    Mirrored X axis
    mirrored
    856
      Can you post your config files and homing files?
      There have been a few other posts about the FT5 such as this one. The confusion arises from the fact it uses the back right as the 0,0 point rather than the front left.
      Take a look at these posts: https://forum.duet3d.com/search?term=ft5&in=titlesposts
      Grace Dertundefined 1 Reply Last reply Reply Quote 0
      • Grace Dertundefined
        Grace Dert @Phaedrux
        config.g
        ;; Folgertech FT5 Configuration
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P2 ; Set firmware compatibility to look like Marlin
        M208 X305 Y304 Z410 S0 ; Set axis maxima
        M574 Y2 X2 Z0 S0 ; Define active high microswitches
        M558 P5 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type for BLTouch
        G31 P50 X-20.00 Y0 Z1.50 ; Set Z probe trigger value, offset and trigger height
        M584 X0 Y1:4 Z2 E3 ; Map to specific drives
        M569 P0 S1 ; Drive 0 - X
        M569 P1 S1 ; Drive 1 - Y
        M569 P2 S1 ; Drive 2 - Z
        M569 P3 S1 ; Drive 3 - E0
        M569 P4 S1 ; Drive 4 - Y
        M92 X80 Y80 Z399 E492.45 ; Set steps per mm
        M566 X1200 Y1200 Z60 E120 ; Set maximum instantaneous speed changes (mm/min)
        M203 X8000 Y8000 Z600 E1200 ; Set maximum speeds (mm/min)
        M201 X1500 Y1500 Z500 E250 ; Set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1200 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M143 S260 ; Set maximum heater temperature to 260C
        M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heated bed (Heater 0)
        M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for E0 (Heater 1)
        M307 H0 A281.7 C430.4 D4.4 B0 ; Bed PID
        M307 H1 A344.7 C122.8 D5.5 B0 ; Hotend PID
        M307 H3 A-1 C-1 D-1 ; BLTouch
        M563 P0 D0 H1 ; Define tool 0
        G10 P0 X0 Y0 ; Set tool 0 axis offsets
        M550 PGraceFT5 ; Set machine name
        M552 P192.168.1.12 S1 ; Enable network and acquire dynamic address via DHCP
        M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S255 I0 F500 H1 T50 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S255 I0 F500 H1 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        T0 ; Select first tool
        homeall
        ; /sys/homeall.g
        G28 X ; home X
        G28 Y ; home Y
        G28 Z ; home Z
          Grace Dert
          Currently my x and y home but go to 300 after hitting end stops and my z does not move at all. Sorry for the late response. Thanks for all the help so far!
            Phaedrux Moderator @Grace Dert
            @Grace-Dert said in Mirrored X axis:
            homeall
            ; /sys/homeall.g
            G28 X ; home X
            G28 Y ; home Y
            G28 Z ; home Z
            We're gonna need to see all the homing files.
            In general, here's what you need to do to define your coordinate system. The FT5 is a little tricky because by default it puts the origin at the rear right, and has some printed grid on the bed surface (I think?) but really it's all arbitrary.
            First, choose a FRONT for the printer so that when you're looking at it standing in front of it 0,0 is the front left corner, X+ goes to the right, Y+ goes to the back. This does not change because it's describing the physical layout of the printer.
            Next, Measure the axis length for X and Y and enter that in your M208 command to set the axis limits. 0 at the low end (or even negative if the head leaves the bed surface to hit the endstop). This does not change because it's describing the physical layout of the printer.
            Now identify where your endstops are located. They can be at the low or high end of the axis. Define them with M574. M574 X1 Y1 for low side, M574 X2 Y2 for high side, or any combo thereof. This does not change because it's describing the physical layout of the printer.
            Now setup your homing movements. If the endstop is at the low end of the axis, the homing move must be negative. And vice versa. This does not change because it's describing the physical layout of the printer.
