    Blank Page after update of Duet Web Control
    Duet Web Control
    811
      It sounds like maybe the update didn't proceed properly.
      First check with a different browser to see if it's just a browser issue. If it still doesn't work, I would pop the SD card into a PC, and manually replace the /www folder with the contents of the DWC 2.0.7 zip file.
        A Former User @Phaedrux
        @Phaedrux I did try the different browser still same issue. Pulled SD card and loaded a fresh download of the DWC 2.0.7 to the card into the /www folder and still same issue. Blank screen
          What board and firmware version?
          Can you connect via USB and verify that it's actually loaded up?
          M115 will give the firmware version.
          M503 will try to read the contents of config.g to verify that the SD card has loaded config.g properly at startup.
          M112 will give a diagnostic report.
          A Former User? 4 Replies Last reply Reply Quote 0
            A Former User
            Maybe add M20 S2 P"/www" to the list?
            And if everything looks good, the developer console in f.ex. chrome has a network tab to help identify issues as well.
            (in chrome hit F12 key to bring up the developer console in a new tab then type in the url for the duet)
            A Former User? 2 Replies Last reply Reply Quote 0
              @Phaedrux So it will eventually load after about 15min and everything seems to be ok. Then I wanted to see if it was fixed so reloaded the page and we are back at the blank page
                @Phaedrux
                m115
                FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
                m503
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 06 2020 14:56:26 GMT-0700 (Mountain Standard Time)
                M550 P"Duet3 CNC" ; set printer name
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P0.1 S0 ; physical drive 0.1 goes backwards
                M569 P0.2 S0 ; physical drive 0.2 goes backwards
                M569 P0.3 S0 ; physical drive 0.3 goes backwards
                M584 X0.0:0.3 Y0.1 Z0.2 ; set drive mapping
                M92 X80.00 Y80.00 Z400.00 E80.00 ; set steps per mm
                M203 X14000.00 Y14000.00 Z1800.00 E14000.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
                M906 X2800 Y2800 Z4200 E2800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X2498 Y1245 Z130 S0 ; set axis maxima
                M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
                M558 P0 H5 F120 T12000 ; disable Z probe but set dive height, probe speed and travel speed
                M308 S0 P"temp0" Y"thermistor" T1 B4138 ; configure sensor 0 as thermistor on pin temp0
                M143 H0 S0 ; set temperature limit for heater 0 to 0C
                M307 H0 B0 S0.00 ; disable bang-bang mode for the bed heater and set PWM limit
                ; Custom settings
                M307 H1 A-1 C-1 D-1 ; Disable Heater 1 so we can use it for a tool
                M453 P0 R24000 F400 ; Set to CNC mode, using Tool 0, 24000 Max RPM, PWM Frequency 400hz
                  A Former User @A Former User
                  @bearer said in Blank Page after update of Duet Web Control:
                  M20 S2 P"/www"
                  M20 S2 P"/www"
                  {"dir":"/www","first":0,"files":["html404.htm","language.xml.gz","reprap.htm.gz","*css","*fonts","*js","favicon.ico","*img","dwc.json","index.html","index.html.gz","favicon.ico.gz"],"next":0,"err":0}
                    @bearer what am I looking for in the developer console? I have it open.
                      This post is deleted!
                        @Phaedrux I also seem to have just a ton of files in my system folder now. I have never seen this many before:
                          Looks like you might have accidentally placed the contents of the dwc zip file in the /sys folder instead of the /www folder.
                            @Phaedrux Wow super rookie mistake.
                              no big deal. You have a backup of your SD card from before you started updating right?
                                @Phaedrux right...... No but I guess I need the practice and the lesson.
                                  @Phaedrux fixed and fixed, comes up no problem now. Thank you
                                  • h4ntyundefined h4nty referenced this topic
