use a USB Print Server to get to DWC?
Duet Web Control
9
53
2.2k
    jallen810
    I am trying to use a Formbot Troodon printer with a Duet 2 Wifi card and the Web interface. Unfortunately, my company will not allow us to use Wifi but they provided me with a print server to connect via Ethernet to our local network that connects via USB. Can I use this print server to access my printer's Web Interface?
    Any ideas would be much appreciated
    Thanks,
    Jake
    ? 1 Reply Last reply 17 Feb 2020, 21:01 Reply Quote 0
      A Former User @jallen810
      @jallen810 said in Duet Wifi board. Can i use a USB Print Server to get to DWC?:
      Not easily at least. If the print server is a plain print server and not a usb server i think it a no-go. If its a usb server you might be able to shoe-horn dwc to run locally and talk to the board over serial/usb via the network.
      is this just to not connect the printer to the office wifi, or also using the printer as an access point? (which you in turn could could NAT onto the wired office network using a OpenWrt or equally flexible wifi device.
      undefined 1 Reply Last reply 18 Feb 2020, 12:51 Reply Quote 0
        Perhaps setting the printer to access point mode would work? You'd have to connect to the printer network to be able to interact with it.
          tobias_munich
          Hi @jallen810,
          connecting something to the USB port wouldn't give you access to the DWC.
          the printserver of your company is neither of use as a "virtual lan adapter" nor as a printserver itself.
          the easiest way is attaching a panel-due to your duet.
          or, maybe you can convert your DuetWifi to a LAN version.
          its described in the following post
          https://forum.duet3d.com/topic/2890/converting-a-duet-wifi-to-a-duet-ethernet/2
          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
            jallen810 @A Former User
            @bearer Our IT is funny about using WiFi on unknown equipment. Above my pay grade.
            Essentially, i just want to be able to access it on our network (LAN) from my laptop <10ft away.
            ? undefined 2 Replies Last reply 18 Feb 2020, 14:08 Reply Quote 0
              DaBit
              Phaedrux mentioned a good method: put the Duet in access point mode, and use the laptop to connect to that access point. This way you are not using the company network at all.
                USB cable is probably your best bet if not able to replace the wifi module with an ethernet one.
                undefined 1 Reply Last reply 18 Feb 2020, 15:52 Reply Quote 0
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                  This would be the quickest way to get you up and running.
                  undefined 1 Reply Last reply 18 Feb 2020, 15:53 Reply Quote 0
                    @bearer Can you control the DWC that way? Or would i just have the Simplify3D/Cura/etc. control screen?
                    ? 1 Reply Last reply 18 Feb 2020, 16:00 Reply Quote 0
                      jallen810 @Phaedrux
                      @Phaedrux But don't you have to have the WiFi SSID and P/W to do a M589? I have a fixed IP address from the Print Server that is ready to go, basically I just need the Duet to output an IP address to get to the DWC
                      undefined 1 Reply Last reply 18 Feb 2020, 15:54 Reply Quote 0
                        You can send that command (and any other commands you need to get connected) via USB.
                          Phaedrux Moderator @jallen810
                          @jallen810 no this is to create your own access point on the printer that you connect to so you get to name it.
                          undefined 1 Reply Last reply 18 Feb 2020, 15:55 Reply Quote 0
                            jallen810 @Phaedrux
                            @Phaedrux I don't follow that, sorry not in IT so my networking skills are lacking a bit. Can you elaborate? What would I need to tell my IT guy to understand what we need to do?
                              With access point mode, you don't need to connect the printer to anything else on your network. Instead the duet creates its own low power wifi network that you connect to with your laptop to monitor it and send files. See if that's acceptable to your IT department.
                              undefined 1 Reply Last reply 18 Feb 2020, 16:00 Reply Quote 0
                                jallen810 @Phaedrux
                                @Phaedrux said in Duet Wifi board. Can i use a USB Print Server to get to DWC?:
                                That would be awesome, can you point me to the instructions in the guide to do this? Or is it as simple and giving the Duet the M589 followed a made-up SSID and P/W for me to find with my Laptop?
                                  If you're not as you say "in IT" then I don't think trying to get DWC to work outside of the standard means is a good path.
                                  As far as running the Duet as an Access Point you determine what SSID and password used to create a new network. If your computer has a wireless network adapter you can connect the computer to the Duet instead of the other way around. But still check with IT, they might have issues with "rouge" Access Points for various reasons.
                                  undefined 1 Reply Last reply 18 Feb 2020, 16:03 Reply Quote 0
                                    @bearer said in Duet Wifi board. Can i use a USB Print Server to get to DWC?:
                                    Okay i think that is what @Phaedrux is also saying, is there a guide on the Duet Dozuki that i can follow that you can point me to?
                                    ? 1 Reply Last reply 18 Feb 2020, 16:09 Reply Quote 0
                                      M589 is all you need. That link is all there is for how to do it. You just need to send that command over a usb console connection.
                                        indeed, just make up a SSID and password to substitute in
                                        M589 S"SSID" P"password"
                                        Password might need to be 8 characters if it doesn't work
                                        undefined 1 Reply Last reply 18 Feb 2020, 16:11 Reply Quote 0
                                          Bear in mind that anyone with the password will be able to control the printer from a smartphone. So choose something difficult to guess! WPA requires 8 characters minimum.
                                          undefined ? 2 Replies Last reply 18 Feb 2020, 16:13 Reply Quote 0
                                          3 out of 53
