    Duet 3 hc6 firmware '''issues''
    Firmware installation
    2.5k
      A Former User
      Probably could, how ever the printter sits in one place and weighs around 47kg, i dont have a reliable laptop and the printter is build so the aces to the duet is under it in a metal enclosure.
      I would avoid mooving it around since ill most likely drop it sooner or later.
        A Former User
        if you can access the SD card and YAT, put the firmware file on the sd card and upgrade using YAT. (or if DWC is stable with the dynamic address, just upload the firmware and let it do the upgrade).
        Kinda difficult to say what to do when information isn't forthcomming.
          A Former User
          Ill try updating via DWC, i hope it works since this is starting to feel like a job and i dont need a second one.
          Thanks for the help.
            A Former User
            Witch one of these i need to update?
              A Former User
              https://github.com/dc42/RepRapFirmware/releases/tag/3.0
              Duet3Firmware_MB6HC.bin
              and these for good measure
              Duet3_SDiap_MB6HC.bin
              DuetWebControl-SD-2.04.zip
              put the files in the /sys folder if transfered using the sd card, if uploading to dwc it will put it in the right place when you upload and ask you to update.
              if using YAT then you need to run M997 S0:2 after having placed the files on the sd card
                A Former User
                (but I'm a little concerned what happens if the SD card glitches during the update. recovery should be possible with bossa but more hassle.)
                  A Former User @A Former User
                  @bearer
                  Sounds fun! cant wait for this to happen, if so how far do you bet an average guy could throw the thing lets not take wind into consideration.
                    droftarts administrators @A Former User
                    @Torppa what version of DWC are you using? If 1.22.6 I wonder if there’s an issue using the old version with RRF3 and Duet 3.
                      A Former User
                      I'd put the files on the sd card, disconnect the network, put the sd card back before powering up the board again and issue the M997 command on the terminal.
                      should reduce the odds of anything going a miss, and if it does you can follow these instructions for recovery https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                        A Former User @droftarts
                        @droftarts
                        Its 2.0.4
                          A Former User
                          And its broken now, no lights no nothing. dont care anymore worst purchase so far trying to be civil so no anger, its hard... wasted basicly 260eur... POS is going to the land fill probably... well atleast my home insurance covers it so i dont haveto fight duet3d over it.
                            A Former User
                            Sigh, I can understand the frustration; but unless the board was damaged the update shouldn't render it unrecoverable.
                            And the update would only have affected one LED, the two indicating 5v and 3.3v are hardwired to the power rails - if they don't work something other than an failed update occured.
                            If you find the will to keep at it; high resolution picture if the board would be helpfull in determining the cause.
                              A Former User
                              Got it to ''work'' again how ever Z and Y axis are reversed, the weird part is that DWC has no trouble homing only when manuly G1 Y34 F3000 Its the Z axis that mooves. The is something weird going on.
                                A Former User
                                I guess that implies it was never broken.
                                Maybe its time to sit down and do some reading.
                                  @Torppa Post your config.g and home all.g.
                                  Check you have connected the Y and Z motors to the correct driver as per your M584 command, the physical order of the drivers on the board isn’t necessarily what you expect; it’s
                                  0 1 2
                                  5 4 3
                                  So driver 3 is behind driver 2, not behind driver 0.
