(Forum Issue) Links on Dark Colour Scheme
Morning,
The default colour for links on user bio pages and last posts should be revisited for the dark colir scheme. They are difficult to read.
Thanks!
Which skin is that? Try "superhero". It's a decent dark mode skin, but still has contrast.
Cyborg, Darkly and Slate all have that same issue. Superhero is a little better.
@Phaedrux "Darkly". I thought there were only two choices when I picked, not looked since so will give the others a go. Thanks.
I think the colour needs to be changed though (and on others by the sound of it) as it is little good as it is.
Just FYI... I found an extension called DarkReader that does really well with tough sites..
https://chrome.google.com/webstore/detail/dark-reader/eimadpbcbfnmbkopoojfekhnkhdbieeh?utm_source=chrome-ntp-iconWith the forum theme set to "default" and DarkReader:
Oddly enough, I also just discovered that you can copy a screenshot to the clipboard and simply paste it into the forum edit box without saving it to a file first.
