    423
    98.7k
      T3P3Tony administrators
      Could you post your repeatability figures if you captured them?
      • kraegarundefined
        kraegar
        I didn't… And then I tweaked too far trying to improve more, and heard the ceramic crack on the piezo. Sensitivity definitely went down. I'll drill another today and swap it out.
        • DjDemonDundefined
          DjDemonD
          I'm probing at 300 mm/min.
          www.precisionpiezo.co.uk
          • kraegarundefined
            kraegar
            Perhaps my "simple mount" isn't good enough?
            I drilled a new disc, it's still very sensitive going by the LED. But when I try to dial in R1 there's no room between "triggers on any printer move" and "doesn't trigger on tap".
            The top nylon washer I'm using is 3.5mm in diameter, and that's all of the piezo it's touching - is that too far in, and preventing it from bending enough perhaps?
            • DjDemonDundefined
              DjDemonD
              Do you mean it's 3.5mm difference between ID and OD?
              • kraegarundefined
                kraegar
                Yes.
                • Moriquendiundefined
                  Moriquendi
                  I think you may be running into the same problem DjDemonD had in the beginning. Looking at your effector it doesn't like you're controlling lateral movement of the hot end. DjDemonD had to add sliders to allow vertical movement of the hot end while preventing lateral movement causing triggering.
                  Idris
                  • kraegarundefined
                    kraegar
                    The Slot for the hotend does actually by design have the hotend groovemount on an E3D "drop down" a bit into the mount. If anything it might be a little too snug of a fit. That's what I was hoping would make this ideal.
                    How tight do you push down on the piezo? Just do it's held flush against the hotend, or do you flex the piezo some (in a "resting" state)
                    • DjDemonDundefined
                      DjDemonD
                      It can be preloaded a small amount, as long as further upward pressure will bend it more, we're only talking 0.1mm more. Its the rate of bend that generates the signal rather than the absolute amount.
                      • kraegarundefined
                        kraegar
                        Ok, back in business.
                        I think my piezo was grounding the brass plate against my hotend mount. Maybe. I trimmed a spot in it around each screw, to be sure it wouldn't make contact. I also went back to the piezo I got the best luck out of… don't think I actually damaged it. I'm using a P1 probe type with a low trigger value. Seems to be working at the moment, anyway.
                        I think drilling these without damage is going to be the challenging part, at least at first.
                        • kraegarundefined
                          kraegar
                          My repeatability testing is now underway. If you have suggestions on the methodology or ways to display the data, let me know and I'll adjust: https://docs.google.com/spreadsheets/d/1EwNdSNXZR_OhwChLFrTYqFDFcKjB-4z6OwGkocKgW7E/edit#gid=0
                          Currently I'm just moving to Z5 and doing a G30 s-1 50 times. I have the min, max, average, and stddev at the bottom.
                          Edit to note I'm powering off and doing a full delta calibration between each set.
                          • DjDemonDundefined
                            DjDemonD
                            Thats good data. When I had a piezo in a machine running marlin I did the M48 repeatability test a few times and came up with similar results.
                            Recv: Mean: -2.492500 Min: -2.510 Max: -2.475 Range: 0.035
                            Recv: Standard Deviation: 0.009014
                            Not quite as good, but the hastily rigged carriage this machine uses is quite wobbly itself.
                            I've mainly been using my delta autocalibration deviation as the metric, which is, I accept, flawed as there are many other factors feeding into this.
                            • kraegarundefined
                              kraegar
                              My delta calibration leaves a bit to be desired still. Just working on the probe for now.
                              Calibrated 6 factors using 16 points, deviation before 0.055 after 0.054
                              I still have some work to do in solving an oddity I've talked to dc42 off and on about, to get that down. Having more accurate probing (and using the nozzle) should hopefully help that.
                              • DjDemonDundefined
                                DjDemonD
                                Started a listing as a repository of 20mm versions which are currently in alpha testing.
                                http://www.thingiverse.com/thing:2152709
                                Feel free to try/mod one, its a basic module at the moment for integration into where-ever you need it. Not fully tested but the module does trigger the signal conditioning board when tapped so I am assuming it will be basically functional.
                                Very small, no rods/pins you need signal board, and 6x20mm m3 bolts and 6xm3 nuts and a 20mm piezo with 5mm hole drilled into it. I put a drilling template on there too.
                                Please feedback if you make/test one I haven't really a suitable machine to test this properly. I will be putting a version up later today which fits into a titan extruder.
                                  Moriquendi
                                  @T3P3Tony:
                                  If it's of any interest, I just probed my bed 89 times and had the exact same reading every time, to four decimal places, 232 steps and 2.9000mm
                                  Idris
                                    Thanks Iris that's a very encouraging result!
                                      Moriquendi
                                      That's with underbed sensors however.
                                      Idris
                                      • Dougal1957undefined
                                        Dougal1957
                                        Idris could you share your underbed mount designs please I may give that method a try on my existing Delta but I suspect I may need to adjust the sizes etc so raw files as well as the STL's would be appreciated
                                        Also do you use it with your 3 port board or with individual ones?
                                        Doug
                                        • kraegarundefined
                                          kraegar
                                          Idris - is that a cartesian, or a delta? I suspect play in my belts, etc between the 3 towers factors in. Less moving factors on a cartesian if you're just moving Z. However, if those results are on a delta, I'm impressed, and probably have more work to do!
                                            Dougal1957
                                            It is on a delta I have seen the pics
