    duet connection
    Duet Web Control
    740
    • tdybare69undefined
      tdybare69
      after enabling the wifi module, and entering the router setting when i go to the ip address it gives me i get a reject message
      Your Duet rejected the HTTP request: page not found
      Check that the SD card is mounted and has the correct files in its /www folder
      please help.
      could it be that i have a second printer running at the same time.
        A Former User
        it would suggest the Duet Web Control files are not present on the SD card.
        grab the file ending with -SD.zip and extract it so you have a file /www/index.html.gz on the sd card.
        edit: ups, forgot the link 🤦 https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.7
          tdybare69
          i replaced it with a working sdcard from other printer still no go. seems like board is not mounting sd card. is there a code i can use in yat to tell it to mount the card?
            A Former User
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M21_Initialize_SD_card
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M39_Report_SD_card_information
            and a few others to help with troubleshooting in the same regin of the wiki
            tdybare69undefined 1 Reply Last reply Reply Quote 0
              tdybare69 @A Former User
              @bearer i went to github got the files you said,extracted it,and tried again. still says same thing. did M21 it says SDHC card mounted in slot 0, capacity 31.9GB<LF>ok<LF>
              M39 says SDcard in slot 0: capacity 31.9GB, speed20.00MBytes/sec,cluster size 167kb<LF>ok<LF>
                A Former User
                Try M20 to confirm the Duet sees the files in the correct location , or check that the card doesn't have multiple partitions (although the card showing as 32g would suggest it may not be partitioned) (if the card works in a different printer it would more so suggest issues with the duet and sd card socket. maybe see if you can get a good macro picture of the solder joints on the sd card socket)
                  @bearer i think thts it . be right back gonna make sure there is no partitions. it says files none.
                    tdybare69 @tdybare69
                    @tdybare69 i think your right. something has to be wrong with board.everything i try it still says none.
                      @tdybare69 its new board. but i have had it for a while in box, stored safely. got it from matter hackers.
                        A Former User
                        Hmm, still odd it mounts the card gets the capacity correct (assuming the capacity is shown correctly?) Confirm the capacity and see what you can do about a picture.
                        In any case I'm sure your friendly neighborhood administrator @dc42 will be along shortly with some insight.
                          dc42 administrators @tdybare69
                          @tdybare69 said in duet connection:
                          Are you sure it says cluster size 167kb? That's not right.
                            A Former User
                            But if the card works in another Duet the cluster size has to be OK, as well as the files present on the card?
                            Except its not, with two different cards.
                              droftarts administrators @tdybare69
                              @tdybare69 can you take a close up picture of the pins on the end of the SD card socket? I suspect poor soldering.
                                tdybare69 @droftarts
                                @droftarts finally got it to work. took sd card from working duet printer. ran a M21&M39, went to working.
                                  A Former User
                                  Isn't that exactly the same you said didn't work yesterday?
                                    @bearer yes. maybe the board had to warm up. got me stumped. i have come across weirder things than that unfortunately.
