Auto Bed levelling Errors - printer continues print
Hey everyone!
I have now 4 printers running with duet, sensorless homing and auto bed compensation.
But everytime he gets an error while probing (Z probe not triggered, Z probe already triggered, measurements not consistent, ...) he continues printing instead of stopping. Is there any way to configure this? So that he lifts Z and stops for example?
Thats my config.g:
; Configuration file for Duet WiFi (firmware version 2.xx)
; generated by RepRapFirmware Configuration Tool v2.0.4 on Wed Oct 02 2019 13:56:34 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"Soldex SX" ; set printer name
M667 S1; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 R-1 ; physical drive 0 deaktiviert
M569 P4 S0 ; physical drive 4 goes forwards
M584 X4 Y1 Z2 E3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z1000.00 E7200.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z500.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S1 ; Set idle timeout;Timing
M208 X380 Y520 Z445 S0 ; set axis maxima; Endstops
M574 X1 Y1 S3 ; set endstops controlled by motor stall detection; Z-Probe
M307 H7 A-1 C-1 D-1 ; disable heater 7 on PWM channel for BLTouch
M558 P5 H3.5 F400 T7000 S0.03 A6 X0 Y0 Z1 I1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
G31 P25 X36.4 Y16 Z1.42 ; Z probe trigger value, offset in relation to nozzle.
; And trigger height adjustment; Geringer = weiter weg vom Bett
M557 X36.4:309 Y87:387 S54.52 ; define mesh grid; Heaters
M106 P0 S1 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M501And my homing script:
; HOME X
; Custom settings
M574 X2 Y1 Z0 S3
M915 P0 S8 R0 ; Higher values reduce the sensitivityG91
G92 X0
G1 X5 ; use relative positioning
G1 S1 X-500 F5000 ; move all carriages up 500mm, stopping at the endstop
G92 X0 ; X reset
G90 ; back to absolute positioning
G91
G92 X0
G92 X0 ; X reset
G90 ; back to absolute positioning; HOME Y
M574 X2 Y1 Z0 S3 ; Higher values reduce the sensitivity
M915 P1 S2 R0M913 X30
G91
G92 Y0
G1 Y20 ; use relative positioning
G1 S1 Y-500 F3500 ; move all carriages up 500mm, stopping at the endstop
G92 Y0 ; X reset
M913 X100M913 X30
G91
G92 Y0
G92 Y0 ; X reset
M913 X100; HOME Z
M280 P7 S160 I1 ;
G92 Z200
G91
G1 Z10
G90
M280 P7 S10 I1 ;
M203 Z500
G91 ; relative positioning
G1 Z5 F1000 S2 ; lift Z relative to current position
G90 ; absolute positioning
G1 X30 Y30 F12000 ; go to first probe point
M203 Z1800The homing script is a little workaround, because sometimes he recognizes the "endstop" while homing too early. Playing around with sensitivity and speed did not ended up in good results.
Have a nice week.
William
@WillGIam said in Auto Bed levelling Errors - printer continues print:
Yes, use RepRapFirmware 3.01 and use conditional GCode to terminate the print if there was a probing error.
If you're using a BLTouch you can clean up this command a bit for potentially better results.
M558 P9 H3.5 F100 T7000 R0.5 A6 S0.03
@Phaedrux said in Auto Bed levelling Errors - printer continues print:
Thanks for your answer. I´m not using a BLTouch.
I´ll try a newer firmware.
Thanks!
@dc42 said in Auto Bed levelling Errors - printer continues print:
conditional GCode
Hey DC42!
Thanks for your answer. So if I see this right, I have to add an if loop after G29 where I have to ask for error messages? Is there a boolean or something like this? I cannot find the right page in the documentation I think...
Best regards
I can´t find a list with the "native" variables of the firmware. I could use the abort function after my G29 in an if loop for checking for error messages, but I don´t know how they named. I found some scripts online, but I don´t know where they got the information about the other variables....
