    My Deltex || A Large-ish Format Delta Printer || Build log
    My Duet controlled machine
    1
    18
    1.1k
    • Nxt-1undefined
      Nxt-1
      Reserved
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • Nxt-1undefined
        Nxt-1
        Reserved
        • Nxt-1undefined
          Nxt-1
          Reserved
          • Nxt-1undefined
            Nxt-1
            Reserved
            • Nxt-1undefined
              Nxt-1
              Reserved
              • Nxt-1undefined
                Nxt-1
                Reserved
                • Nxt-1undefined
                  Nxt-1
                  Reserved
                  • Nxt-1undefined
                    Nxt-1
                    Reserved
                    • Nxt-1undefined
                      Nxt-1
                      Reserved
                      • Nxt-1undefined
                        Nxt-1
                        Update: completed sections
                        July 2019 - Bed upgrade
                        January 2020 - Epoxy Granite Machine Base
                        • Nxt-1undefined
                          Nxt-1
                          Update: finally got this post more or less updated to current time, enjoy the read 🙂
                          I am also pleased to announce a Deltex V2 which is just about confirmed to be coming. It will not be a 3rd printer as it will reuse the majority of the existing frame and other components. Some changes that are currently planned:
                          • Linear rail upgrade from Robotdigg MGN12's to original THK SRS series rails.
                          • Optimization of rail placement should increase build height ~10-20 cm.
                          • A sound and temperature insulation enclosure.
                          • The existing fourth axis with v-slot rail with be swapped for the old MGN12 rails. Furthermore, the 4th axis mounting points will be incorporated into the enclosure.
                          • Water cooling components might be moved to be stationary on the outside of the enclosure walls.
                          • New way of mounting the steppers/belt idlers to relieve stress from the stepper bearing at higher belt tensions.
                          • Existing printed corner brackets in the frame will be replaced by metal brackets.
                          • Possibly the introduction of even more metal parts as replacement for current plastics.
                          • Nxt-1undefined
                            Nxt-1
                            Update: Finished writing the final piece of the Deltex V1 build log. Currently designs are being drawn and parts are on order for the V2, exiting time for sure.
                            • Nxt-1undefined
                              Nxt-1
                              Updated again: added the section about the noise issues I have been having and some picture 🙂
