    Issues with dual extrusion and Prusaslicer with Duet 2
    2.1k
    • Turboundefined
      Turbo
      currently i have not tried a dual extrusion print, i'm just working on using the "secondary" extruder, and not the default. I set the printed piece to extruder 2.
      Cant stop tuning wont stop tuning.
      Dbot, Custom i3, Voron 0&2
      • Danalundefined
        Danal @Turbo
        @Turbo said in Issues with dual extrusion and Prusaslicer with Duet 2:
        Got it. That should also work...
        What do you get that is the dual version of this:
        M190 S60 ; set bed temperature and wait for it to be reached
        M104 S215 T0 ; set temperature
        M104 S215 T1 ; set temperature
        M109 S215 T0 ; set temperature and wait for it to be reached
        M109 S215 T1 ; set temperature and wait for it to be reached
        Turboundefined 1 Reply Last reply Reply Quote 0
        • Turboundefined
          Turbo @Danal
          @Danal generating the gcode for mine shows it doesn's define a tool in the m104 codes. /could that be it? i dont want to have to manually change the start gcode every time i change extruders, as i have one .4 nozzle and one .5 nozzle.
          the start gcode should still be handling temps correct?
          ; generated by PrusaSlicer 2.2.0+win64 on 2020-03-29 at 19:11:58 UTC
          ; external perimeters extrusion width = 0.56mm
          ; perimeters extrusion width = 0.56mm
          ; infill extrusion width = 0.56mm
          ; solid infill extrusion width = 0.56mm
          ; top infill extrusion width = 0.50mm
          ; first layer extrusion width = 0.60mm
          M107
          M280 P3 S160 I1 ; Alarm Release and Push-Pin UP
          M572 D0 S0.8
          M572 D1 S0.8
          ;Pressure Advance M572
          ; D# = Extruder #
          ; S = K Value (0.2 is start point tune up or down from there (current bowden length about 600mm))
          ;M104 S210 ; set extruder temp
          M140 S60 ; set bed temp
             T1 ; temp fix
             G10 P1 S210 ; temp fix
          M190 S60 ; wait for bed temp
          M109 S210 ; wait for extruder temp
          G28 ; Home Printer
          G29 ; run bed compensation script
          G1 X10 Y10 Z0.3 F3600 ; Move to front left corner
          G92 E0 ; zero extruded length
          G1 E10 F300 ; purge blob
          G1 X10 Y110 E20 F1800 ; purge line
          G1 E-2 F800;
          ;End of Start.gcode
          G21 ; set units to millimeters
          G90 ; use absolute coordinates
          M83 ; use relative distances for extrusion
          T1
          ; Filament gcode
          G1 Z0.300 F15000.000
          G1 E-2.40000 F1200.00000
          G1 X132.692 Y77.794 F15000.000
          G1 E2.40000 F1200.00000
          G1 F1800.000
          • Danalundefined
            Danal
            I just tried a single STL, with the extruder "overriden" as shown below. It properly generated everything for Tool1 (Toll 0 is the first, Tool 1 the second, etc). In particular:
            M107
            T1
            I take it that is not what you are seeing?
            • Turboundefined
              Turbo @Danal
              @Danal correct. No Tool defining in the gcode for the temps, unless i add it manually. Is your temp gcode part of your start gcode or is it auto generated?
              • Danalundefined
                Danal
                It shows up. My "start gcode" box on the printer settings tab is blank.
                How are you 'convincing' the slicer to print the one STL on the second extruder? Same as the screenshot above?
                • Turboundefined
                  Turbo @Danal
                  @Danal Yep. although i think you just helped me solve it. you have no temps in the start gcode? thats where mine differs. ill try removing it and see what happens
                  • Danalundefined
                    Danal
                    I don't see a set bed temp in your gcode either. Is it further down?
                    M190
                    • Turboundefined
                      Turbo @Danal
                      @Danal line 26 has bed temp
                      • Danalundefined
                        Danal
                        Got it. I just missed it with my eye, somehow.
                        Hmmm.... Let me upgrade to the latest release, I'm on 2.0.0 right now. Be a min or two...
                        • Turboundefined
                          Turbo
                          Okay so deleting The temps from the start gcode solved it I believe. I have a print running right now, but ill try it afterwards, but the gcode reflects the fix.
                          • Danalundefined
                            Danal
                            Good. I'm still going to install 2.2, just because 🙂
                            Turboundefined 1 Reply Last reply Reply Quote 1
                            • Turboundefined
                              Turbo @Danal
                              @Danal Okay so deleting it kinda fixed it but not really. It does auto add the code for the tool requested, but will try to print before the extruder is up to temp. I dont know why.
                              • Turboundefined
                                Turbo
                                adding an M109 S[first_layer_temperature] cause it to heat up the wrong extruder
                                • Turboundefined
                                  Turbo
                                  Adding an M116 seems to have done the trick, however, i get an error message saying that tool 0 didnt move because it never got up to temp, possibly because it is set as active by default (although im not using is to why even prompt me?), and the second extruder only gets set to active when the standalone T1 command is executed in gcode. I would leave it, but i dont want an error message every print, as it concerns me.
                                  • Danalundefined
                                    Danal
                                    Waiting for the tool is not up to the slicer. Be sure you have a "M116 H2 " near the beginning of your
                                    /sys/tpost1.g
                                    file. Actually tpost0.g and tpost1.g
                                    If you don't have those files, create them.
                                    • Turboundefined
                                      Turbo @Danal
                                      @Danal
                                      M116 H1 in the tpost0 and H2 in tpost1 as they refer to heater number, or h2 in both?
                                      • Danalundefined
                                        Danal @Turbo
                                        @Danal
                                        Heater number. Which, in my config, is Tool Number + 1. Because H0 is bed.
                                        • Turboundefined
                                          Turbo @Danal
                                          @Danal After including that, nothing seems to have changed. when it goes to start the purge line i configured in the start gcode, it doesnt extrude because its not up to temp, defeating the purpose
                                          Danalundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                          • Danalundefined
                                            Danal @Turbo
                                            It should be waiting on that line in the toolchange macro. You may need a T-1 (unmount all tools) in the startup.
