    No output from G32 on DSF 1.2.4 / DWC 2.07
    Duet Web Control
    14
    64
    3.5k
    • chrishammundefined
      chrishamm administrators @PaulHew
      @mvieleers I hope I can get conditional G-code working in DSF next week.
      @PaulHew Load the heightmap and it should be automatically displayed. I'll add a file list next to the 3D viewer at some point to avoid confusion.
      Duet software engineer
      mvieleersundefined 2 Replies Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew
        @chrishamm said in No output from G32 on DSF 1.2.4 / DWC 2.07:
        Have pressed the 'Reload height map' button and it will not load.
        I will rename the current heightmap.csv and run another.
        Regards,
        Paul
        mvieleersundefined 1 Reply Last reply Reply Quote 0
        • mvieleersundefined
          mvieleers @chrishamm
          Cool!
            mvieleers @PaulHew
            @PaulHew I have the same issue. After I ran a G29, it displays correctly.
            • PaulHewundefined
              PaulHew
              Re-ran Mesh Compensation and still will not display height map.
              File is there
              • PaulHewundefined
                PaulHew
                @chrishamm
                Update, put DWC2.0.7 back on and height map is displayed.
                Regards,
                Paul
                PaulHewundefined 1 Reply Last reply Reply Quote 0
                • PaulHewundefined
                  PaulHew @PaulHew
                  @chrishamm
                  All fixed with 2.1.1 Thank you.
                    Glad it's working now. The issue with G32 not showing any output should be fixed in DSF 1.3.1, too.
                    mvieleersundefined 1 Reply Last reply Reply Quote 1
                    • kraegarundefined
                      kraegar
                      Great news. I'll have to stop printing face shields long enough to upgrade and test!
                      • Danalundefined
                        Danal
                        Yay!! I'm still new with 3 motor beds, and it really helps to see the output. Yay!!
                        kraegarundefined 1 Reply Last reply Reply Quote 0
                        • kraegarundefined
                          kraegar @Danal
                          @Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                          I strongly recommend using a script to auto level until it's under a set value, with a Z home at the end. I've been doing that with one of my printers, and it's been awesome. The other day I had a bit of filament stuck right where my probe hits one spot, and so it couldn't level correctly. It failed to level under my set value, so I went to check and found the filament. Might have saved me a bed surface!
                          • Danalundefined
                            Danal
                            @kraegar said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                            That is exactly what I do. And check the console output to see that it is converging.
                            Literally called "prepz.g"
                              @chrishamm This is indeed correctly working now in DSF 1.3.1. Great job! Thanks! As this was the original issue, I guess this topic can be closed now.
                                @chrishamm Just to make sure I'm not doing anything wrong...conditional gcode is not yet in dsf 1.3.1, correct?
                                • stonewaterundefined
                                  stonewater
                                  This has been driving me crazy for months - can confirm console output is restored for G32 (and others for me) with with 2.1.1
                                  Thank you.
