    Mesh Bed Compensation Screwy
    65
    10.6k
    • CHPundefined
      CHP
      Ok, so I loaded GrodanB's heightmap.csv and then sampled the whole bed ( HeightMap::GetInterpolatedHeightError() ) with a 4mm (and 2mm) resolution and visualised the result with excel.
      The first one is rather off, the area clearly wrong. Debugging it showed that GridDefinition::recipSpacing is still at its default value (for a 20mm grid) after loading the .csv.
      After fixing that it is much better, but still some hard jumps at the borders, so I'll debug the border-interpolation next.
      My fixes as well as the (very shoddy) simulator I use can be found here: https://github.com/ChristophPech/RepRapFirmware
      • 3dprinting meatheadundefined
        3dprinting meathead
        I just made a short video of the smooth motion without g29, and the choppier motion with.
        I'm not sure if it's a bug, maybe all the variables eat up the processing power?
        But I don't remember my 8 bit board doing this.
        Here's the video:
        https://youtu.be/igNx0sjtSqE
        If I can learn it, than anyone can learn it.
        • CHPundefined
          CHP
          I found an error in one of the interpolation functions and fixed it (pull request pending)
          The result looks much better:
          • CHPundefined
            CHP
            But there is still more. Zeroing out the last two columns gives me this:
            The interpolation overflows into the first column of the next line. Fixing it:
            The final result of the whole mesh: looks quite good.
            • CHPundefined
              CHP
              And we can even do better by using bicubic interpolation:
              Since Z is often the slowest axis, smoothing it out will mean smoother movement for the other axes.
              But there still remain two last issues: unprobed points with a 0 csv are being clamped to zero, this can easily be fixed
              Second: points outside the probing area remain constant. These should be extrapolated, maybe something like linear regression.
              Thoughts?
                @CHP, many thanks for diagnosing and fixing these issues. I have accepted your pull request, and I will release a new 1.18 beta soon incorporating these changes.
                • pcsentinelundefined
                  pcsentinel
                  Hi CHP, can I just say thank you for identifying this and fixing, very very much appreciated.
                  DC42, have you any idea what going on re my comment about 4 pont adjustment above?
                  thanks
                    3dprinting meathead
                    @CHP although I only understand have of what you said(the hampster wheel in my head is seizing up), the pictures you put up show that you've found a way to wrangle the angry pixies flowing to my motors, and I thank you for it.
                      @pcsentinel:
                      thanks
                      You need to probe clockwise round the bed, not anticlockwise. One of these days I'll get round to either re-ordering the points or generating an error message if they are in the wrong order.
                        pcsentinel
                        Hi, tried this which is clockwise
                        G30 P0 X151 Y151 H0 Z-99999
                        G30 P1 X151 Y49 H0 Z-99999
                        G30 P2 X49 Y49 H0 Z-99999
                        G30 P3 X49 Y151 H0 Z-99999 S4
                        but same result, just gives a small judder on first move after running the bed level and then wont move anymore. (Sorry)
                          pcsentinel
                          Update, maybe its just my misunderstanding of how this works, but commented out last line and moved S to third line as
                          G30 P0 X100 Y151 H0 Z-99999
                          G30 P1 X151 Y151 H0 Z-99999
                          G30 P2 X151 Y49 H0 Z-99999 S
                          works and I can then see compensation movement through moves, yet to try with a print though
                            @pcsentinel:
                            Start with your X49 Y49 point as P0 and go clockwise from there.
                              pcsentinel
                              Further Update, changed the coords so that there were four but not in a perfect square. And now it works with 4, but following running the bed compensation, Z is set to an insane neagtive number of -199.91
                              G30 P0 X49 Y151 H0 Z-99999
                              G30 P1 X150 Y150 H0 Z-99999
                              G30 P2 X149 Y50 H0 Z-99999
                              G30 P3 X51 Y50 H0 Z-99999 S
                              Go back to 3points as
                              G30 P1 X149 Y50 H0 Z-99999
                              G30 P2 X51 Y50 H0 Z-99999 S
                              and Z after shows 5.73 and z compensation across the bed seems to work, again need to wait till tonight to try a print
                              • GrodanBundefined
                                GrodanB
                                Great work, thanks.
