    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.7k
      A Former User @tobias_munich
      @tobias_munich said in RepRapFirmware 3.01-RC6 released:
      seem DWC/DCS has problems connecting the DUET3 Board.
      verify the ribbon cable connecting the Duet and the SBC is installed correctly.
      verify the SPI drivers are loades ( ls /dev/spi*)
      check the logs for DCS (service duetcontrolserver status)
      edit: also, which SBC?
      tobias_munichundefined 1 Reply Last reply Reply Quote 0
      • tobias_munichundefined
        tobias_munich @A Former User
        @bearer it has run for weeks now. its not a new installation. will go deeper to understand the issue...
        Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
        Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
        Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
        • chrishammundefined
          chrishamm administrators
          RRF 3.01-RC6 is NOT compatible to DSF 1.2.x. If you want to give it a try, make sure you are on the unstable branch and if you can, do NOT upgrade the firmware manually. The provided reprapfirmware package updates it automatically.
          Duet software engineer
            @tobias_munich DWC is running otherwise you'd not get a web page, so issue is with DCS, logs are likely most relevant, checking the SPI drivers are just to dot the t's in case something external to the duet packages got updated to cause an issue
              tobias_munich @chrishamm
              @chrishamm seems that's my problem. will fix it..
              • Dougal1957undefined
                Dougal1957 @chrishamm
                @chrishamm Chris I have upgraded mine to 1.3 of DSF but when attempting to upgrade to RC6 I get a failure due to no IAP file
                Any advise
                	M122
                RepRapFirmware for Duet 3 MB6HC version 3.01-RC5 running on Duet 3 MB6HC v0.6 or 1.0
                Board ID: 08DGM-9T66A-G63SJ-6J1DA-3SD6R-TV0BA
                Used output buffers: 1 of 40 (5 max)
                Static ram: 154084
                Dynamic ram: 160892 of which 52 recycled
                Exception stack ram used: 216
                Never used ram: 77972
                Tasks: NETWORK(ready,2076) HEAT(blocked,1196) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,216) MAIN(running,4956) IDLE(ready,80)
                Owned mutexes:
                Last reset 124:09:52 ago, cause: software
                Last software reset at 2020-03-03 18:27, reason: User, spinning module LinuxInterface, available RAM 79528 bytes (slot 3)
                Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                Error status: 0
                Free file entries: 10
                MCU temperature: min 38.4, current 41.6, max 43.2
                Supply voltage: min 23.6, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                Driver 0: standstill, reads 1090, writes 14 timeouts 0, SG min/max 0/0
                Driver 1: standstill, reads 1090, writes 14 timeouts 0, SG min/max 0/0
                Driver 2: standstill, reads 1091, writes 14 timeouts 0, SG min/max 0/0
                Driver 3: standstill, reads 1091, writes 14 timeouts 0, SG min/max 0/0
                Driver 4: standstill, reads 1092, writes 14 timeouts 0, SG min/max 0/0
                Driver 5: standstill, reads 1092, writes 14 timeouts 0, SG min/max 0/0
                Date/time: 2020-04-03 13:26:07
                Slowest loop: 2.33ms; fastest: 0.14ms
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP* is ready with "M122" in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon* is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 0.80ms; fastest: 0.01ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                HTTP sessions: 0 of 8
                - Ethernet -
                State: disabled
                Error counts: 0 0 0 0 0
                === CAN ===
                Messages sent 1787965, longest wait 0ms for type 0
                === Linux interface ===
                State: 0, failed transfers: 2
                Last transfer: 16ms ago
                RX/TX seq numbers: 36774/40855
                SPI underruns 3, overruns 3
                Number of disconnects: 1
                Buffer RX/TX: 0/0-0
                === Duet Control Server ===
                Duet Control Server v1.3.0.0
                Code buffer space: 4096
                Full transfers per second: 32.88
                Doug
                dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                  @bearer said in ReprapFirmware 3.01-RC6 released:
                  Will future DWC releases like 2.1.0 retain full support for RRF2? At least until RRF3 goes mainstream perhaps? Couldn't see anything about compatibility except for 2.0.3 stated supporting 0.6/0.8.5 boards
                  That's unlikely. Future versions of DWC will provide features (e.g. the object cancellation interface) that are not supported by RRF2.
                  I expect RRF 3 to go "mainstream" shortly after RRF 3.01 stable is released. That release may be as little as a week away.
                    dc42 administrators @Dougal1957
                    @Dougal1957 said in RepRapFirmware 3.01-RC6 released:
                    That file should be included in the DSF release. I can provide it if necessary.
                      Dougal1957 @dc42
                      @dc42 please but it definitly fails and I have tried to do the Sudo Apt-get Update sequence twice as well I have appended the M122 log to my post above.
                      I will probably need simple instruction on what to do with the file mind.
                      Doug
                        chrishamm administrators @Dougal1957
                        @Dougal1957 Sorry, looks like like this file was missing in the RRF package, I've just added it back and uploaded it to another location: http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin You may need to rename it to Duet3iap_spi.bin.
                          A Former User
                          if the issue is stable/unstable package feed run grep duet3d -r /etc/aptto check and echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.listto fix if needed.
                          or what that guy said ☝
                          • chas2706undefined
                            chas2706
                            You M112 suggests you are running 3.01-RC5.
                              A Former User @chrishamm
                              @chrishamm said in RepRapFirmware 3.01-RC6 released:
                              To check, have a look at /etc/apt/sources.list.d/duet3d.list and make sure you have unstable instead of stable in there.
                              btw that conflicts with the wiki that says to create another file duet3d-unstable.list
                                Dougal1957 @chas2706
                                @chas2706 exactly the point the upgrade to rc6 is failing
                                  Dougal1957 @A Former User
                                  @bearer Defo on the Unstable branch
                                  pi@duet3:~ $ grep duet3d -r /etc/apt
                                  /etc/apt/sources.list.d/duet3d.list:deb https://pkg.duet3d.com/ stable armv7
                                  /etc/apt/sources.list.d/duet3d-unstable.list:deb https://pkg.duet3d.com/ unstable armv7
                                  Binary file /etc/apt/trusted.gpg.d/duet3d.gpg matches
                                  pi@duet3:~ $ echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                                  pi@duet3:~ $ sudo apt-get update
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Hit:3 https://pkg.duet3d.com unstable InRelease
                                  Hit:4 https://pkg.duet3d.com stable InRelease
                                  Reading package lists... Done
                                  pi@duet3:~ $
                                  Doug
                                  A Former User? chrishammundefined 2 Replies Last reply Reply Quote 0
                                    A Former User @Dougal1957
                                    yeah
                                    do wget http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin -O /opt/dsf/sd/sys/Duet3iap_spi.bin
                                      @Dougal1957 The stable list is still in there: sudo rm /etc/apt/sources.list.d/duet3d.list followed by sudo apt-get update should work for you
                                        is that a problem, more importantly, should it be a problem?
                                          @bearer that sorted it Thanks very much as you probably imagine I am not good with LINUX at all although I am learning some of it
                                            @Dougal1957 i only translated
                                            into copy/paste; and we all had to learn at some point
