    Error: Temperature reading fault on heater 0
    2.1k
    • felixlvhundefined
      felixlvh
      @dc42 @bearer
      i have tried to disconnect all wires to isolate the issue. i am plugging in the extruder heaters e1, extruder thermistors, bed thermistor, heated bed still showing the same error. do you think is should get a new board?
      • Turboundefined
        Turbo
        This post is deleted!
          A Former User
          if you measure the resistance across the two pins of the thermistor plug, when its not connected to the board wht do you get?
          felixlvhundefined 1 Reply Last reply Reply Quote 0
          • felixlvhundefined
            felixlvh @A Former User
            @bearer said in Error: Temperature reading fault on heater 0:
            @bearer , i got reading 80.3K
              A Former User @felixlvh
              @felixlvh said in Error: Temperature reading fault on heater 0:
              80.3K
              config says its a 100k thermistor so it should be about right
              maybe you should connect vssa directly to ground on a unused thermistor input now that you have nothing else connected; power from usb and see if that makes a difference
              • felixlvhundefined
                @bearer Thanks, i am still uncertain about the vssa fuse. if you see the image here, https://ibb.co/TYb2MNS i got reading 90.9K. i can now confirm board is v1.01.
                  A Former User
                  you should get pretty much 0. (or at least single digit ohms)
                  if you have a wire handy, run it as shown here, connect the thermistor to e0 or bed and power from usb.
                  (it'll bypass the fuse, which should be safe when only the thermistor and usb is connected)
                  edit: seems the 1.02 board do not have a resettable fuse
                  https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_VSSA_fuse
                  • felixlvhundefined
                    felixlvh
                    @bearer If i did it correctly, It still shows the same error 2000'C
                      A Former User
                      you've got the thermistor connected to e1 and configured for e0? move it to e0?
                      • felixlvhundefined
                        felixlvh
                        configured
                        @bearer OMG, E0 works!
                          A Former User
                          so you need a new fuse, ref the wiki link above.
                          edit; and you probably have to remap or repair fan2 as well.
                          • felixlvhundefined
                            felixlvh
                            @bearer am i right to say usign external fuse like this? can i still print by bypassing it temporarily? thanks a ton!
                              A Former User
                              if the pins read vssa and gnd, then yes. (also very low value fuse, less is better, wiki says "between 125 and 250mA and a resistance of between 2 and 4 ohms.")
                              you can print with a bypass either a wire instead of the fuse, or like you tested - BUT there is likely a reason the fuse blew and the fan blew - your fan and thermistor have likely shorted on the hotend; and if it happens again with no fuse the CPU will likely be damaged.
