    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.6k
    • tobias_munichundefined
      tobias_munich @chrishamm
      @chrishamm seems that's my problem. will fix it..
      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
      • Dougal1957undefined
        Dougal1957 @chrishamm
        @chrishamm Chris I have upgraded mine to 1.3 of DSF but when attempting to upgrade to RC6 I get a failure due to no IAP file
        Any advise
        	M122
        RepRapFirmware for Duet 3 MB6HC version 3.01-RC5 running on Duet 3 MB6HC v0.6 or 1.0
        Board ID: 08DGM-9T66A-G63SJ-6J1DA-3SD6R-TV0BA
        Used output buffers: 1 of 40 (5 max)
        Static ram: 154084
        Dynamic ram: 160892 of which 52 recycled
        Exception stack ram used: 216
        Never used ram: 77972
        Tasks: NETWORK(ready,2076) HEAT(blocked,1196) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,216) MAIN(running,4956) IDLE(ready,80)
        Owned mutexes:
        Last reset 124:09:52 ago, cause: software
        Last software reset at 2020-03-03 18:27, reason: User, spinning module LinuxInterface, available RAM 79528 bytes (slot 3)
        Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 10
        MCU temperature: min 38.4, current 41.6, max 43.2
        Supply voltage: min 23.6, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
        Driver 0: standstill, reads 1090, writes 14 timeouts 0, SG min/max 0/0
        Driver 1: standstill, reads 1090, writes 14 timeouts 0, SG min/max 0/0
        Driver 2: standstill, reads 1091, writes 14 timeouts 0, SG min/max 0/0
        Driver 3: standstill, reads 1091, writes 14 timeouts 0, SG min/max 0/0
        Driver 4: standstill, reads 1092, writes 14 timeouts 0, SG min/max 0/0
        Driver 5: standstill, reads 1092, writes 14 timeouts 0, SG min/max 0/0
        Date/time: 2020-04-03 13:26:07
        Slowest loop: 2.33ms; fastest: 0.14ms
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP* is ready with "M122" in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon* is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 0.80ms; fastest: 0.01ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
        HTTP sessions: 0 of 8
        - Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 1787965, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 2
        Last transfer: 16ms ago
        RX/TX seq numbers: 36774/40855
        SPI underruns 3, overruns 3
        Number of disconnects: 1
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v1.3.0.0
        Code buffer space: 4096
        Full transfers per second: 32.88
        Doug
        dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
          @bearer said in ReprapFirmware 3.01-RC6 released:
          Will future DWC releases like 2.1.0 retain full support for RRF2? At least until RRF3 goes mainstream perhaps? Couldn't see anything about compatibility except for 2.0.3 stated supporting 0.6/0.8.5 boards
          That's unlikely. Future versions of DWC will provide features (e.g. the object cancellation interface) that are not supported by RRF2.
          I expect RRF 3 to go "mainstream" shortly after RRF 3.01 stable is released. That release may be as little as a week away.
            dc42 administrators @Dougal1957
            @Dougal1957 said in RepRapFirmware 3.01-RC6 released:
            That file should be included in the DSF release. I can provide it if necessary.
              Dougal1957 @dc42
              @dc42 please but it definitly fails and I have tried to do the Sudo Apt-get Update sequence twice as well I have appended the M122 log to my post above.
              I will probably need simple instruction on what to do with the file mind.
              Doug
              • chrishammundefined
                chrishamm administrators @Dougal1957
                @Dougal1957 Sorry, looks like like this file was missing in the RRF package, I've just added it back and uploaded it to another location: http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin You may need to rename it to Duet3iap_spi.bin.
                Duet software engineer
                  A Former User
                  if the issue is stable/unstable package feed run grep duet3d -r /etc/aptto check and echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.listto fix if needed.
                  or what that guy said ☝
                  • chas2706undefined
                    chas2706
                    You M112 suggests you are running 3.01-RC5.
                      A Former User @chrishamm
                      @chrishamm said in RepRapFirmware 3.01-RC6 released:
                      To check, have a look at /etc/apt/sources.list.d/duet3d.list and make sure you have unstable instead of stable in there.
                      btw that conflicts with the wiki that says to create another file duet3d-unstable.list
                        Dougal1957 @chas2706
                        @chas2706 exactly the point the upgrade to rc6 is failing
                          Dougal1957 @A Former User
                          @bearer Defo on the Unstable branch
                          pi@duet3:~ $ grep duet3d -r /etc/apt
                          /etc/apt/sources.list.d/duet3d.list:deb https://pkg.duet3d.com/ stable armv7
                          /etc/apt/sources.list.d/duet3d-unstable.list:deb https://pkg.duet3d.com/ unstable armv7
                          Binary file /etc/apt/trusted.gpg.d/duet3d.gpg matches
                          pi@duet3:~ $ echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                          pi@duet3:~ $ sudo apt-get update
                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:3 https://pkg.duet3d.com unstable InRelease
                          Hit:4 https://pkg.duet3d.com stable InRelease
                          Reading package lists... Done
                          pi@duet3:~ $
                          Doug
                          A Former User? chrishammundefined 2 Replies Last reply Reply Quote 0
                            A Former User @Dougal1957
                            yeah
                            do wget http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin -O /opt/dsf/sd/sys/Duet3iap_spi.bin
                              @Dougal1957 The stable list is still in there: sudo rm /etc/apt/sources.list.d/duet3d.list followed by sudo apt-get update should work for you
                                is that a problem, more importantly, should it be a problem?
                                  @bearer that sorted it Thanks very much as you probably imagine I am not good with LINUX at all although I am learning some of it
                                    @Dougal1957 i only translated
                                    into copy/paste; and we all had to learn at some point
                                      @bearer Prob is that I am getting a bit old you know the saying about teaching old Dogs new tricks lol
                                        @Dougal1957 you're trying, and succeeding; no-one gonna fault you for that.
                                        • chas2706undefined
                                          chas2706
                                          Just upgraded and having issues.
                                          On the SBC display DWC reports that the sys drive is unmounted:
                                          But in web browser DWC looks ok but nothing works when clicked:
                                          Any ideas?
                                            A Former User @chas2706
                                            @chas2706 said in RepRapFirmware 3.01-RC6 released:
                                            see what ls -l /opt/dsf/sd says in a ssh shell?
