    Can't access wifi
    Firmware installation
    3.6k
      A Former User @jens55
      @jens55 said in Can't access wifi:
      failed trying to connect to "-----" , wifi module is idle
      As I said, I have one non alphanumeric character in the password, a period ..... ?????
      beyond "bug" that should leave only signal strength and encryption.
      a period shouldn't pose a problem neither for RRF or your linux terminal but share the details of which terminal you went with and I can try it (also if the period is first, last or in the middle of the key just for good measure)
      • jens55undefined
        jens55
        Plenty of signal and no interference. The network uses wpa2 personal, period is in the middle. I used puTTY as the terminal program. The terminal program is configured for 9600 8 1 but does show occasional odd characters but is of course only used as an additional source for diagnostic. It is however annoying that the duet spits out a more or less continuous stream of text which may or may not indicate that something is misconfigured. I can however enter commands in a fashion and get a proper terminal response (in amongst the text the duet is constantly streaming)
        I have set things aside for now as sometimes I can't see the obvious when I get so wound up.
          special case so don't think the baud rate matters for this, but I generally leave it at 57600 in case I want to use the PanelDue port where it does matter. But I don't think I've seen any garbled data from the Duet usb serial, the connection is lost when the Duet resets but unless the garbled data is tied to resets its a bit of a concern.
          i'll give it a go when i'm back if its not sorted by then
          • jens55undefined
            jens55
            Making some odd progress ...
            I am not getting the constant flow of characters from the duet on the serial port any more and only the first command to the duet has a garbeled character in it. So ....
            I have removed all the extras out of config.g that were set up to try and get this thing going.
            I manually, through the serial port, gave it the right ssid and password. I also set up a static IP on the router.
            I now get two (!!!) entries in the client list on the correct network. One has the correct ip and is not properly connected, the other is as ip 0.0.0.0 but it shows as connected with good signal.
            Well I can't get to 0.0.0.0 with my browser but I can get to the correct ip number where I get a picture similar to what I should see but greyed out and it's trying to connect but can't.
            I tried giving the ip number in the M587 command in quotation marks and that was a no go (invalid IP number) and then tried the same with no quotation marks and duet accepted that.
            I now get the proper ssid and the proper IP number when I give the M587 command but I still have two entries in my router for connected clients. I have no idea what's going on or how this could happen.
            My next kick at the cat will be to try forgetting everything and then re-entering the ssid and password .
            • jens55undefined
              jens55
              Everything erased and re-entered. Wifi shut down to erase the 0.0.0.0 entry. Wifi brought back up and confirmed all entries for the duet are gone.
              As soon as I turned on power to the duet, both ip numbers show up with 0.0.0.0 being the connected ip address and the 192.168.xxx.xxx being the not connected number. When I direct the browser to 192.168.xxx.xxx, I get the right web screen but the console tells me "failed to connect to 192.168.xxx.xxx"
                A Former User
                At this point in time I'd try flashing RRF2 joining the network and going back to RRF3 if it works tbh. If it doesn't work I'd be tempted to try connecting to the ESP8266 and using esptool.py from the computer and erasing the whole flash before updating it with M997
                oh, and thanks for seting the record straight about the qoutes, I never actually tried it myself come to think of it.
                  btw, is this on your wifi ruter or using m587 on the duet?
                    Have you tried the macro method yet?
                    On occasion where I've had issues with the wifi I have created a couple macros to help simplify the process of clearing and re-adding the network. I use a dedicated old wifi router for the printer network as a simple access point. The main router provides a DHCP reservation for the printer, so I don't have to set an IP on the DUET.
                    I have a PanelDue so I can run them from there, but you can execute them via USB terminal as well with M98 P.
                    ; WifiReset.g
                    ; Use in case wifi module is not running. (Blue light off)
                    M291 R"Reset wifi module? Y/N" P"Caution. Will cause pause in print" S3 T10
                    M552 S0			; Disable network module
                    G4 S5			; wait 5 seconds
                    M552 S1			; Enable network module
                    M291 P"Wifi module reset. Check console or DWC."
