    DSF 1.3.1 (unstable) released
    DSF Development
    9
    40
    2.0k
    • gtj0undefined
      gtj0
      @chrishamm Can you also comment on the other model oddities like the "fans" object showing in an update but with all empty values. It's kinda confusing because some of the things the RRF model considers "live" show up on every update but others which are also "live" don't.
      • chrishammundefined
        chrishamm administrators @gtj0
        @gtj0 The whole purpose of the patch-mode subscription is to reflect changes. So it is intended to transmit empty objects if none of the properties of a list item have changed, else you would not be able to tell when the size of a list has changed (e.g. because you decided to delete a tool or something else). Well, in your case you shouldn't be seeing any empty or null items either and it's related to the bug I'm about to fix, so don't worry about it.
        PS: Here the new regex for S3D that should work, feel free to give it a try:
        Build time: ((?<h>\d+) hour(s)?\s*)?((?<m>\d+) minute(s)?\s*)?((?<s>(\d+) second(s)?))?
        Duet software engineer
        • gtj0undefined
          gtj0 @chrishamm
          @chrishamm Cool! I'll give the regex a try.
          • gtj0undefined
            gtj0 @gtj0
            @gtj0 said in DSF 1.3.1 (unstable) released:
            AHHHHH. The fact that all those <> etc characters need to be escaped in config.json is really annoying. I'll wait for you to update the default file in the repo. 🙂
            • gtj0undefined
              gtj0
              (Possibly) New issue with messages.
              If I execute G32 directly, I get the Leadscrew adjustments made: 0.005 0.040 -0.000, points used 3, (mean, deviation) before (0.014, 0.017) after (0.000, 0.000) message back. If I execute G32 from a macro, I don't.
              For the good case, I see 2 messages in the DCS log...
              DuetControlServer[4316]: [debug] Completed G30 P2 X230 Y-222 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors => Leadscrew adjustments made: 0.005 0.040 -0.000, points used 3, (mean, deviation) before (0.014, 0.017) after (0.000, 0.000)
              DuetControlServer[4316]: Leadscrew adjustments made: 0.005 0.040 -0.000, points used 3, (mean, deviation) before (0.014, 0.017) after (0.000, 0.000)
              When run from a macro I only see...
              • gtj0undefined
                gtj0
                @dc42 @chrishamm Not sure of this is a DSF or RRF issue but the model reported by the DSF always has the extrusion factor at "1" and M221 doesn't seem to affect it. Not sure if the M221 isn't working or if the value reported in the model is incorrect.
                  dc42 administrators @gtj0
                  It works for me, in standalone mode (read command/response pairs from bottom to top as usual):
                  07/04/2020, 07:59:43 	m563 p0
                  Tool 0 - drives: 0; heaters (active/standby temps): 1 (0.0/0.0); xmap: X; ymap: Y; fans: 0; status: selected
                  07/04/2020, 07:59:22 	m409 k"move.extruders[].factor"
                  {"key":"move.extruders[].factor","flags":"","result":[1.2,1.0]}
                  07/04/2020, 07:59:17 	m221
                  Extrusion factor(s) for current tool: 120.0%
                  07/04/2020, 07:59:14 	m221 s120
                  07/04/2020, 07:59:07 	t0
                  07/04/2020, 07:58:59 	m221 s120
                  Error: M221: No tool selected
                  07/04/2020, 07:58:42 	m409 k"move.extruders[].factor"
                  {"key":"move.extruders[].factor","flags":"","result":[1.0,1.0]}
                  • gtj0undefined
                    gtj0 @dc42
                    @dc42 Yeah you're right. I keep forgetting I can do M409 to get the values from RRF.
                    @chrishamm It does appear to be a DSF model update issue. M409 reports the correct value but the DSF model does not.
                      @gtj0 Thanks for the report about the extrusion factor, it will be fixed in the next RRF version. I'm afraid I cannot reproduce the G32 output issue though, I can call macros from macro files and the correct output is shown on DWC as expected.
                      • gtj0undefined
                        gtj0 @chrishamm
                        @chrishamm OK. I'll have to look how I'm grabbing messages from the model updates.
                        Actually I tried with the DWC and had the same result. I'll check again.
