No output from G32 on DSF 1.2.4 / DWC 2.07
@chrishamm said in No output from G32 on DSF 1.2.4 / DWC 2.07:
Again, sorry for the inconvenience!
No worries! I (and probably most others) understand that this is not your day job. Appreciate everything you're doing.
Looking forward to try the new release, when it's available.
@Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
As you may suspect I have prepared a new DWC version, which adopts David's new object model from RRF and likewise DSF has been improved, too. I'll release a new DSF version later this week which will also feature conditional G-code. Once these new versions are out, I'll be happy to provide support again.
Where is it then?
@chas2706 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
Where is it then?
you can track the development on github while waiting for the packages to show up in the feed for apt.
https://github.com/chrishamm/DuetSoftwareFramework/commits/dev
@chrishamm Thanks a lot for the hard work. Installed DSF 1.3.0 and DWC 2.1.0 and RRF3.01-RC6. This issue with no output on the G32 command still persists, unfortunately.
@mvieleers Thanks for letting me know, I'll have a look.
@chrishamm Brilliant. Quick question, sorry to polute this topic, but were you able to implement conditional gcode in this version of dsf?
Just updated to 2.1.0. Think I have found an issue.
I cannot load my Height Map.
I have check the file is there and there are numbers in it but it tells me height map not available.Have rebooted my Maestro and it still is not displaying.
Regards,
Paul
@mvieleers I hope I can get conditional G-code working in DSF next week.
@PaulHew Load the heightmap and it should be automatically displayed. I'll add a file list next to the 3D viewer at some point to avoid confusion.
Have pressed the 'Reload height map' button and it will not load.
I will rename the current heightmap.csv and run another.
Regards,
Paul -
Cool!
@PaulHew I have the same issue. After I ran a G29, it displays correctly.
@chrishamm
Update, put DWC2.0.7 back on and height map is displayed.Regards,
Paul -
@chrishamm
All fixed with 2.1.1 Thank you. -
Glad it's working now. The issue with G32 not showing any output should be fixed in DSF 1.3.1, too.
Great news. I'll have to stop printing face shields long enough to upgrade and test!
Yay!! I'm still new with 3 motor beds, and it really helps to see the output. Yay!!
I strongly recommend using a script to auto level until it's under a set value, with a Z home at the end. I've been doing that with one of my printers, and it's been awesome. The other day I had a bit of filament stuck right where my probe hits one spot, and so it couldn't level correctly. It failed to level under my set value, so I went to check and found the filament. Might have saved me a bed surface!
@kraegar said in No output from G32 on DSF 1.2.4 / DWC 2.07:
That is exactly what I do. And check the console output to see that it is converging.
Literally called "prepz.g"
@chrishamm This is indeed correctly working now in DSF 1.3.1. Great job! Thanks! As this was the original issue, I guess this topic can be closed now.