                                Just tell me when a beta is available and I test with that.
                                It would be interesting to see the result. I'll switch back to 16 mm square instead of the 32 mm I used for this test.
                                I'll still wonder if there is something hidden in the fact that the measurement clearly shows that the bed is high at the back right off the plate but the print is pressed hard against the plate on precisely that spot… Strange if you ask me...
                                Then I kind of wonder how the compensation is done when printing with dual head. I set the distance between the first tool and the Z-probe. But I do not enter the distant from the second... So is automatically compensated or should I refer to a point in the middle?
                                G31 X-25.19 Y7 Z2.67 P500 ; Set the probe height and threshold; increase Z to decrease bed probe distance X11.0 Y0.5
                                This is relative the tool 1 nozzle... the nozzles are approx. 38 mm apart. So to place the compensation in the middle should I use:
                                G31 X-44.19 Y7 Z2.67 P500
                                Or is the 38mm added due to
                                G10 P1 X38.3 Y0.0 Z0.0 S0 R0
                                So that exact bed leveling is done for the extruding nozzle?
                                  pcsentinel
                                  Update on G30 four point probing. Now I have actually read DC42's comment (sorry must have overlapped) I have set the four poits clockwise from minor XY as per
                                  G30 P0 X49 Y49 H0 Z-99999
                                  G30 P1 X49 Y149 H0 Z-99999
                                  G30 P2 X149 Y149 H0 Z-99999
                                  G30 P3 X149 Y49 H0 Z-99999 S
                                  it looks like the four pointer is working, the results are
                                  G32
                                  Bed equation fits points [49.0, 49.0, -0.118] [49.0, 149.0, -0.156] [149.0, 149.0, 0.162] [149.0, 49.0, -0.093]
                                  So my final bed.g looks like
                                  ; bed.g
                                  ; generated by RepRapFirmware Configuration Tool on Sun Feb 26 2017 13:25:00 GMT+0000 (GMT Standard Time)
                                  G90
                                  ; Clear any bed transform
                                  M561
                                  ; Probe the bed at 4 points CLOCKWISE!
                                  G28
                                  G1 X0 Y0
                                  Also my Home Z and Home All now have
                                  G1 X1 Y21 F6000
                                  G30
                                  becuase my X offset of the probe from the extruder is 48 and Y offset is 28 and G30 instructions account for the offset in the instructed points.
                                  Hope this helps anyone else who is suffering.
                                    pcsentinel
                                    Hi All, can I now confirm that I amprinting the four squares test succesfully. thanks for your help.
                                    DC42 as a suggestion, might it be worthwhile adding the above fledged out with a little explanation to the Wiki, at least for those of us that are using Glass Beds on a Cartesian?
                                      deckingman
                                      @pcsentinel. Glad you got it sorted. A couple of points. You seem to only be doing the bed compensation for 100mm x 100mm of the bed area. It's usually best to probe close to the 4 extreme corners of the axes movements so that you cover the entire printable area. Also, your Z homing example seems to indicate that you are homing Z at one corner of the bed and it's usually better to do the Z homing at the centre of the bed, because that is where the majority of your printing will take place and therefore where you need the most accuracy. HTH
                                        pcsentinel
                                        Ok, thanks I tried that, but because of my offset when I go to postion 2 on the grid with
                                        G30 P1 X49 Y189 H0 Z-99999
                                        the nozzle is hitting the bed and compressing the carriage before te sensor is activated therefor throwing off the reading
                                          @pcsentinel:
                                          I think you must have a severely tilted bed. You can increase the Z probe dive height - it's the H parameter in the M558 command. But it's better to get the bed more level than to rely on a lot of compensation.
                                          • GrodanBundefined
                                            GrodanB
                                            Is it possible for me to test before a firmware is released?
