Burnt board
389
    Leblond
    Per colpa di una prolunga usb, ho fottuto la scheda, e' riparabile o devo per forza prenderne un'altra?
    stavo calibrando il sensore con pronterface.
      A Former User
      Ouch! USB extension was in itself not the problem. Bad ground connection on the Duet board, or a ground fault in the computer or on the mains installation more likely.
      To evaluate if it can be repaired the extent of damage has to be evaluated. Clearly the micro USB connector and the 3.3V regulator (U2) in the pictures are damaged. If nothing else is broken its probably repairable; but I'm not sure how well google translate will handle technical troubleshooting.
      undefined 1 Reply Last reply 9 Apr 2020, 13:44 Reply Quote 0
        Leblond @A Former User
        @bearer fino a 2 ore andava tutto ben poi avendo allontanato la stampante mi son dovuto collegare con una prolunga usb per calibrare l'offset del sensore, ho acceso poi puff
          Leblond
          forse faccio prima a prenderne una'altra
            Leblond
            non mi era mai successo in 5 anni, mai avuto problemi di questo genere
              Leblond
              comunque la stampante era gia' collegata con l'usb perche' avevo problemi col router, risolto il problema router ma avendola allontanato la stampante ho usato sto caxxo di cavo
                A Former User
                Its clear from the picture that a lot of current took the path through the ground pin of the USB port - and current takes the path of least resistance. What caused that path to have less resistance is an open question.
                In order to fully evaluate the extent of the damage its necessary to replace the 3.3v regulator designated U2.
                undefined 1 Reply Last reply 9 Apr 2020, 13:52 Reply Quote 0
                  @bearer quindi come dovrei fare?
                    A Former User
                    You need SMD rework tools, a hotplate or pre-heater and hot air station to do a good job. You can read through this thread that offer some non traditional suggestions. https://forum.duet3d.com/topic/15263/magic-smoke-and-stopped-working
                    Edit: it is also necessary to repair the PCB trace to the USB ground pad. Example of less damaged Duet board after removing the USB connector. The trace was loose all the way to the via and the repair will have to find alternative ground nearby and make the connection so it is not a straight forward replacement of the USB socket.
                    undefined 1 Reply Last reply 9 Apr 2020, 14:00 Reply Quote 0
                      boldnuts
                      As this is the 2nd ground loop issue in a short time frame, it might be a good idea to have a refresh on, https://duet3d.dozuki.com/Wiki/USB_ground_loops
                        @bearer si avevo gia' visto tempo fa', ok ne prendo un'altra, purtroppo non riesco ad aggiustarla adesso con questo covid19, io non riesco e non conosco nessuno che la possa aggiustare in tempi brevi
                          Leblond
                          grazie per il momento
                            A Former User
                            Good luck, and see the tips in the link provided by @boldnuts to avoid repeating the issue after replacing the board.
                            undefined 1 Reply Last reply 9 Apr 2020, 14:05 Reply Quote 0
                              @bearer 👍
                              1 out of 14
