code ???? o k then ???
ok where did the stall feature come from then the docs say if stall is active endstops wont work im trying to understand did it com from M307
Stall detection as an endstop is defined by M574 S3.
M307 is to configure heater parameters. Not related.
What exactly is not working?
If you have changed the Y axis to use the ball screw, have you changed the steps per mm yet?
all 3 endstop limits limits let me reboot and ill try again
could my prob be in the 4 home files
; homeall.gG91 ; relative positioning
G1 S2 X0.2 Y0.2 Z0.2 ; Move all axis 0.2 mm, clear stall status
M98 Pdeployprobe.g ; deploy mechanical Z probe; x and y Sensor less homing
M400 ; make sure everything has stopped before we make changes
M915 X S2 Y S3 R0 F0 ; set X and Y sensitivity, do nothing when stall, unfiltered
M574 X1 Y1 S3 ; set endstops to use motor stall
G1 S2 Z10 F1200 ; lift Z
G1 S1 X-265 Y-260 F5000 ; move X and Y back, stopping at the end stop
G90 ; back to absolute mode;G1 X115 Y115 F12000 ; Move to center of bed and home Z
G1 X127 Y134 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bedM915 X S10 Y S10 R3 F0 ; set X and Y sensitivity to -0, when stall home XY and resume print, filtered so it takes 4 steps to figure out it has stalled
M98 Pretractprobe.g ; retract mechanical Z probe
what does a guy remove ?? replace???
So i think i get this now,, your gonna laugh,,, not ever having worked with this stuff can i assume everything after the ; is a "note" to the specific g or m code entry??.. everything before is the ; actual "Working code" notes to remind me what I've done in the future?? the notes are not attached to the software in any way???? so if i make a change the notes stay the same ?? so lets say, i want to get rid of stall.... lets say its set at S3 (example) all i would do is change the S1 and change the note to somthing like endstop sw. n/o so i remember in the future ??
Yes, everything after a ; is a comment that isn't used by the firmware.
so the only thing i need to change is M574 X1 Y1 Z1 S3.........to S1 in my homeall file like i did in config.g
@ziggymanpopo said in code ???? o k then ???:
Yes, remove the M574 from the homeall, and the probedeploy and retract. And the M915 line.
what do i do with this ???
M915 X S2 Y S3 R3 F0 ; set X and Y sensitivity to 0, when stall home XY and resume print, filtered so it takes 4 steps to figure out it has stalled
do i delete this whole line ? home x & home y. files both have M915o k thats the best guess i have
the whole M574 line/ and only from home all
Delete those lines from all your homing files if you aren't using stall detection anymore.
sorry that was a question
great thank you ill give that all a try tonight
well that did the trick everthing is back in working order.
i really appreciate all your patients you guys rock
back to tweeeking thank you
