    Duet reporting inaccurate percentage.
    Duet Web Control
    2.0k
    • Turboundefined
      Turbo
      Im going to try copying the end gcode from my other printer (only changing one z value since its not as big), since that one reads percentage properly, and see if the issue persists.
      Cant stop tuning wont stop tuning.
      Dbot, Custom i3, Voron 0&2
      • Turboundefined
        Turbo
        @Phaedrux
        Print finished with the new gcode. Its not the end script causing it. it still ends at 82%, despite being the same end gcode on my other printer, which displays the percentage properly.
        What else could it be
        • Turboundefined
          Turbo
          tried another print with no end .gcode. I'm still having this issue.
          • Turboundefined
            Turbo
            Is it possible the start gcode would cause this issue? Ive ran the same gcode (essentially, changing retraction/PA) on two printers and one correctly reads the percentage, while one finishes around the 82% mark, not the same value each time. 81.2, 82.6, and 82% is what ive witnessed.
              I can't see anything obvious in the gcode file.
              • Turboundefined
                Turbo
                Bumping this topic because the issue remains unresolved. A print just finished at 55.8%
                  Are you referring to the % complete reported by DWC, or by PanelDue?
                  Those % complete figures are not based on object height, which is why your end GCode does not affect them. AFAIR the % complete figure is based on filament consumption vs. filament required (if the filament length required is available in the GCode file), otherwise on the percentage of the GCode file that has been processed.
                  Your sample GCode file has these figures:
                  ; filament used [mm] = 6904.1
                  ; filament used [cm3] = 16.6
                  ; total filament used [g] = 0.0
                  ; total filament cost = 0.0
                  The 6904.1mm figure is being picked up by RRF. Next time you print this file (or another file that shows the same issue), please monitor the Filament Usage value of the DWC status page towards the end of the print, to see whether it is converging towards the filament usage recorded in the GCode file, or towards a lower value.
                  I note that your GCode file contains some negative extrusion amounts:
                  G1 F8640.000
                  G1 X18.241 Y12.662 E-0.33092
                  G1 X19.422 Y11.978 E-0.31506
                  G1 X20.660 Y11.628 E-0.29710
                  G1 X21.913 Y11.463 E-0.29192
                  G1 E-0.06500 F2100.00000
                  I presume this means you have "wipe while retracting" or similar enabled in the slicer.
                    I've just run that file in simulation mode. It finished just after reporting 88% complete with >1m of filament remaining. This suggests to me that either RRF is accumulating filament usage incorrectly, or that PrusaSlicer is reporting incorrect filament usage for the particular options you are using.
                    I think that RRF may be being confused by wipe during retraction. Please can you try running that print in simulation mode and check that you get the same results as me (or run another file if you prefer, and note the % complete figure it reaches just before the end). Then slice that file again, turning off wipe-while-retract. Simulate that file and see if the behaviour is different.
                    Turboundefined 1 Reply Last reply Reply Quote 1
                    • Turboundefined
                      Turbo @dc42
                      @dc42 running that .gcode I linked earlier shows a correct readout in simulation mode; reaching 100% as expected. I am referring to the DWC %
                      EDIT: i ran the file that finished at 55% from earlier in simulation mode, and it showed proper percentage up to 100%
                        dc42 administrators @Turbo
                        @Turbo said in Duet reporting inaccurate percentage.:
                        Strange, when I ran your file in simulation mode (using RRF 3.01-RC7) it definitely jumped from about 88% to 100%.
                        I am fairly sure that wipe-while-retract is confusing the filament used accumulator, but I don't know if that is the only issue here. Can you re-slice one of your prints with wipe-while-retract disabled and see if the problem goes away?
                          This is now fixed in the 3.01 source code and in the firmware binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                          Turboundefined 1 Reply Last reply Reply Quote 0
                          • Turboundefined
                            Turbo @dc42
                            @dc42 disabling wipe while retract solved it! Although am i able to use 3.01 with a duet 2 wifi board?
                            Board: Duet WiFi 1.02 or later
                            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
                            Duet WiFi Server Version: 1.23
                              Yes you can, however you will need to make substantial changes to your config.g file if you do upgrade. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files for the details.
                              The fix will probably make it to RRF 2 eventually, but not until it has been in RRF3 long enough for me to be certain that it has no unexpected side effects.
                              Turboundefined 2 Replies Last reply Reply Quote 0
                              • Turboundefined
                                Turbo @dc42
                                @dc42 Got it, thanks. I always assumed the RRF 3 would only work for Duet 3 boards and later. IDK Why
                                • Turboundefined
                                  Turbo @dc42
                                  @dc42 After updating to RRF3.0 RC7, the issue is still present it seems. i have a current print about 50% done, however, the DWC only shows 6%, and i can watch it go up and down in percentage, which i dont think is supposed to happen. The object is consistent all the wey to the top, so there shouldnt be any large discrepancies that would affect %. This is with wipe while retract is on, because it does affect my print quality noticeably.
                                    Yes the bug is present in the 3.01-RC7 release, but fixed in the post RC7 build that I linked to earlier.
                                    • SpoonUnitundefined
                                      SpoonUnit
                                      I'm not sure if this issue is connected with my recent move to RRF3.3b2. Since I did, I've had a number of prints telling me they are over 100% complete. Querying the forum I found this thread, and the detail that completion calculation is based on GCODE-embedded filament usage.
                                      In the GCODE file I see:
                                      ; filament used [mm] = 13125.43
                                      In DWC, I see this at the end of the print during my cool down phase:
                                      and
                                      The layer count is off, but the filament consumption seems to suggest the reported job completion level should be 99%, not 144.7%.
                                      To add to the mix, I'm also testing ArcWelder, so the GCODE has G2/G3 commands scattered throughout.
                                      dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                                        dc42 administrators @SpoonUnit
                                        One for @chrishamm.
                                        • chrishammundefined
                                          chrishamm administrators @SpoonUnit
                                          @spoonunit Please share the full G-code file and I'll have a look.
                                          Duet software engineer
                                          SpoonUnitundefined 1 Reply Last reply Reply Quote 0
                                            SpoonUnit @chrishamm
                                            @chrishamm here you go
                                            seq26.gcode
                                            SpoonUnitundefined dc42undefined 2 Replies Last reply Reply Quote 1