                        • gtj0undefined
                          gtj0
                          @chrishamm Using DSF 1.3.1 and DWC 2.1.1, If I click "True Bed Levelling (G32)" then when it completes, I get the message with the corrections. If I run a macro from the DWC that either runs G32 or calls M98 P"/sys/bed.g", I do NOT get the message with the corrections and there's no indication from the DCS that it sent the message.
                          • gtj0undefined
                            gtj0
                            @chrishamm Here's the full DCS output from executing the "PrepPrinter.g" macro from the DWC.
                            No message was displayed.
                            dcs.txt
                              @gtj0 Thank you, the log explains why you see no output. I am working on a fix.
                              • ChrisPundefined
                                ChrisP
                                @chrishamm, not sure if you're aware of this one - there seems to be an issue with sensors that fault crashing DCS.
                                I'm experimenting with using multiple beds for a project and was trying to define a second bed to emulate another system that is setup and runnning already (using RC5 and 1.2.5.0). However, on 1.3.1, the moment the heater/sensor is mapped as a bed, DCS dies - log attached.
                                The system I already have running (not here) does actually have the additional bed attached, whereas this one doesn't at the moment. As a result, there is a sensor fault and I think this is possibly where the bug lies. Unfortunately, I can't find a spare sensor right now to test whether the bug just relates to a sensor fault, however, I don't believe this shold cause a complete crash anyway.
                                Here's the code that can induce the error for me:
                                M308 S2 P"temp1" Y"thermistor" T100000 A"Bed2"	; configure sensor 0 as thermistor on pin temp1
                                M950 H2 C"out2" T2				; create bed heater output on out2 and map it to sensor 2
                                M143 H2 S80					; set temperature limit for heater 0 to 80C
                                M307 H2 A81.5 C541.8 D1.3 S1.00 V0.0 B0		; bed heater tuning values
                                M140 P1 H2 S0 R0				; map heated bed to heater 0
                                M144 P1						; put bed into standby
                                And while you can proabaly easily recreate this, here's the log: Sensor fault.txt
                                • Danalundefined
                                  Danal
                                  This MAY be related to a behavior I've observed but cannot completely and cleanly reproduce enough to report. My best phrasing at this point:
                                  If a homing sequence does not complete, a D3+Pi hangs in a way that requires a power cycle. M999 or emergency stop on the DWC does not totally clear it.
                                  • gtj0undefined
                                    gtj0
                                    @chrishamm ...continuation from PM...
                                    Testing your latest commits...
                                    Things appear to be worse. When I execute the PrepPrinter macro from the DWC, the macro starts and the DWC shows a spinner next to the macro entry but no messages are ever shown and the spinner entry doesn't clear when the macro finishes. In this state you can't click the macro entry any more. I've attached the dcs log again below.
                                    BTW, If I just click the "True Bed Levelling (G32)" button I still don't get the completion message. I was getting it earlier.
                                    Another oddity... If I refresh the DWC, it displays the last message that was sent by the DCS even if it was 20 minutes ago.
                                    ;PrepPrinter.g
                                    M561
                                    G29 S2
                                    G32
                                    G32
                                    G29 S1
                                    ; bed.g
                                    G1 Z5 F3600
                                    G30 P0 X-235 Y-222 Z-99999 ; probe near a leadscrew
                                    G30 P1 X2 Y235 Z-99999 ; probe near a leadscrew
                                    dcs.txt
                                    • gtj0undefined
                                      gtj0
                                      Hmmm. Lots of other things not working. DSF not accepting commands after a few minutes, pause/resume/cancel not working, etc. Have to revert.
                                        @gtj0 Thanks for testing, I'll do some more tests later when I get back home.
                                        PS were you on the latest RRF from github when you tested?
                                        • gtj0undefined
                                          gtj0 @chrishamm
                                          @chrishamm said in DSF 1.3.1 (unstable) released:
                                          Yes. Last commit:
                                          commit b1a1ef35db873ce8ae84a20de90d096c79e8d108 (upstream/v3.01-dev, v3.01-dev)
                                          Author: David Crocker <dcrocker@eschertech.com>
                                          Date:   Tue Apr 7 16:38:01 2020 +0100
                                              Made the heater fault mnessage more concise
                                          • gtj0undefined
                                            gtj0
                                            @chrishamm Any progress? The current dev branch DCS just hangs when you try to run a macro.
