    Webserver won't start
    Duet Web Control
    2.9k
      A Former User
      With the risk of repeating myself, its not a config issue if it doesn't work with the SD card removed.
      • Dougal1957undefined
        Dougal1957 @A Former User
        @bearer I think you'll find that the duet won't come up at all without an SD Card inserted but I am prepared to be proved wrong
          A Former User @Dougal1957
          @Dougal1957 said in Webserver won't start:
          @bearer said in Webserver won't start:
          @droftarts I think his config is the one from his WiFi first post says he swapped them over it's one of those little things that catch us all out from time to time!
          see my post https://forum.duet3d.com/post/142097 Duet2Ethernet, no SD card, only send M552 S1 gets IP from DHCP server no problem. M552 P0.0.0.0 S1 will also work, but isn't needed unless to override a stored static IP for a Wifi network afaik.
          there you go; proven wrong. (i.e. the whole session from the serial terminal is shown, M552 is send over serial to rule out other config issues)
            droftarts administrators @Haffwalker
            @Haffwalker At some point you changed from 3.01-RC5, which got an IP address, to 3.0, which doesn't. At what point did you also disconnect the TL-WR802N?
            Just for completeness, can you downgrade to 2.05.1, and try connecting again, without SD card?
            Haffwalkerundefined 2 Replies Last reply Reply Quote 0
              @bearer I Stand corrected I know that wouldn't work several years back.
              • Haffwalkerundefined
                Haffwalker @droftarts
                @droftarts I will downgrade to 2.05.1 now, will let you know how if it works.
                  Haffwalker
                  Didn´t help...
                    @droftarts During my initial setup everything seemed to work nicely - duet got an IP and dwc was working. Then I unplugged everything - put it into the printer/attached cables and when I powered it up, it didnt work anymore. After that I got rid of the WR802N and connected it directly with my router and also I did downgrade from 3.01RC5 to RRF3.0 and now 2.05.
                      A Former User
                      I'm a little curious why mine said "No SD card detected" at boot but yours didn't.
                      Can you also run M503 and M20 before anything else when starting up just for good measure?
                      Haffwalkerundefined 1 Reply Last reply Reply Quote 0
                        Haffwalker @A Former User
                        @bearer Sure.
                        Downgrading to 2.04 didnt help neither
                          Haffwalker
                          Now with M503 and M20:
                            A Former User
                            Well, that proves there isn't any conflicting config despite the lacking message about missing SD card*. I'm at the end of the line unless you can capture the traffic with wireshark as outlined above. (also, you can skip the M111 command, it doesn't seem to produce any relevent debug info in this scenario)
                            *) never mind I see now the version information isn't from the boot message, but from M115 - so any messages about missing SD cards were above that; and a moot point in any case now.
                              @Haffwalker I appreciate this is frustrating. Could you please test it with a different ethernet cable. Perhaps the one that connects the Duet to the TL-WR802N, if it's long enough, as this cable has been proven to work with the Duet.
                                Haffwalker
                                I downgraded to 2.01 - I think that was the firmware which was on the board when i bought it - still no change...
                                  @droftarts I unconnected everything to get it to my router and I used the cable which already was working, but still nothing changes in the behavior...
                                    @bearer About the wireshark traffic...do you have any source of explanation, which steps I have to take like a youtube video or something?
                                      A Former User @Haffwalker
                                      @Haffwalker said in Webserver won't start:
                                      its mostly down to equipment; a modern switched network won't send the packets to your computer unless they're adressed to your computer ... so to monitor traffic between your Duet and your router you'd need some fancy managed gear.
                                      Although, if you have a basic switch and can be bothered to set up a DHCP server on your computer that would work to diagnose the issue. A relatively simple DHCP server for windows is tfptd32 (or 64 whatever floats your boat).
                                      (you need the switch because you need to configure the computers interface with a static IP and start the DHCP server before connecting the Duet, and a such a direct connection won't work even though you're just connecting the computer and the duet to a basic switch)
                                        @Haffwalker Yes, I don't think this is a firmware issue. Thanks for trying the different ethernet lead. I'm just looking at the Duet 2 Ethernet I have here, particularly how easy it is to dislodge the ethernet module. It isn't!
                                          Dougal1957
                                          This may sound stupid but have you tried taking it back out of the printer and trying it again on the bench just to see if it could be a short somewhere?
                                          It's a long shot mind but it is all I can think of now.
                                            A Former User
                                            ..its not stupid when everything else doesnt work:)
