    Duet Maestro Bed heating uncontrolled
    51
    2.3k
      dc42 administrators @NTX9
      @NTX9 said in Duet Maestro Bed heating uncontrolled:
      Is the chip next to the LED on the board, the Mosfet that has been damaged?
      Yes, the one marked 036N04L. To replace it you will need a hotplate as well as hot air, because of the amount of heatsinking that the PCB provides.
      My Quad is in better shape than your photo, but there is some bare wire very close to the edge of the aluminium. I'm going to put some Kapton tape in the gap and over the edge of the aluminum.
      droftartsundefined NTX9undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @dc42
        @dc42 @NTX9 Those bare wires on the heatbed do look crazily close to the edge. Could you desolder them and resolder the other way around, so they looped back, with insulation over the edge of the bed? Or would you need to heat the bed to 200C first, as it's a massive heatsink?
        NTX9undefined DocTruckerundefined 2 Replies Last reply Reply Quote 0
        • NTX9undefined
          NTX9 @droftarts
          @droftarts
          Ian, That is exactly what I plan to do. I may also add some kind of printed cover if I can find or design something that seems suitable. I am not sure how difficult re soldering will be but the alternative is to replace the bed.
          • NTX9undefined
            NTX9 @dc42
            @dc42 said in Duet Maestro Bed heating uncontrolled:
            Yikes, that sounds like a golden opportunity to totally bogger up the board.
            Maybe I will go with an external mosfet afterall.
            Are there pins on the expansion board that would bypass the onboard mosfet? Or would I need to attach to the gate pin on the onboard mosfet?
            • NTX9undefined
              NTX9
              While this issue is clearly the result of a short at the heated bed, it would seem like the Duet board would have a fuse to protect against this kind of fault.
                Sadly, fuses are usually too slow to protect mosfets. OTOH, in many cases the short-circuit protection of the PSU does provide sufficient protection - but evidently not in this case.
                  A Former User
                  Unfortunately fuses aren't fool proof; if you're looking for a warranty claim I'd look to the printer manufacturer instead.
                  NTX9undefined 1 Reply Last reply Reply Quote 0
                  • NTX9undefined
                    NTX9
                    Even if the fuse doesn't prevent damage to the mosfet, I would hope that it would at least prevent the bed from heating uncontrolled.
                    dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                    • NTX9undefined
                      NTX9 @A Former User
                      @bearer
                      Unfortunately, it appears that M3D has no interest in covering this under warranty.
                        Maybe, if the short circuit lasts long enough to blow the fuse. But bed heaters should always be protected against uncontrolled heating anyway, either passively (by ensuring that the maximum temperature reached is safe), or actively (using a thermal cutout).
                          A Former User @NTX9
                          That would have the side effect of slowing down the bed heating as well; normally the bed is on more or less 100% until it starts getting close to the set point and the power level tapers off to settle on the chosen temperature. The (electrical) fuse can't distinguish between desired and undesired heating.
                          A thermal fuse would be the appropriate safety device to prevent over heating in such a case, which would be part of the bed, not the controller.
                          It doesn't make sense to cripple a controller board because someone makes a printer that literally sh¤# the bed.
                          As far as the manufacturer not seeing it as a warranty claim that would be nothing but bad publicity if the product is still in its warranty period - there is no doubt the fault is poor design or manufacturing; ultimately if the warranty has expired it doesn't matter.
                          • NTX9undefined
                            NTX9 @dc42
                            What is considered a safe maximum temperature for a 3D Pinter bed?
                            It seems to me that is dependent as much on the furnishings of the space around the printer as the machine itself. For example wood paneling that is common in basements or wood furniture can have spontaneous combustion at prolonged temps as low as 110c.
                            • NTX9undefined
                              NTX9 @A Former User
                              @bearer said in Duet Maestro Bed heating uncontrolled:
                              Perhaps, I am not an electrical engineer. I just know that other boards have fuses.
                              Fair enough. From my digging around it appears that at least some of the Creality models have the exact same bed connection. And unfortunately the price point makes these some of the fastest selling printers on the market. The M3D design borrows considerably from the Creality so they possibly sourced the same manufacturer.
                              The printer arrived last May and the M3D warranty only covers a 3 Month period. But even if it was newer I really don't have much faith in their willingness or ability to follow through.
                                I agree.
                                My delta printer uses an AC mains voltage silicone heater on the underside of an aluminium bed, which is connected to the frame via three small metal spacers. The limiting component is the silicone heater, which is rated to 200C continuous. In my tests it tops out at 190C at full power.
                                Many PCB heaters struggle to reach 100C, so they are probably intrinsically safe as long as they are not supported by parts printed from PLA.
                                BTW hot end heaters are frequently over-powered, often sufficiently to melt the aluminium heater block at sustained full power.
                                  A Former User @NTX9
                                  they more likely than not wouldn't have helped any more than the duet fuse didn't; unless the fuse and bed are chosen to actually fail after a certain amount of time of full power which is sort of possible, but fuses aren't precise enough for it to reliable.
                                  we also don't know if M3D changed the default bed fuse to match their chosen bed.
                                  as far as the maxium safe bed temperature, the most relevant part is what is supporting the bed; compare to a toaster - heating filament probably reach in excess of 1000C, but mica or ceramic parts that hold the heaters can deal with the heat and isolate the outer case to avoid the surface temperature to pose a problem to the surrounding material and creatures. but there is no accounting for bad design sadly, best we can do is share the knowledge and prevent others experiencing the same.
                                  Just get an external mosfet; file down the sharp edge and put some high temperature tape over it. if you want to bananas replace the wiring with some silicone or fiberglass insulated wires and make sure the insulation covers the edge.
                                  NTX9undefined 1 Reply Last reply Reply Quote 1
                                  • NTX9undefined
                                    NTX9
                                    Thanks guys! I appreciate the technical and moral support. I have an external mosfet on its way and will hopefully have a functional machine again soon. I will post images of what ever I come up with for the bed connection fix.
                                    I was already planning to do a video comparing the Quad head against the Diamond Hotend and the Quadden (bowden) retrofit that some users using. Now I guess I have more to talk about on the video.
                                    • NTX9undefined
                                      NTX9 @A Former User
                                      I see no evidence any fuse related to the bed.
                                        The Duet WiFi/Ethernet has a bed fuse, the Duet Maestro doesn't.
                                        • DocTruckerundefined
                                          DocTrucker @droftarts
                                          @droftarts said in Duet Maestro Bed heating uncontrolled:
                                          ... Or would you need to heat the bed to 200C first, as it's a massive heatsink?
                                          The best (/only) way I have found so far is the smallest ring on my gas hob on low and a gas soldering iron. Perhaps not brilliant but so far not warped them and soldered on silicone insulated 14AWG wire.
                                          That said if the hotbed has had anything else on it the fumes could be nasty.
                                          • NTX9undefined
                                            NTX9
                                            So bypassing the on board mosfet has proven to be more of a soldering challenge than I anticipated. My feeble skill has basically rendered surface solder pad for the mosfet gate unusable.
                                            Is it possible to edit the firmware to use E1 to control an external mosfet? Or is there a pin on the expansion header that I can connect to that is upstream from the bed mosfet?