            Now test the motor movement direction. using this page: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
            If X+ moves to the right, you're good to go. If it moves left, you need to change the motor rotation for the X driver by changing the M569 S0/S1 command in config.g. Same goes for Y+ moving to the back. If you've connected the motors to their default drivers, it should be mapped like this:
            M569 P0 S0                                         	; Drive 0 (x) goes backwards
            M569 P1 S0                                         	; Drive 1 (y) goes backwards
            M569 P2 S0                                         	; Drive 2 (z) goes backwards
            M569 P3 S0                                         	; Drive 3 (e) goes backwards
            If you follow those steps your printed parts will match the orientation in the slicer and won't be mirrored.
            I think what has happened is that you moved the endstop but didn't change the M574 command to match.
            Grace Dertundefined 1 Reply Last reply Reply Quote 1
              @Phaedrux
              Home x
              ; /sys/homex.g
              M402 ; make sure the probe is retracted
              G1 X310 F5000 S1 ; move quickly to X axis endstop and stop there (first pass)
              G91 ; relative moves
              G1 X-5 F6000 ; go back a 5mm
              G90 ; absolute moves
              M400 ; wait for the move to complete
              G1 X310 F360 S1 ; move slowly to X axis endstop once more (second pass)
              Home y
              ; /sys/homey.g
              G1 Y310 F6000 S1 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y-5 F6000 ; go back a 5mm
              G1 Y310 F360 S1 ; move slowly to Y axis endstop once more (second pass)
              Home z
              ; /sys/homez.g
              M280 P3 S160 I1 ; reset gcode for bltouch
              M400 ; wait for reset to complete
              M558 F300 ; set probe speed to 300mm/min
              G1 Z10 F8000 ; move bed down 10mm
              G1 X300 Y300 F8000 ; move to probe position
              M401 ; deploy probe
              G30 ; probe
              M402 ; retect probe
              G1 Z4 F8000 ; move bed down 4mm
              M558 F80 ; set probe speed to 80mm/min
              M401 ; deploy probe
              G30 ; probe
              M402 ; retract probe
              M558 F200 ; set probe speed to 300mm/min
                Grace Dert
                So I currently got my x and y homing but I just want to check and see if I did it right if you don't mind. However my z axis is not moving at all which is odd...
                Config
                M208 X300 Y300 Z300 S0 ; Set axis maxima
                M574 X2 Y2 Z1 S0 ; Define active high microswitches
                ;M558 P5 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type for BLTouch
                ;G31 P50 X-20.00 Y0 Z1.50 ; Set Z probe trigger value, offset and trigger height
                M569 P3 S0 ; Drive 3 - E0
                ;M569 P4 S1 ; Drive 4 - Y
                home x
                G1 X300 F5000 S1 ; move quickly to X axis endstop and stop there (first pass)
                G1 X300 F360 S1 ; move slowly to X axis endstop once more (second pass)
                home y
                G1 Y300 F6000 S1 ; move quickly to Y axis endstop and stop there (first pass)
                G1 Y300 F360 S1 ; move slowly to Y axis endstop once more (second pass)
                  Grace Dert
                  So I think I fixed everything! Maybe... everything homes now and so far doesn't appear mirrored. Thanks so much for the help so far!
                  Home x
                  Home y
                  Home z
                  G1 Z-300 F5000 S1 ; move quickly to X axis endstop and stop there (first pass)
                  G1 Z5 F6000 ; go back a 5mm
                  G1 Z-300 F360 S1 ; move slowly to X axis endstop once more (second pass)
                  Config
                  M574 X2 Y2 Z0 S0 ; Define active high microswitches
                  M569 P2 S0 ; Drive 2 - Z
                  M906 X1000 Y1000 Z1000 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M552 P192.168.1.14 S1 ; Enable network and acquire dynamic address via DHCP
                    M401 ; deploy probe
                    G30 ; probe
                    M402 ; retect probe
                    Are you using an endstop or a z probe to home the Z axis?
                      @Phaedrux endstop
                        In that case you should change that Z0 to Z1 (assuming it's a zmin endstop). Z0 means no endstop configured.
