Recovery after "Emergency Stop"
1.5k
    Yonkiman
    I'm making good use of the "Emergency Stop" button as I sort out motor assignments and polarities on my new CoreXY. To recover, I have to press the reset button on the Duet Wifi, wait a few seconds, and refresh my browser.
    Is that the normal procedure? Wasn't expecting to have to press reset, though it's hardly a big deal.
    Firmware Version: 1.17e (2017-02-10)
    WiFi Server Version: 1.03 (ch fork)
    Web Interface Version: 1.14a
      iDevelo
      I had this issue until I upgraded the firmware to 1.18.
        T3P3Tony administrators
        If you are hitting the emergency stop button on the web interface it sends the commands M112 and then M999 which causes a software reset. Refreshing the browser window (or pressing the connect button, top left) should connect back to the Duet without the hardware reset button needing to be pressed
          Yonkiman
          @iDevelo:
          Where'd you get 1.18? The latest on git (https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Stable) seems to be 1.17.
            Yonkiman
            @T3P3Tony:
            Not for me. No matter how long I wait after an emergency stop, when I refresh the browser the interface says it's connected, but it isn't. Nothing happens when I try to Home an axis, and when I try to edit .g files it says "Connect to your Duet to display System files". Everything's fine after a reset. Running Chrome 56.0.2924.87 (64-bit) on Windows 10.
              Odd that may be a difference between 1.17 and 1.18
                DjDemonD
                Yeah mine doesn't always reset without a hardware reset buts not a big problem.
                Yonkiman - try https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Edge
                For edge firmware.
                www.precisionpiezo.co.uk
                  Yonkiman
                  @DjDemonD:
                  That worked! After an emergency stop I just have to wait 5-10 seconds (no reset, no refresh) and everything is working normally.
                  Thanks!
                    iDevelo
                    @T3P3Tony:
                    Yeah Tony. It just shows as halted in DWC with 1.17 latest for some reason. With 1.18 it works as it should.
                      Thanks for the clarification, I just never noticed that before!
                      7 out of 10
