Webserver won't start
Is it possible, that when I erased the board, that any kind of firmware which is supposed to run on the ethernet module got deleted as well? Maybe I have to flash firmware on that thing too?
@Haffwalker I note you said you formatted the SD Card you did install all the Config files as well as the DWC Files didn't you?
Can you post your Config.g file from the SD Card
Doug
And my config.g looks like this:
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Jan 28 2020 00:41:51 GMT+0100 (Central European Standard Time); General preferences
M550 P"AKLP Plus+" ; set printer name
M665 R135.4 L267 B118 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M92 X80.00 Y80.00 Z80.00 E418.50 ; set steps per mm
M566 X250.00 Y250.00 Z800.00 E200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X2000.00 Y2000.00 Z2000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1100 Y1100 Z1100 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z-20 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P5 C"e0stop" H5 A3 F360 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z16.254 ; set Z probe trigger value, offset and trigger height
M557 R110 S19 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"fan0" ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"fan1" ; create fan 1 on pin fan1 and set its frequency Hotend Cooler
M106 P1 S127 H1 T50 ; set fan 1 value. Thermostatic control is turned on Hotend Cooler ab 50°C mit 12V; Tools
M563 P0 S"Hotend 1" D0 H1 F0 ; define tool 0
M501 ; load saved parameters from non-volatile memory -
@Haffwalker Reading through the thread, it doesn't seem that this is a Duet-related problem, I think more likely is that the TL-WR802N is blocking http requests to the Duet from the network. What settings are there to configure it?
To test the Duet, if you can move it to plug the ethernet directly into your main router, using a USB power adapter to power it, you should be able to access it.
Hi, yes I already took the WR802N out of the equation - the Duet is currently directly plugged into my router.
@droftarts I think his M552 line is wrong for an Ethernet version should it not have P0.0.0.0 to tell it to pick up an address via DHCP also not sure if you really need the S1 to enable it as well
@Haffwalker said in Webserver won't start:
The firmware relating to the network is part of the Duet's RepRap firmware which you have at v3.0, so no. As far as replacing the Ethernet module its a possibility, but I'd be surprised to see it make a difference.
To get to the bottom of whats going on we'd need something like a wireshark log of the traffic, which is a bit difficult to do without a bridge or managed switch with a mirror feature as far as I can tell.
I suppose you can as a last effort set up a static IP address on your computer using the same ethernet cable (and no wifi), then set up the Duet 2 Ethernet with the same address and see if it works to rule out issues with DHCP (but its such a simple, tried and true protocol that incompatibilities are rare)
@Dougal1957 said in Webserver won't start:
He's supposedly tried the Duet without the SD card and thus no config, using only M552 S1
Okay! Sorry, just catching up...
Quite right. M552 should be
M552 P0.0.0.0 S1
for DHCP, or for a fixed IP address, set the address using the P parameter.Ian
@droftarts I think his config is the one from his WiFi first post says he swapped them over it's one of those little things that catch us all out from time to time!
@droftarts said in Webserver won't start:
Quite right. M552 should be M552 P0.0.0.0 S1 for DHCP, or for a fixed IP address, set the address using the P parameter.
see my post https://forum.duet3d.com/post/142097 Duet2Ethernet, no SD card, only send
M552 S1
gets IP from DHCP server no problem.M552 P0.0.0.0 S1
will also work, but isn't needed unless to override a stored/configured static IP for aWifinetwork afaik. -
@Haffwalker what's in your Config-overide.g?
@Dougal1957 SD card isn't plugged in right now.
With the risk of repeating myself, its not a config issue if it doesn't work with the SD card removed.
@bearer I think you'll find that the duet won't come up at all without an SD Card inserted but I am prepared to be proved wrong
@bearer said in Webserver won't start:
M552 S1
will also work, but isn't needed unless to override a stored static IP for a Wifi network afaik.there you go; proven wrong. (i.e. the whole session from the serial terminal is shown, M552 is send over serial to rule out other config issues)
@Haffwalker At some point you changed from 3.01-RC5, which got an IP address, to 3.0, which doesn't. At what point did you also disconnect the TL-WR802N?
Just for completeness, can you downgrade to 2.05.1, and try connecting again, without SD card?
@bearer I Stand corrected I know that wouldn't work several years back.
@droftarts I will downgrade to 2.05.1 now, will let you know how if it works.
