12V on the 5V rail
2.9k
    Haggan90 @A Former User
    @bearer Yeah, that's what I tought.. Could it be fixed if I just replaced U2? 😃
    What does U2 do?
    ? 1 Reply Last reply 20 Mar 2020, 18:29 Reply Quote 0
      A Former User @Haggan90
      @Haggan90 said in 12V on the 5V rail:
      Theoretically. It provides 3.3v to the system. U11 / 74HCT02 drives the heater mosfets. But there could be more damage as well. I'd remove U2 and apply an external, preferably current limited supply to test.
      undefined 1 Reply Last reply 20 Mar 2020, 18:39 Reply Quote 0
        @bearer Ok!
        I've removed U2, where can I connect 3.3V and what should I set the current limit to? 😃
        Btw, I tried the SD card and it seems to work fine.
        ? 1 Reply Last reply 20 Mar 2020, 21:01 Reply Quote 0
          A current limit of 200mA should be enough if nothing else is damaged, until you turn the WiFi module on. With WiFi on you may need 600mA.
            i've found that making a cable to connect to CONN_SD gives me convenient access to gnd, 3v3 and 5v connections. You can use single du-pont style wires as well. In general you can use any 3.3v pin shown on the wiring diagram. as dc42 said, 200mA is a good starting point; if it goes into current limiting mode try 300mA but if it takes more than a second or two to charge up capacitors and start up then start looking for what gets warm.
              zapta @Haggan90
              @Haggan90, you can find the duet wifi schematics in the link below. It may help you understand what's is going on.
              https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04
                You can feed the 3.3V into any endstop connector.
                undefined 1 Reply Last reply 21 Mar 2020, 21:53 Reply Quote 0
                  Haggan90 @dc42
                  @dc42 I connected 3.3V and nothing got hot.
                  When I connected USB I got 4.4V in the 3.3V rail...
                  ? undefined 2 Replies Last reply 21 Mar 2020, 22:55 Reply Quote 0
                    after removing the 3.3v volt regulator? strange, please post a picture of the board?
                    undefined 1 Reply Last reply 22 Mar 2020, 06:32 Reply Quote 0
                      @bearer I connected 3.3V to where the regulater output was.
                        dc42 administrators @Haggan90
                        Remove the other blown chip too.
                        undefined 1 Reply Last reply 22 Mar 2020, 07:33 Reply Quote 0
                          Haggan90 @dc42
                          @dc42 You mean the U11 / 74HCT02?
                          undefined 1 Reply Last reply 22 Mar 2020, 09:44 Reply Quote 0
                            Yes.
                            undefined 2 Replies Last reply 22 Mar 2020, 12:29 Reply Quote 0
                              Haggan90 @dc42
                              @dc42 aha ok! I have to do that at work where we have a hot air solder gun
                                Haggan90 @dc42
                                @dc42 Hi!
                                Sorry for taking such long time for this, but now I have manage to replace the U2 and U11.
                                When I connect the Duet to USB I get a warning of high current cunsumtion on the USB port, and U2 get's really hot.
                                Do you have any slightest idea of what else could be broken?
                                  What else is getting hot? Start by checking the processor, SD card (if it is in the socket), and WiFi module.
                                  Are you certain that you used the correct chip to replace U2? Different hardware versions of the Duet WiFi use different chips in that position.
                                  undefined 1 Reply Last reply 26 Apr 2020, 08:25 Reply Quote 0
                                    Haggan90 @dc42
                                    @dc42 hi!
                                    As far as I can nothing else get's hit then the U2. Here are the new components.
                                      What part number did you use for the 3.3V regulator, and what hardware revision Duet board is it? I think you may have used the wrong regulator.
                                      undefined 1 Reply Last reply 27 Apr 2020, 06:02 Reply Quote 0
                                        Haggan90 @dc42
                                        @dc42 Hi,
                                        As voltage regulator I used a: AP7361C-33E-13
                                        And as the U11 mosfet driver I used a : SN74HCT02PWR
                                          A Former User
                                          looks like the board is a revision 1.03 board that uses a TC2117 which is not compatible with AP7361C-33E-13 but should could be compatible with AP7361C-33ER-13
                                          undefined ? 2 Replies Last reply 27 Apr 2020, 06:25 Reply Quote 0
