Duet2 Wifi and Duex Suddenly Won't Connect on RailCore
Duet Web Control
422
    A Former User
    check that the DWC files in /www on the SD card are there? or just extract a fresh copy?
      JeffAGreen
      How do I do that? Can I do that from YAT? If I try to look at it on the PC, it wants me to format it.
      ? 1 Reply Last reply 16 Mar 2020, 23:30 Reply Quote 0
        Phaedrux Moderator @JeffAGreen
        @JeffAGreen said in Duet2 Wifi and Duex Suddenly Won't Connect on RailCore:
        I tried typing M503 and I just get OK.
        Your card is dead I think. Format it and try another config set. Or try another card entirely with another config set.
        What does M122 tell you in YAT?
        undefined 1 Reply Last reply 16 Mar 2020, 23:37 Reply Quote 1
          A Former User @JeffAGreen
          https://www.sdcard.org/downloads/formatter/ that ensures windows doesn't try to be clever.
          use the "overwrite format" option if you can't replace it. takes a while 10-30 minutes maybe.
          (maybe run M20first just to rule out issue with the computer, but sounds like the duet is also struggling with the card)
          undefined 2 Replies Last reply 16 Mar 2020, 23:40 Reply Quote 2
            JeffAGreen @Phaedrux
            @Phaedrux m122.png This is what I get. I don't think it sees a card.
              JeffAGreen @A Former User
              @bearer Thanks. I have already started that format process. I have SD Card Formatter for the Pi. Where can I get some really clear instructions for getting the system back on the SD card that doesn't assume I know what I'm doing? I was able to follow the instructions for getting the firmware updated, but that was not started from scratch. Once I get to DWC, I was much more comfortable in learning how to make changes.
                https://duet3d.dozuki.com/Wiki/SD_Card
                undefined 1 Reply Last reply 16 Mar 2020, 23:43 Reply Quote 1
                  @Phaedrux Right. That part I understand. I mean, to get the software back on the SD card to run the duet.
                  undefined 1 Reply Last reply 16 Mar 2020, 23:46 Reply Quote 0
                    A Former User
                    RepRap configurator may be the simplest way, but all it does is offer you a link to download DWC to put on the card.
                    which is basically to download https://github.com/dc42/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip and extract the files to the new SD card so you have /www/index.htm.gz (and all the other files ofc)
                    Then when you connect with YAT and enable networking you can continue with configuriring through the web interface creating a /sys/config.g (or use the RepRap configurator).
                      Well the folder structure is here: https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure
                      The firmware is already on the duet, it doesn't live on the SD card.
                      The web configurator will get you the config files.
                      And bearer linked to the DWC files, which should also be present in the firmware release.
                      ? 1 Reply Last reply 17 Mar 2020, 00:02 Reply Quote 1
                        @bearer M20 shows 0 files.
                          A Former User
                          M20 shows 0 files.
                          it would when M122 said the card wasn't detected, its just less noise in the output with M20 if the SD card is the sole focus.
                            A Former User @Phaedrux
                            @Phaedrux said in Duet2 Wifi and Duex Suddenly Won't Connect on RailCore:
                            seems a new feature offers links to download the correct files at the end of the configurator
                            and then
                            11 out of 14
