    RepRapFirmware 3.01-RC3 released
    Beta Firmware
    22
    68
    4.2k
      dc42 administrators @c310
      @c310 said in RepRapFirmware 3.01-RC3 released:
      @TurtlePrint said in RepRapFirmware 3.01-RC3 released:
      When sending the M112 command the printer turns off and then starts the hot end fan "fan1" at full speed
      i have the same issue too. after M112 (or hardware mushroom button) printer stops, starts reboot and stucks with the cooling fan at 100% speed.
      M112 has always done that. The printer should still respond to M999.
      c310undefined 1 Reply Last reply Reply Quote 0
      • c310undefined
        c310 @dc42
        @dc42 thanks, m999 works however to do so i need to use /reprap UI, DWC remains "blocked" untill power cycle.
        in old good times of 2.x firmware mushroom button not only stopped operations, but also made
        web interface responsive after reset (that does not happen in 3.01-RC3 )
        what is a way to link m999 to emergency stop button (instead of triggering m112) without macros ?
        or what can be done to run m999 after m112 generated by mushroom button ?
          dc42 administrators @insertnamehere
          @insertnamehere said in RepRapFirmware 3.01-RC3 released:
          I'm using conditional code to optimized bed leveling.
          On occasions when the 2 points used are equal I get an initial deviation of NAN.
          3/10/2020, 11:10:16 AM Leadscrew adjustments made: -0.001 -0.001, points used 2, (mean, deviation) before (-0.001, nan) after (0.000, 0.000)
          I would expect that when 2 points are the same that the standard deviation for those points would be 0. If I'm wrong, how can I test for NAN in the conditional code?
          The NaNs should be gone in the internal build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
          insertnamehereundefined 1 Reply Last reply Reply Quote 1
          • mundsenundefined
            mundsen
            When do you plan to release RC4?
            • Danalundefined
              Danal
              I may be off track here, but the reset problem described (here and in several other threads)... I believe the fix for that is having DuetControlServer restart itself as the last action when processing an M999.
              I've built a version that does that, and opened a pull request on Github in chrishamm/DuetControlServer repository.
              Meanwhile, if anyone is willing to try the 1.2.4.0 version of DuetControlServer with this fix, download this file:
              http://danalspub.com/wp-content/uploads/2020/03/DuetControlServer.zip
              Unzip, and place the two files inside in /opt/dsf/bin
              The 'DuetControlServer' file should have attributes of -rwxr-xr-x. If for some reason it does not, run chmod 755 DuetControlServer
              After the copies:
              sudo systemctl stop duetcontrolserver
              sudo systemctl start duetcontrolserver
              If you decide to go back, run:
              sudo apt-get reinstall duetcontrolserver
              or
              sudo apt-get reinstall duetcontrolserver=specific version number you wish
              You can find all available versions via:
              apt-cache policy duetcontrolserver
              gtj0undefined 2 Replies Last reply Reply Quote 1
              • gtj0undefined
                gtj0 @Danal
                @Danal I'll test it later today. Thanks!
                • gtj0undefined
                  gtj0 @Danal
                  @Danal Had to recompile with your pull request because I use a 64 bit distro but it seemed to work OK.
                  • Danalundefined
                    Danal @gtj0
                    @gtj0 said in RepRapFirmware 3.01-RC3 released:
                    Yeah, I compile for 32 because the Duet distro is Debian.
                    Thanks for checking it!! It was a one line change... "systemctl" restarts it.
                    • tobias_munichundefined
                      tobias_munich
                      DUET3-SBC/DSF Wrong print process percentage on PI/DSF
                      Hi guys.
                      My Pi shows a wrong percentage of the print progress.
                      PanalDue shows it right.
                      Is this a known error?
                      I will reboot and reset the system and start a new print and check it again.
                      144C3F8C-FEF9-404C-BDF4-EAB54BE34774.jpeg 54B6916F-5C1B-481B-94F2-2D1B454DF4CB.jpeg
                      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                      • insertnamehereundefined
                        insertnamehere @dc42
                        @dc42 said in RepRapFirmware 3.01-RC3 released:
                        Thanks @dc42, it works correctly now.
                        3/14/2020, 11:17:11 AM Leadscrew adjustments made: 0.000 0.000, points used 2, (mean, deviation) before (0.000, 0.000) after (-0.000, 0.000)
                        BED LEVELLING COMPLETED
                        Final Deviation 0.000mm
                        • appjawsundefined
                          appjaws
                          I have been using3.01- RC3 since it was released. I have discovered what could be a bug in the way the load filament works.
                          The extruder runs backwards, I also have a macro to load which also runs backward.
                          When printing the extruder works as expected and also the extrude button on DWC works correctly.
                          This is my filament load:-
                          ; Load filament Real light blue
                          M98 P"0:/macros/Set LED Red"
                          if heat.heaters[1].current <190
                          M291 P"Please wait while the nozzle is being heated up" R"Auto Filament Load" S1 T0
                          M104 S195 ; Set current tool temperature to 195C
                          M116 S5 ; waiting for nozzle to reach temperature
                          M291 P"Feed Real light blue filament into the extruder by hand and click OK" R"Auto Filament Load" S3
                          M291 P"Loading Real-light blue filament" S1 T0 ; Display new message
                          G1 E10 F600 ; Feed 10mm of filament at 600mm/min
                          G1 E250 F3000 ; Feed 210mm of filament at 3000mm/min
                          G1 E20 F300 ; Feed 20mm of filament at 300mm/min
                          G4 S1 ; Wait one second
                          G1 E-3 F1800 ; Retract 10mm of filament at 1800mm/min
                          M400 ; Wait for the moves to finish
                          M104 S0 ; Set the temperature to zero
                          M98 P"0:/macros/Set LED Green"
                          M291 P"Real light blue filament Loaded" R"Auto Filament Load" S1 T0
                          I have only noticed this since RC3, I'm sure RC2 worked properly.
                          appjaws - Core XYUV Duet Ethernet Duex5
                          firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                          Ormerod 1-converted to laser engraver, Duet wifi
                          OpenSCAD version 2024.03.18
                          Simplify3D 5.1.2
                            Might you be in absolute extrusion mode when you run that macro? Try putting M83 at the start of it.
