    Demoing Duet 3 machine without internet?
    386
    • oozeBotundefined
      oozeBot
      Our prototype uses a Duet3 / RPi combo along with a PanelDue. Since the PanelDue cannot yet read the RPi’s SD card, it makes demoing without internet very difficult. I’ve been told this issue will be resolved in a coming release.
      Does anyone have any ideas on how to easily circumvent this? I have a demo scheduled in two days and am looking for any good work around. I may try using my cell as a WiFi access point but am unsure if my laptop will be able to find the RPi..
      • gtj0undefined
        gtj0
        Can you not just hook up a monitor and mouse to the RPi? You could also give both the RPi and your laptop static IP addresses and just hook them together with an ethernet cable.
        • projectR3Dundefined
          projectR3D
          If you are running the pi with the gui I suggest just plugging in a monitor keyboard and mouse into the Pi. This way you have the web interface that you can fully demonstrate. Personally I find the Panel useless for the Duet3 and Im looking into HDMI panel replacements.
          • oozeBotundefined
            oozeBot
            Hmm.. I might try using a small switch to connect my laptop to the pi directly vs lugging a monitor around. Thanks- I’ve been focused on trying to do this wirelessly.
            Danalundefined DocTruckerundefined 2 Replies Last reply Reply Quote 0
            • Danalundefined
              Danal @oozeBot
              @gfisher said in Demoing Duet 3 machine without internet?:
              Most modern laptops have auto-sense for ethernet crossover. Try it, you may not need the switch.
              • bondusundefined
                bondus
                If you have a windows laptop with wifi you can simply "share internet" with the ethernet and plug that into the PI. It's quite simple to do.
                What Danal says is also true. If that not work you can buy a special cross cable made for point-to-point connection without a switch.
                oozeBotundefined 1 Reply Last reply Reply Quote 1
                • DocTruckerundefined
                  DocTrucker @oozeBot
                  ...vs lugging a monitor around. ...
                  Just ordered a £30 HDMI touch screen from ebay. No larger than PanelDue.
                    droftarts administrators @oozeBot
                    @gfisher unless you particularly need the features of the RPi for the demo, you could disconnect it, run the Duet 3 in standalone mode, and the PanelDue should work correctly. Just make sure all your config and Gcode files are on the SD card in the Duet.
                    • oozeBotundefined
                      oozeBot @bondus
                      @bondus This turned out to be the simplest solution... thanks!
