    Brakes on Stepper Motors
    • C6Dundefined
      C6D
      Hi All,
      I realise this topic has been raised a couple of times before with various solutions being put on the table namely worm gears and firmware changes.
      What I would like to know is if anyone has had any success operating brakes on stepper motors without making firmware changes? I'm using the Duet 2 eco system with the DUEX 5 expansion board.
      I'm planning on driving two Nema 17 with friction brakes. These brakes require a always on 24V signal to disengage. The plan was to get the 24V through a Mosfet Board.
      Any help regarding this would be greatly appreciated.
      Regards,
      Andre
      • DocTruckerundefined
        DocTrucker
        Could use the PS_ON pin and ensure M80 is at the end of your config.g?
        If you did get a heater fault the steppers could be commanded to drive against the brakes.
        C6Dundefined 1 Reply Last reply Reply Quote 0
        • C6Dundefined
          C6D @DocTrucker
          @DocTrucker are you referring to what would happen if I did what you suggested in your striked through comment?
            DocTrucker
            Yeah, don't do what I suggested! 😄
              A Former User
              There is already an enable signal going to the motor drivers; this could be used for disengaging the brake as well i recon?
              You'll have to solder to get to the signals (for the duex you might get away with a splice on the 50pin ribbon)
              • C6Dundefined
                C6D @A Former User
                @bearer I'll try it and give feedback.
                  A Former User
                  Btw, just realized there is a common enable signal for all the drivers if that makes a difference.
