    Y-splitter and Duet 2
    PanelDue
    • Anidalundefined
      Anidal
      Good afternoon!!
      Tell me how to properly configure the printer so that there are no artifacts in the PanelDue.
      Problem:
      After adding the y-splitter and, accordingly, 2 tools per 1 heater, the tools began to display incorrectly on the panel.
      At the same time, the web-interface works correctly.
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Jan 21 2019 19:24:43 GMT+0300
      ;M929 P"eventlog6.txt" S1
      M111 S6
      ;M584 X0 Y1 Z2 E3:4 ;Driver 0 controls the X motor, 1 controls Y, 2 control Z motors, 3 4 control E motors and 5 control U axis
      M584 X0 Y1 Z2 E3:4:6 U5 ;Driver 0 controls the X motor, 1 controls Y, 2 control Z motors, 3 4 6 control E motors and 5 control U axis
      M667 S1 ; Select CoreXY mode
      M550 P"My little pony 2" ; Set machine name
      M551 P"Konica120: ; Set password
      M552 S1 ; Enable network
      M587 S"TOLO" P"Konica120" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S0 ; Enable Telnet
      M569 P3 S0 ; Drive 3 goes back
      M569 P4 S0 ; Drive 4 goes back
      M569 P5 S1 ; Drive 5 goes forwards
      M569 P6 S1 ; Drive 6 goes forwards
      ;M350 E128:128 I0 ; Configure microstepping without interpolation MK8
      ;M350 E128:64 I0 ; Configure microstepping without interpolation SUNJIU
      M350 E128:64:64 I0 ; Configure microstepping without interpolation SUNJIU+B2D
      M350 X64 Y64 Z16 I0 ; Configure microstepping with interpolation
      M350 U16 I1 ; Configure microstepping with interpolation
      ;M92 X320.00 Y320.00 Z625.00 E1136.00:1136.00 U8.889 ; Set steps per mm MK8
      ;M92 X320.00 Y320.00 Z625.00 E1136.00:1337.7 U8.889 ; Set steps per mm SUNJIU
      ;M92 X320.00 Y320.00 Z625.00 E1136.00:1401:883 U8.889 ; Set steps per mm SUNJIU+B2D
      ;M92 X320.00 Y320.00 Z625.00 E1136.00:1401:1460 U8.889 ; Set steps per mm SUNJIU+B2D(mk8) (lin)
      M92 X320.00 Y320.00 Z625.00 E1079.00:1331:1387 U8.889 ; Set steps per mm SUNJIU+B2D(mk8)(good)
      M566 X600.00 Y450.00 Z120.00 E600.00:600.00:600.00 U200 ; Set maximum instantaneous speed changes (mm/min)
      ;M566 X600.00 Y450.00 Z120.00 E600.00:900.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z360.00 E1600.00:1600.00:1600.00 U7200 ; Set maximum speeds (mm/min)
      ;M203 X12000.00 Y12000.00 Z360.00 E1600.00:1600.00 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y2000.00 Z200.00 E3000.00:2000.00:2000.00 U200 ; Set accelerations (mm/s^2)
      ;M201 X3000.00 Y2000.00 Z200.00 E3000.00:3000.00 ; Set accelerations (mm/s^2)
      M906 X1400.00 Y1400.00 Z1400.00 E1600.00:1700.00:1500.00 U500 I30 ; Set motor currents (mA) and motor idle factor in per cent SUNJIU
      ;M906 X1400.00 Y1400.00 Z1400.00 E1600.00:1600.00 I30 ; Set motor currents (mA) and motor idle factor in per cent MK8
      M84 S300 ; Set idle timeout
      M208 X0 Y0 Z0 U0 S1 ; Set axis min/max
      M208 X228 Y245 Z250 U360 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      M574 U0 S0 ; U has no endstop, but...
