    Mesh Bed Compensation Screwy
    65
    10.6k
    • 3dprinting meatheadundefined
      3dprinting meathead
      I just made a short video of the smooth motion without g29, and the choppier motion with.
      I'm not sure if it's a bug, maybe all the variables eat up the processing power?
      But I don't remember my 8 bit board doing this.
      Here's the video:
      https://youtu.be/igNx0sjtSqE
      If I can learn it, than anyone can learn it.
      • CHPundefined
        CHP
        I found an error in one of the interpolation functions and fixed it (pull request pending)
        The result looks much better:
        • CHPundefined
          CHP
          But there is still more. Zeroing out the last two columns gives me this:
          The interpolation overflows into the first column of the next line. Fixing it:
          The final result of the whole mesh: looks quite good.
          • CHPundefined
            CHP
            And we can even do better by using bicubic interpolation:
            Since Z is often the slowest axis, smoothing it out will mean smoother movement for the other axes.
            But there still remain two last issues: unprobed points with a 0 csv are being clamped to zero, this can easily be fixed
            Second: points outside the probing area remain constant. These should be extrapolated, maybe something like linear regression.
            Thoughts?
              @CHP, many thanks for diagnosing and fixing these issues. I have accepted your pull request, and I will release a new 1.18 beta soon incorporating these changes.
              • pcsentinelundefined
                pcsentinel
                Hi CHP, can I just say thank you for identifying this and fixing, very very much appreciated.
                DC42, have you any idea what going on re my comment about 4 pont adjustment above?
                thanks
                  3dprinting meathead
                  @CHP although I only understand have of what you said(the hampster wheel in my head is seizing up), the pictures you put up show that you've found a way to wrangle the angry pixies flowing to my motors, and I thank you for it.
                    @pcsentinel:
                    thanks
                    You need to probe clockwise round the bed, not anticlockwise. One of these days I'll get round to either re-ordering the points or generating an error message if they are in the wrong order.
                      pcsentinel
                      Hi, tried this which is clockwise
                      G30 P0 X151 Y151 H0 Z-99999
                      G30 P1 X151 Y49 H0 Z-99999
                      G30 P2 X49 Y49 H0 Z-99999
                      G30 P3 X49 Y151 H0 Z-99999 S4
                      but same result, just gives a small judder on first move after running the bed level and then wont move anymore. (Sorry)
                        pcsentinel
                        Update, maybe its just my misunderstanding of how this works, but commented out last line and moved S to third line as
                        G30 P0 X100 Y151 H0 Z-99999
                        G30 P1 X151 Y151 H0 Z-99999
                        G30 P2 X151 Y49 H0 Z-99999 S
                        works and I can then see compensation movement through moves, yet to try with a print though
                          @pcsentinel:
                          Start with your X49 Y49 point as P0 and go clockwise from there.
                            pcsentinel
                            Further Update, changed the coords so that there were four but not in a perfect square. And now it works with 4, but following running the bed compensation, Z is set to an insane neagtive number of -199.91
                            G30 P0 X49 Y151 H0 Z-99999
                            G30 P1 X150 Y150 H0 Z-99999
                            G30 P2 X149 Y50 H0 Z-99999
                            G30 P3 X51 Y50 H0 Z-99999 S
                            Go back to 3points as
                            G30 P1 X149 Y50 H0 Z-99999
                            G30 P2 X51 Y50 H0 Z-99999 S
                            and Z after shows 5.73 and z compensation across the bed seems to work, again need to wait till tonight to try a print
                            • GrodanBundefined
                              GrodanB
                              Great work, thanks.
                              Just tell me when a beta is available and I test with that.
                              It would be interesting to see the result. I'll switch back to 16 mm square instead of the 32 mm I used for this test.
                              I'll still wonder if there is something hidden in the fact that the measurement clearly shows that the bed is high at the back right off the plate but the print is pressed hard against the plate on precisely that spot… Strange if you ask me...
                              Then I kind of wonder how the compensation is done when printing with dual head. I set the distance between the first tool and the Z-probe. But I do not enter the distant from the second... So is automatically compensated or should I refer to a point in the middle?
                              G31 X-25.19 Y7 Z2.67 P500 ; Set the probe height and threshold; increase Z to decrease bed probe distance X11.0 Y0.5
                              This is relative the tool 1 nozzle... the nozzles are approx. 38 mm apart. So to place the compensation in the middle should I use:
                              G31 X-44.19 Y7 Z2.67 P500
                              Or is the 38mm added due to
                              G10 P1 X38.3 Y0.0 Z0.0 S0 R0
                              So that exact bed leveling is done for the extruding nozzle?
