3Dtouch doesn't respond properly on M280 S160 command
Now I can't make work it properly at all. Bouncing during the probing, falling of the pin, false reading etc etc.
Ok I have all 3 my sensor clones, but I can't believe its are all broken or damaged.
Could I have damaged the duex5/duet2wifi connecting a 3dtouch without the "logic trace 5v" cutted?
How can I check my board? for example the 5V output on h7 pwm that I use is 4,9v, Can be poor as voltage? -
I have tested it with an external 5v supply , but it doesn't work anyway.I has Erased the firmware at all and installed the new one from zero but I had no luck. I have added the resistor of 240ohm on parallel on signal, no change.What can I check other? Could be changed the frequency of the pwm? How can I check it? What is the frequency of the pwm on duet2?
@sirkris said in 3Dtouch doesn't respond properly on M280 S160 command:
Unlikely.
When you've tested all your 3 probes, have you tested with the same wiring harness?
@Phaedrux No, I had wired the 3 probes directly on the duex5 and also on the duet2wifi to test its. No additional wiring that can give problems.
How can check eventuals damages? I had test several pwm channels and they work the same. -
Did you make changes to your config when connected to the Duex versus the Duet?
@Phaedrux Yes, of course I added I1 into m280 commands to invert polarity
Not sure what else to tell you. If the wiring is correct and the config is correct that leaves the probe itself. Is it possible to get a real bltouch to test with?
@Phaedrux said in 3Dtouch doesn't respond properly on M280 S160 command:
No alas.
How can I check my duet?
Can I find out the frequency which is operating actually on the pwm?
I want exclude that possibility. -
Some multimeters have a Hz setting.
@dc42 said in 3Dtouch doesn't respond properly on M280 S160 command:
Ok, I have got a multimeters with Hz probing.
I have executed a probe test on fan P0 and it changes the frequency.
I have tested it with the fan connected (because if disconnected it probes nothing), probe between ground and pwm channel.
If I send M106 P0 S0.5 Fxx I can probe xx frequency.
By the way I cannot probe the channel of the 3dtouch (H7 on duex5).
It seems always 50Hz.
Which are the right command that I have to send?
I have tried to use:
M307 H7 A-1 C-1 D-1 into override config
and without it:
;M307 H7 A-1 C-1 D-1
sending after several commands as
M106 P7 S0.5 Fxx
It is right or I'm doing something wrong to test it?
Best regards