      ;Filament sensors
      ;M591 D0 P2 C3 S1
      ;M591 D1 P2 C4 S1
      M581 E0:1 S1 T1 C1;
      M558 P0 H3 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
      M557 X15:210 Y15:230 S100 ; Define mesh grid
      M305 P0 X0 T100000 B3950 R4700 S"Bed" ; Set thermistor + ADC parameters for heater 0
      M301 H0 S0.98 ; Set heater 0 PWM limit to 98%
      M143 H0 S140 ; Set temperature limit for heater 0 to 130C
      M570 H0 P30 T25 S2 ; Configure heater fault detection
      M305 P1 X501 R4700 S"support" ; Configure thermocouple for heater 1
      M301 H1 S0.98 ; Set heater 1 PWM limit to 98%
      M570 H1 P30 T25 S1 ; Configure heater fault detection
      M305 P2 X502 R4700 S"main" ; Configure thermocouple for heater 2
      M301 H2 S0.98 ; Set heater 2 PWM limit to 98%
      M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      M570 H2 P30 T25 S1 ; Configure heater fault detection
      M305 P3 X3 T100000 B3950 R4700 S"Obduv" ; Set thermistor + ADC parameters for heater 3
      M301 H3 S0.98 ; Set heater 3 PWM limit to 98%
      M143 H3 S90 ; Set temperature limit for heater 3 to 80C
      M570 H3 P30 T25 S1 ; Configure heater fault detection
      M305 P102 X4 T100000 B3950 R4700 S"Сold_junction" ; Set thermistor + ADC parameters for heater 4
      M305 P103 X5 T100000 B3950 R4700 S"Hot_End" ; Set thermistor + ADC parameters for heater 5
      M106 P0 S0.3 I0 F500 H-1 C"Obduv" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H-1 C"HotEnd" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0.9 I0 F500 H-1 C"Extruders" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P3 S0.6 I0 F500 H-1 C"main cool" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 S"support" D0 H1 L0 ; Define tool 0
      M572 D0 S0.2; set extruder 0 pressure advance to 0.4 seconds
      ╨╢M592 D0 A0.008 B0.0001 L2 ; set parameters for extruder drive 0
      M221 S100 D0 ;Set extrude factor override percentage
      M563 P1 S"main" D1 H2 L1 ; Define tool 1
      G10 P1 X-18 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M572 D1 S0.3 ; set extruder 0 pressure advance to 0.5 seconds
      ╨╢M592 D1 A0.001 B0.0002 L2; M592 D1 A0.07 B0.0005 L5 ;M592 D1 A0.07 B0.003 L5 ;M592 D1 A0.06 B0.0025 L2 ; set parameters for extruder drive 1
      M221 S100 D1 ;Set extrude factor override percentage
      M563 P2 S"mainB2D" D2 H2 L3 ; Define tool 1
      G10 P2 X-18 Y0 Z0 ; Set tool 1 axis offsets
      G10 P2 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M572 D2 S0.3 ; set extruder 0 pressure advance to 0.5 seconds
      ╨╢M592 D2 A0.001 B0.0002 L2; set parameters for extruder drive 1
      M221 S100 D2 ;Set extrude factor override percentage
      M563 P3 S"obduv" H3 ; Define tool 2
      G10 P3 X0 Y0 Z0 ; Set tool 2 axis offsets
      G10 P3 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
      ;M563 P7 S"Сold junction" H4 ; Define sensor
      ;M563 P8 S"HotEnd" H5 ; Define sensor
      M501 ; Load saved parameters from non-volatile memory
      T0
      T1 ; Select first tool
      T3
      T2
      • Anidalundefined
        Anidal
        Doctor, they ignore me!
          droftarts administrators @Anidal
          @Anidal Unfortunately, this is a limitation of the PanelDue firmware. It shows the four tools you have defined at the top, then iterates the heaters below, expecting one heater per tool. Because you are using one heater shared between two tools, it doesn't quite know what to do with this, and ends up showing the active temperature of T1, and standby temperature of T2, on the shared H2 heater.
          Unless you really want to set temperatures on the Panel Due, I don't think this will be an issue. It will just display the values. We are currently not planning further PanelDue firmware updates for RepRapFirmware 2, so this will not be fixed with your current setup.
          However, with the development and release of RepRapFirmware 3 there is scope to update PanelDue and add a number of requested features and better support a wider variety of setups, once the new Object Model in RRF3 is stable. The PanelDue is on the 'to do' list for this.
          • Anidalundefined
            Anidal
            Ok. Wait for next version....