                                pcsentinel
                                Update on G30 four point probing. Now I have actually read DC42's comment (sorry must have overlapped) I have set the four poits clockwise from minor XY as per
                                G30 P0 X49 Y49 H0 Z-99999
                                G30 P1 X49 Y149 H0 Z-99999
                                G30 P2 X149 Y149 H0 Z-99999
                                G30 P3 X149 Y49 H0 Z-99999 S
                                it looks like the four pointer is working, the results are
                                G32
                                Bed equation fits points [49.0, 49.0, -0.118] [49.0, 149.0, -0.156] [149.0, 149.0, 0.162] [149.0, 49.0, -0.093]
                                So my final bed.g looks like
                                ; bed.g
                                ; generated by RepRapFirmware Configuration Tool on Sun Feb 26 2017 13:25:00 GMT+0000 (GMT Standard Time)
                                G90
                                ; Clear any bed transform
                                M561
                                ; Probe the bed at 4 points CLOCKWISE!
                                G28
                                G1 X0 Y0
                                Also my Home Z and Home All now have
                                G1 X1 Y21 F6000
                                G30
                                becuase my X offset of the probe from the extruder is 48 and Y offset is 28 and G30 instructions account for the offset in the instructed points.
                                Hope this helps anyone else who is suffering.
                                  pcsentinel
                                  Hi All, can I now confirm that I amprinting the four squares test succesfully. thanks for your help.
                                  DC42 as a suggestion, might it be worthwhile adding the above fledged out with a little explanation to the Wiki, at least for those of us that are using Glass Beds on a Cartesian?
                                    deckingman
                                    @pcsentinel. Glad you got it sorted. A couple of points. You seem to only be doing the bed compensation for 100mm x 100mm of the bed area. It's usually best to probe close to the 4 extreme corners of the axes movements so that you cover the entire printable area. Also, your Z homing example seems to indicate that you are homing Z at one corner of the bed and it's usually better to do the Z homing at the centre of the bed, because that is where the majority of your printing will take place and therefore where you need the most accuracy. HTH
                                      pcsentinel
                                      Ok, thanks I tried that, but because of my offset when I go to postion 2 on the grid with
                                      G30 P1 X49 Y189 H0 Z-99999
                                      the nozzle is hitting the bed and compressing the carriage before te sensor is activated therefor throwing off the reading
                                        @pcsentinel:
                                        I think you must have a severely tilted bed. You can increase the Z probe dive height - it's the H parameter in the M558 command. But it's better to get the bed more level than to rely on a lot of compensation.
                                        • GrodanBundefined
                                          GrodanB
                                          Is it possible for me to test before a firmware is released?
                                            pcsentinel
                                            Further unknown with 4 point plane. Sorry I know this is under Mesh, but its where all the previous comments are.
                                            I extended my four points to be wider but obviously still keep the probe over the bed.
                                            I then thought I would check each four points without any compensation, i.e. drop nozzle to just hold paper, set z to 0, raise head by 5mm and do G30 S-1. and then check repeatability. the result are below that seem to indicate that the points all have different trigger heights but repeatability at each point is good.
                                            Nozzle X Nozzle Y Probe X Probe Y G30 S-1 G30 S-1 G30 S-1 Average Offset from P1
                                            Point 1 1 1 49 29 0.385 0.382 0.38 0.382333333 0
                                            Point 2 1 161 49 189 0.298 0.298 0.303 0.299666667 -0.082666667
                                            Point 3 131 161 179 189 0.157 0.153 0.155 0.155 -0.227333333
                                            Point 4 131 161 179 189 0.185 0.185 0.188 0.186 -0.196333333
                                            My settings in coonfig.g are
                                            M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                                            G31 P500 X48 Y28 Z0.382333333 ; Set Z probe trigger value, offset and trigger height
                                            I therefor mofidied my bed.g to
                                            ; bed.g
                                            G90
                                            M561
                                            G28
                                            G30 P0 X49 Y29 H0 Z-99999
                                            G30 P1 X49 Y189 H-0.082666667 Z-99999
                                            G30 P2 X179 Y189 H-0.227333333 Z-99999
                                            G30 P3 X179 Y29 H-0.196333333 Z-99999 S
                                            G1 Z5
                                            G1 X0 Y0
                                            But after I ran the bed compensation I then went back to each probe point and dropped the Z to 0 over the piece of paper, at all points the paper was trapped until I lifted the nozzle 0.3mm. So I added:
                                            G1 Z0.25
                                            G92 Z0
                                            into the bed.g before the G1 Z5 and now everything seems to be working, but I am really mystified why I have to push the the height up by 0.25 does anyone know?
