    Is there a basic guide to set the duet up as a CNC
    CNC
    1.5k
      See also https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine.
      • Asdasd1234undefined
        Asdasd1234
        thanks guys ill read into this now
          Asdasd1234
          Ok so am I right in saying :
          • I have a gcode file (just a re-named .nc file from fusion 360)
          • I home my machine using g28.
          • I jog the machine to the start of the file gcode
          • Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file.
          • then run the file?
          How do I ensure the file runs using the work co-ords and not the machine co-ords? Do I need to specify it at the start of the file?
          A Former User? Danalundefined 3 Replies Last reply Reply Quote 0
            A Former User @Asdasd1234
            @Asdasd1234 said in Is there a basic guide to set the duet up as a CNC:
            Think there is an option in your post processor to either run G28 or G54 at the start of the exported g-code? Been awhile since I've messed with that stuff. You can review the top of the exported g-code to verify what you get.
            • Danalundefined
              Danal
              All CNC machines that follow G-Code standards are always in a work coordinate system.* The default at power up is G54. When you do the G10 L20 P2, you are setting the "second" system, namely G55.
              Therefore, you can have a G55 at the very start of your file, or issue a G55 via the Web interface.
              * Always, with the single exception of an individual line that starts with G53, which will operate in machine coordinates. G53 is not 'sticky' and therefore applies to only the line where it appears.
              Asdasd1234undefined 1 Reply Last reply Reply Quote 0
                Asdasd1234 @Danal
                @Danal
                Ah, so I could do the following?
                • G28 home the machine
                • Jog machine to start of file.
                • Run macro that does:
                  -G10 L20 P2 X0 Y0 Z0
                  -G55
                • Then run the file?
                Sorry for all the questions, I just realllly dont want to crash the machine into an axis or the bed etc
                Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • Danalundefined
                  Danal @Asdasd1234
                  You are basically correct, here is a slight rephrasing of a couple of lines, just for clarity.
                  • I have a gcode file (just a re-named .nc file from fusion 360) Correct, upload that file via the Web interface
                  • I home my machine using g28. Correct
                  • I jog the machine to the start of the file gcode to the tip of the cutter just touching the origin of the stock. Normally in the 'lower left' corner, and just touching top-of-stock in Z.
                  • Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file. the second work-coordinate-system (G55) to match the physical object I want to cut
                  • then run the file? Issue a G55, then, Yes, in the Jobs tab, click then file, then OK
                  • Danalundefined
                    Danal @Asdasd1234
                    -G55
                    Then run the file?
                    Yes
                      Asdasd1234 @Danal
                      @Danal
                      Thats great, I'll try that now. Thanks a bunch for the help people. Its much appreciated
                      • Danalundefined
                        Danal
                        No problem.
                        This does assume you've set Z0 to top of stock in Fusion. This is a fairly normal CNC practice.
                          Asdasd1234 @Danal
                          @Danal
                          I'm pretty sure I have, but will double check
                            Asdasd1234
                            Ah, I might have an issue.
                            F360, when set to grbl only lists out the co-ordinates and doesn't do a G1/0 before them like:
                            G1 Z1 F500
                            Z-1.999
                            Y26.033 Z-2 F1200
                            Y26.034
                            X28.967 Y26.035
                            X28.595 Y26.047
                            X28.194 Y26.057
                            X27.792 Y26.067
                            Will this still work?
                            • Danalundefined
                              Danal
                              No. Duet doesn't support "sticky" G1 or G0. You will need to select a different post processor, or modify that one.
                              • Danalundefined
                                Danal
                                I use Mach3 post. Which isn't perfect, but it does put G1 on each line.
                                  Asdasd1234
                                  i found a post processor online for duet. I need to manually delete out the G54 at the start, but my test pen-plot has come out perfect. Thanks a bunch!
                                    you can edit the .cps file and change the line that says (line 28 in the grbl if thats what you used)
                                    extension = "nc";
                                    to say
                                    extension = "gcode";
                                    to not have to do the renaming.
                                    try putting a "2" in WCS offset here if you wanted G55 instead.
                                    Setup -> Post process tab:
                                    (edit: or you could edit the file and change 1 to 2 in line 353 to make it permament and not have to set it each time.)
                                    ((or search for var workOffset = currentSection.workOffset;and change workOffset = 1; to workOffset = 2; a few lines below if your post is different from the grbl))
                                    (((or if you just wanted to get rid of the whole G54 thing try changeing the Safe retracts parameter in the post to ClearanceHeight
                                    bc723522-0a24-4561-9959-30403c9e2562-image.png )))
                                      dc42 administrators @Danal
                                      @Danal said in Is there a basic guide to set the duet up as a CNC:
                                      Yes it does, when in CNC mode and using recent firmware versions (2.05 or 3.x).
                                        @bearer said in Is there a basic guide to set the duet up as a CNC:
                                        extension = "nc";
                                        to say
                                        You don't have to rename anyway. DWC and RRF accept .nc files.
                                          dc42 administrators @Asdasd1234
                                          -G55
                                          Alternatively, use P1 in the G10 command instead of P2, then you don't need the G55.
                                          • Danalundefined
                                            Danal @dc42
                                            @dc42 said in Is there a basic guide to set the duet up as a CNC:
                                            Ah... I tried it, but not in CNC mode... grasshopper learns from master once again. 🙂