                    ;WifiClear.g
                    ; Clear all wifi networks
                    M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10
                    M588 S"*"			; Clear all saved wifi networls
                    M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
                    ; WifiAdd.g
                    ; Add default wifi network
                    M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
                    M587 S"duetwifi" P"password"			; Add duetwifi SSID to remembered networks list
                    M552 S1			; reenable wifi module
                    M291 R"duetwifi SSID added." P"Check console to verify IP address."
                    Works every time I've had an issue.
                    • jens55undefined
                      jens55
                      Yes, the connected clients thing is on my router and the M587 was done via the usb serial link.
                      On reflection, I think that the static IP that shows as not connected on the router is a reflection of the static IP being set up and the 0.0.0.0 ip is somehow done via the duet.
                      I am now thinking that maybe DHCP isn't properly set up on the duet and I will be exploring that. I will also read up and follow initial setup instructions and see if I missed something there. I had no issues with the initial setup so it's difficult to understand why I am having the issues now. I also don't understand why I would see a perfectly good duet web page in my browser when there is no connection (and I doubt anything is cached because these are new IP numbers)
                      I do have a memory card sitting here with my old RRF2 version and I did try that in between with no luck.
                      I have not tried the macro approach yet but will try that if the DHCP investigation doesn't get me anywhere.
                        The main benefit of the macro approach is that it completely removes any special character shenanigans over the terminal. And the convenience I suppose.
                          you need to actually flash RRF2 to the Duet not just change sd cards btw.
                          • jens55undefined
                            jens55
                            Well ...... over the terminal I did a M552 S0 got the right reply and followed it up with M552 S1 and got a "connected"message
                            The router still shows IP 0.0.0.0 connected (with the right mac id) and a 192.168.xxx.xxx not connected (same mac id)
                            Ran a "home all" on the web interface and it did exactly what it was supposed to do.
                            So at this point I have a printer that seems connected, reported connected but isn't properly shown as connected on the router.
                            I haven't got the foggiest what I did to make it connect that is any different from what I did before other than the dwells were longer than the 1 second because I did it by hand over the terminal.
                            If nothing else, there is progress of sorts 🙂
                            Thanks for helping me resolve the connectivity issue. I will have to work on this some more to see if I can figure out what is going on.
                            • jens55undefined
                              jens55 @A Former User
                              @bearer said in Can't access wifi:
                              Never did that ....
                              • jens55undefined
                                jens55
                                Why do I need to flash RRF2 rather than change the memory card from a previously running RRF2 setup? (other than to maybe deal with the remembered wifi stuff)
                                • jens55undefined
                                  jens55 @Phaedrux
                                  @Phaedrux said in Can't access wifi:
                                  I think I will set up the same macros for the next time (because there ALWAYS is a next time ) 😞
                                    droftarts administrators @jens55
                                    @jens55 what router is it that you have? Did you eventually save the SSID and password with, or without, I0.0.0.0 parameter set? Setting that shouldn’t be necessary, but if there’s a bug in the firmware, I’d guess it’ll be that it’s doing something odd with the 0.0.0.0 IP address, which is why you get that reported on the router. Then the router is doing some address mapping/translation to make it accessible.
                                      first of all, you don't have to - but in order to try and see if there is a difference between RRF2 and RRF3 its not sufficient to just swap memory cards as the firmware is flashed to the MCU regardless of memory card.
                                      the thinking is I know it works on RRF2, if RRF2 can store it properly in the WiFi module it should continiue working if you upgrade the MCU back to RRF3.
                                      I got sidetracked with unexpected stuff othrewise I'd test it with RRF3 now.
                                      • jens55undefined
                                        jens55
                                        It is a new Pepwave Surf Soho, an enterprise grade router.
                                        I have the ssid and password set with no ip given however when I look at what the wifi radio remembers, it has the 0.0.0.0 ip set ... but that is always set like that because in theory that means 'use DHCP'.
                                        The router is not set up to do any translating or anything. On top of that I have removed the static IP reservation from the router and the duet still connects to the same IP number although DHCP should give a completely different IP.
                                        This could be related to the DHCP lease time and I have reduced that to an hour but it will take some time until it updates things.
                                        • jens55undefined
                                          Got it .... didn't realize that the mcu itself was flashed. Thanks!
                                            what do you actually have in your config.g right now?