                                  See the wiring diagram here: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/TF1FBCbopEsxvYAv.huge
                                    A Former User
                                    on 3)
                                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 09 2020 16:09:20 GMT+0300 (Itä-Euroopan kesäaika)
                                    M550 P"My Printer" ; set printer name
                                    M551 P"***********" ; set password
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P0.1 S0 ; physical drive 0.1 goes backwards
                                    M569 P0.0 S0 ; physical drive 0.0 goes backwards
                                    M569 P0.2 S0 ; physical drive 0.2 goes backwards
                                    M569 P0.3 S0 ; physical drive 0.3 goes backwards
                                    M584 X0.1 Y0.0 Z0.2 E0.3 ; set drive mapping
                                    M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm
                                    M566 X600.00 Y600.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                    M203 X15000.00 Y15000.00 Z180.00 E3600.00 ; set maximum speeds (mm/min)
                                    M201 X2800.00 Y2800.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                                    M906 X2600 Y2600 Z2600 E1197 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30 ; Set idle timeout
                                    M208 X670 Y620 Z430 S0 ; set axis maxima
                                    M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
                                    M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io0.in
                                    M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in
                                    M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                                    M558 P9 C"io7.in" H5 F120 T2400 ; set Z probe type to bltouch and the dive height + speeds
                                    M308 S0 P"temp0" Y"thermistor" T97700 B4619 C9.743561e-8 ; configure sensor 0 as thermistor on pin temp0
                                    M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                                    M143 H1 S285 ; set temperature limit for heater 1 to 285C
                                    M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                                    M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                                    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                                    M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
                                    M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                                    M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
                                      A Former User
                                      The fans are cooling the steppers, aiming to print mostly nylon ans ASA, duet has a fan 240v for cooling. dont knoiw if this is abit mad for my first 3d printter
                                        @Torppa said in Duet 3 hc6 firmware '''issues'':
                                        So motor wires are connected like this?
                                        Y0 X1 Z2
                                         5  4 E3
                                        I've just been playing around with the networking on a standalone Duet 3. This in my config.g works for me to set a static IP address:
                                        M552 P192.168.0.28 S1                        ; enable network and set IP address
                                        M553 P255.255.255.0                          ; set netmask
                                        M554 P192.168.0.1                            ; set gateway
                                        I can connect to the DWC, edit the IP address and reset, and the IP address will move to the new IP address.
                                        I can also connect when starting up without an SD card inserted. Start up, connect via USB with Serial terminal (in this case Pronterface, as I'm on a Mac):
                                        Connecting...
                                        Printer is now online.
                                        >>>M115
                                        >SENDING:M115
                                        >FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC4 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-03-16b1
                                        >>>>M552
                                        SENDING:M552
                                        Ethernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                                        >>>M553 P255.255.255.0
                                        SENDING:M553 P255.255.255.0
                                        >>>M554 P192.168.0.1
                                        SENDING:M554 P192.168.0.1
                                        >>>M553
                                        SENDING:M553
                                        Net mask: 255.255.255.0
                                        >>>M554
                                        SENDING:M554
                                        Gateway: 192.168.0.1
                                        SENDING:M552 P192.168.0.28 S1
                                        Ethernet running, IP address = 192.168.0.28
                                        >>>M552
                                        SENDING:M552
                                        Ethernet is enabled, configured IP address: 192.168.0.28, actual IP address: 192.168.0.28
                                        >>>M552 S0
                                        SENDING:M552 S0
                                        Network stopped
                                        >>>M552 P192.168.0.69 S1
                                        SENDING:M552 P192.168.0.69 S1
                                        Ethernet running, IP address = 192.168.0.69
                                        >>>M552
                                        SENDING:M552
                                        Ethernet is enabled, configured IP address: 192.168.0.69, actual IP address: 192.168.0.69
                                        I can ping all the addresses I set, even when running with no SD card. I did make sure to send the subnet mask and gateway before the static IP address and enabling the network, though. This is with firmware 3.01-RC4.
                                        So I can't replicate the problem you are seeing.
                                          With you motor currents set like this:
                                          The Duet 3 should barely be getting warm, even without a fan. But then depends how close to other hot things it is, how confined the enclosure is, what the ambient temperature is. It's difficult to over-cool something!
                                            A Former User
                                            The enclosure is 350x350x50mm duet sits on 8mm pcb stands. has 3 went meshes, cables are running in the perimeters of the enclosure and the cable passtru holes have silicone thinggys that i salvaged from an old pc case.
                                            Now that i think of it i might use the old itx case as the enclosure.
                                            the PSU is not in the same box as the duet.
                                            PSU, Mean Well RSP-500-24.
