    Flying extruder with 4th axis
    Firmware developers
    13
    100
    10.8k
      See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Adding_additional_towers_to_carry_flying_extruders. Your config.g command doesn't have the M669 command.
      • anderundefined
        ander
        Hi there
        Thanks for the help, i saw i had some errors so i changed them and the new axis seems to work fine even with lateral compensations, But i still have to fix one last thing so the printer can start printing, and this is the Z probe situation. I feel a bit confused with this thing in the firmware 3.0.
        Being a delta printer has 3 axis ( X,Y,Z) and then it has an effector with a mecanical switch on it similar to the atom delta 3d printer.
        The new axis(U) endstop is conected to E0 endstop pin, and the effector´s Z probe is conected to E1 endstop pin.
        Here i put my config file and bed file.config(2).g bed.g
        After finishing the entire configuration i will post the finished config file so others can use it
        thanks
          As you are running RRF3 I suggest you change your M558 command to this:
          M558 P5 C"e1stop" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
          Use either P5 (filtered) or P8 (unfiltered). The command as shown is for a normally-close switch. If your switch is normally open (not recommended) then use C"!e1stop" instead.
          • anderundefined
            ander
            Hi there
            thanks for all the help, the printer looks that works fine, now time to create some macro´s etc.
            For those who want to replicate this setup i will leave here my config file so you can copy.
            It is currently running on a duet wifi and firmware 3.0
            config (2).g
            • anderundefined
              ander
              Hello everyone
              The 4th axis delta is running but i noticed an issue and i don´t know how to solve it.
              To put everyone in context, we are running a delta printer on a duet wifi using firmware 3.0. the printer has an aditional axis for the flying extruder (see picture).
              The issue is that the non printing moving speed is very low, i can increase the speed in simplify 3d up to 400mm/s (currently set at 200mm/s), and you notice no difference.
              Even homing speed is very slow, and i noticed that if i push the endstop of the aditional tower by hand when homing, the rest of the motors speed up inmediately, so i looks like it is related to the aditional axis.
              i will put the config file and homing file so you can please give me a hand.
              Thanks1583396013208-whatsapp-image-2020-03-05-at-08.51.18.jpeg config (3).ghomedelta.g
                I don't see your config.g file.
                I suggest you change your homedelta.g file as follows:
                ; homedelta.g
                ; called to home all towers on a delta printer
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 27 2020 08:16:33 GMT+0100 (hora estándar de Europa central)
                G91   ; relative positioning
                M584 P4
                G1 H1 X833 Y833 Z833 U833 F5000 ; move all towers to the high end stopping at the endstops (first pass)
                G1 H2 X-5 Y-5 Z-5 U-5 F4800    ; go down a few mm
                G1 H1 X10 Y10 Z10 U10 F360     ; move all towers up once more (second pass)
                M584 P3
                G1 Z-5 F600               ; move down a few mm so that the nozzle can be centred
                G90                        ; absolute positioning
                G1 X0 Y0 F6000             ; move X+Y to the centre
                Added M584 P3 line, and removed the U parameter from the following G1 command.
                • anderundefined
                  ander
                  I don´t know why but the config file was on the right of the picture i sent.
                  i just removed the U parameters in the home section, and the u axis doesn´t go back home anymore
                  config (3).g
                    dc42 administrators @ander
                    @ander said in Flying extruder with 4th axis:
                    That isn't what I suggested. Read my reply again.
                    • anderundefined
                      ander
                      Sorry i missunderstood. i made the change you suggested and still makes non printing moves very slow
                        We do not advise running at x256 microstepping. Change to x16 with interpolation, adjust the M92 steps/mm accordingly, and try again.
                        • anderundefined
                          ander
                          It worked very well!
                          Thanks for the excelent service!!
