    423
    98.4k
    • kraegarundefined
      kraegar
      I take that back, when the LED is lit, the signal stops. if I trigger it rapidly enough, the z-probe value falls to 0.
      Switching the I1 to I0 to invert it did the trick. Should be ready to rock now.
      • DjDemonDundefined
        DjDemonD
        Go easy at first lower your motor currents during probing, to the minimum needed to move the axes, mine are at 500. Then any head crashes are fairly low impact. A little finesse on the signal conditioning board is required.
        The digital config above M558 P5 …. is the one to try first. Lower the debounce value if you get false triggers.
        Any issues with that, switch to the analogue one and use the analogue value as a guide for fault finding, use low jerk/accel values with this mode.
        www.precisionpiezo.co.uk
        • Moriquendiundefined
          Moriquendi
          I think screened cable probably has more capacitance per meter than unscreened, we're not talking about electromagnetic interference but rather the capacitance of the cable absorbing the signal.
          My current piezos come from rapid but I don't really trust them as a long term source of parts. If I design and calibrate for one particular piezo disk I want to be sure I can get hold of them in a few months or years. I've seen rapid pull parts or replace them with something equivalent but not identical. Rapid is also the only supplier of Kepo piezos I can find, murata elements are much more widespread.
          Option 2 is the most versatile but my current designs for option 2 are about 50mm/2" long which may make mounting difficult, width is about 14mm or just over 1/2".
          On a delta, option 3 would allow you to pit the endstop board in the top of the printer and route the signals down to the controller using the existing wiring, all you'd need to do is run wires to power the board.
          Idris
            The Farnell own-brand (Multicomp) piezos might be made by Kepo too, because I know that their own-brand piezo sounders that I use in PanelDue are made by Kepo.
            • kraegarundefined
              kraegar
              Ok, so I'm calibrating succesfully with the piezo now. Some tuning to do, but it's definitely functional and working. Thanks for the help, and guide, and thanks Moriquendi for the board!
              I'll post some pictures of my setup, but essentially it's just my hotend mount I already had + $1 in nylon washers from the hardware store.
              • Dougal1957undefined
                Dougal1957
                @Moriquendi:
                Idris
                Idris
                On the New delta I intend to put the Controller and motor's at the top of the towers anyway (This will be a slightly taller than normal Delta) And my idea was to use single core screened cable but route it so one leg went down one side and the other down the opposite side to the triangle (This would of course only work if it was at the top).
                Could the Control board be placed in the upper part of the Delta (For a traditional type build) and then the signals from the board to the Duet etc be routed down in one bunch as then twisted screened cable should be ok for that?
                  Moriquendi
                  It's only the signals from the piezo elements to the endstop board that are delicate, the signals from the endstop board to the controller are as robust, if not more so, than a normal microswitch signal, I don't think you need to take any special precautions with them. To answer your question, yes, for a traditional delta the best arrangement would probably be to have the endstop board in the top of the machine near the endstop piezos.
                  Idris
                  • kraegarundefined
                    kraegar
                    Ok, so I'm probing. So far the only real issue I've hit is I can't probe if the hotend is heating or even hot. No biggie, I calibrated the Z offset for the probe, and I'm good to go.
                    To mount it, as I noted earlier I use the 713maker hotend mount for my v6. This made it extremely simple.
                    First, I put a locking right on the collet for the bowden (I have a stub of a bowden to my Y adapter for filament switching). I had to chop the lock ring down to be really small - no bigger than the collet itself. Around the collet / bowden I put a 3.2mm tall nylon washer (12.7mm OD, 8.2mm ID) I got at the hardware store for 23 cents. It's just taller than the collet when locked, and just barely fits around it. Above that I put the piezo with a hole drilled in it (I also filed down the solder some), with the coated side facing up. On top of the coated side I put a bigger nylon washer. 1.6mm thick, 25.2mm OD, 18.5mm ID - also from the hardware store for 50 cents. I cut a small bit out of it to allow the wires to pass out. Then I simply put the locking ring from my hotend mount on top as usual.
