    Is there a basic guide to set the duet up as a CNC
    CNC
    1.5k
    • Danalundefined
      Danal
      @Asdasd1234 said in Is there a basic guide to set the duet up as a CNC:
      How do I ensure the file runs using the work co-ords
      All CNC machines that follow G-Code standards are always in a work coordinate system.* The default at power up is G54. When you do the G10 L20 P2, you are setting the "second" system, namely G55.
      Therefore, you can have a G55 at the very start of your file, or issue a G55 via the Web interface.
      * Always, with the single exception of an individual line that starts with G53, which will operate in machine coordinates. G53 is not 'sticky' and therefore applies to only the line where it appears.
      Asdasd1234undefined 1 Reply Last reply Reply Quote 0
      • Asdasd1234undefined
        Asdasd1234 @Danal
        @Danal
        Ah, so I could do the following?
        • G28 home the machine
        • Jog machine to start of file.
        • Run macro that does:
          -G10 L20 P2 X0 Y0 Z0
          -G55
        • Then run the file?
        Sorry for all the questions, I just realllly dont want to crash the machine into an axis or the bed etc
        Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • Danalundefined
          Danal @Asdasd1234
          Ok so am I right in saying :
          • I have a gcode file (just a re-named .nc file from fusion 360)
          • I home my machine using g28.
          • I jog the machine to the start of the file gcode
          • Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file.
          • then run the file?
          How do I ensure the file runs using the work co-ords and not the machine co-ords? Do I need to specify it at the start of the file?
          You are basically correct, here is a slight rephrasing of a couple of lines, just for clarity.
          • I have a gcode file (just a re-named .nc file from fusion 360) Correct, upload that file via the Web interface
          • I home my machine using g28. Correct
          • I jog the machine to the start of the file gcode to the tip of the cutter just touching the origin of the stock. Normally in the 'lower left' corner, and just touching top-of-stock in Z.
          • Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file. the second work-coordinate-system (G55) to match the physical object I want to cut
          • then run the file? Issue a G55, then, Yes, in the Jobs tab, click then file, then OK
          • Danalundefined
            Danal @Asdasd1234
            -G55
            Then run the file?
            Yes
              Asdasd1234 @Danal
              @Danal
              Thats great, I'll try that now. Thanks a bunch for the help people. Its much appreciated
              • Danalundefined
                Danal
                No problem.
                This does assume you've set Z0 to top of stock in Fusion. This is a fairly normal CNC practice.
                  Asdasd1234 @Danal
                  @Danal
                  I'm pretty sure I have, but will double check
                    Asdasd1234
                    Ah, I might have an issue.
                    F360, when set to grbl only lists out the co-ordinates and doesn't do a G1/0 before them like:
                    G1 Z1 F500
                    Z-1.999
                    Y26.033 Z-2 F1200
                    Y26.034
                    X28.967 Y26.035
                    X28.595 Y26.047
                    X28.194 Y26.057
                    X27.792 Y26.067
                    Will this still work?
                    • Danalundefined
                      Danal
                      No. Duet doesn't support "sticky" G1 or G0. You will need to select a different post processor, or modify that one.
                      • Danalundefined
                        Danal
                        I use Mach3 post. Which isn't perfect, but it does put G1 on each line.
                          Asdasd1234
                          i found a post processor online for duet. I need to manually delete out the G54 at the start, but my test pen-plot has come out perfect. Thanks a bunch!
                            A Former User @Asdasd1234
                            you can edit the .cps file and change the line that says (line 28 in the grbl if thats what you used)
                            extension = "nc";
                            to say
                            extension = "gcode";
                            to not have to do the renaming.
                            try putting a "2" in WCS offset here if you wanted G55 instead.
                            Setup -> Post process tab:
                            (edit: or you could edit the file and change 1 to 2 in line 353 to make it permament and not have to set it each time.)
                            ((or search for var workOffset = currentSection.workOffset;and change workOffset = 1; to workOffset = 2; a few lines below if your post is different from the grbl))
                            (((or if you just wanted to get rid of the whole G54 thing try changeing the Safe retracts parameter in the post to ClearanceHeight
                            bc723522-0a24-4561-9959-30403c9e2562-image.png )))
                              dc42 administrators @Danal
                              @Danal said in Is there a basic guide to set the duet up as a CNC:
                              Yes it does, when in CNC mode and using recent firmware versions (2.05 or 3.x).
                                @bearer said in Is there a basic guide to set the duet up as a CNC:
                                extension = "nc";
                                to say
                                You don't have to rename anyway. DWC and RRF accept .nc files.
                                  dc42 administrators @Asdasd1234
                                  -G55
                                  Alternatively, use P1 in the G10 command instead of P2, then you don't need the G55.
                                  • Danalundefined
                                    Danal @dc42
                                    @dc42 said in Is there a basic guide to set the duet up as a CNC:
                                    Ah... I tried it, but not in CNC mode... grasshopper learns from master once again. 🙂
                                    • Danalundefined
                                      Danal @dc42
                                      -G55
                                      This is true... but... a lot of people like to leave G54 matching machine, because there the controller is always in some Work Coordinate System, and it just makes more sense for the human to have G54 match the physical layout of the device, G55 match the first fixture, G56 the second fixture and so forth.
                                      Again, there is no "right or wrong" here... and some people do it a completely different way... the most common practice I've seen is leaving G54 alone (or, technically, G54 has a 0,0,0 offset to G53).