                    Pictures are here if they help - total additional cost for mounting was 73 cents. http://imgur.com/a/tYFXb
                    Edit to say I did hit some early issues beyond those noted above for inverting the probe. Turned out I had a bearing that failed fairly catastrophically and was causing enough vibration I couldn't calibrate the piezo for all the noise. Replacing that and tightening the belts up took care of things from there.
                    • DjDemonDundefined
                      DjDemonD
                      This is great feedback kraegar. Do you think the piezo disc is heating up with the hot end? At around 50-60 deg C they are meant to stop working.
                      Micro-locking ring is a good idea too.
                      (Not Piezo related but… I've got one of those y splitters on order I'll have to pick your brains about how to set it up on RRF)
                      • kraegarundefined
                        kraegar
                        I'll put a temp sensor near the piezo to check the temp. It's odd - it looks like electrical interference, except just turning the heater off doesn't help. It doesn't work reliably again until the temperature drops < 40c.
                        I was considering re-trying the tuning of the piezo with the heater on, to see if I could get it to filter out the noise. Not sure if I want to bother.
                        I'll make a separate post on the Y adapter.
                        • kraegarundefined
                          kraegar
                          I am still occasionally seeing it register the tap at my Y tower a tad late - I can see the effector "tip" a bit. It's only at the Y tower, and I'm not sure what's causing it. I can't adjust the sensitivity without affecting the other probe points negatively, so I suspect it's something about either the bed there, or that tower / belt. Adjusting belt tension didn't help it. This is the tower that had a bad bearing, and I'd hoped that would fix it. It seemed to improve, but is not 100% resolved.
                          • DjDemonDundefined
                            DjDemonD
                            I was getting v poor probing at one point but only on the left side of the bed. I wondered if it was the bowden tube or one of the screws being looser than the others, turned out to be a loose electrical connection.
                            • kraegarundefined
                              kraegar
                              If I probe at 850mm/min (with jerk & acceleration reduced, though) I don't get the tipping at that point. below 500mm/min, it starts doing it at more points, all on that side. I suspect maybe effector tilt isn't giving me as clean of a tap on that side. (I have plans to have an aluminum effector milled custom, but haven't had time to properly design it)
                              • kraegarundefined
                                kraegar
                                Ok, first, don't tap that fast. Results got progressively worse.
                                Second, I found my issue, I think. I like repeatability as proof, so I'll do a lot of rounds of checks and see how consistent it is. When I'd tightened down the piezo probe down with the 3 screws on my hotend, I got one lower then the other two, so my hotend was sitting at just a slight angle. This was causing poor results on one part of the bed. I straightened it up and now (4 rounds done) I'm getting good probe points all around the bed. I'll report back if that turns out not to be the fix.
                                Edit: Just finished a height map. I should try slowing down the probing speed now that things are better. This was at 600mm/min. http://imgur.com/kk1uaGH
                                  T3P3Tony administrators
                                  Could you post your repeatability figures if you captured them?
                                  • kraegarundefined
                                    kraegar
                                    I didn't… And then I tweaked too far trying to improve more, and heard the ceramic crack on the piezo. Sensitivity definitely went down. I'll drill another today and swap it out.
                                    • DjDemonDundefined
                                      DjDemonD
                                      I'm probing at 300 mm/min.
                                      • kraegarundefined
                                        kraegar
                                        Perhaps my "simple mount" isn't good enough?
                                        I drilled a new disc, it's still very sensitive going by the LED. But when I try to dial in R1 there's no room between "triggers on any printer move" and "doesn't trigger on tap".
                                        The top nylon washer I'm using is 3.5mm in diameter, and that's all of the piezo it's touching - is that too far in, and preventing it from bending enough perhaps?
                                        • DjDemonDundefined
                                          DjDemonD
                                          Do you mean it's 3.5mm difference between ID and OD?
                                          • kraegarundefined
                                            kraegar
                                            Yes.
