    I am erasing duet but which firmware can I use?
    Firmware installation
    1.4k
      Do you have the DWC files in the /www folder on the SD card?
      Can you ping that IP address successfully?
      What happens when you try to go to the IP?
      jcv1977undefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @jcv1977
        @jcv1977 said in I am erasing duet but which firmware can I use?:
        Thanks for helping. I did try the fallback 3 but again I can't log in to web control page. I have installed Firmware 2.05.1 and wifi 1.02.
        Did you mean WiFi firmware 1.23 ?
        • jcv1977undefined
          jcv1977 @Phaedrux
          @Phaedrux Yep i have follow the tutorial so i have replaced www files for the recommended ones. Actually i can't ping that ip, it funny i entered my router page and there seems to be a problem, the router detects the mac address of the duet correctly but it keeps assigning a another fixed ip. The strange part is that if i try my duet to use dhcp so that its assigned the routers fixed ip address it just don't get any ip at all. Then, i've tried to delete the fixed address from my router, but it persist. WTF?? So i am guessing thats why the web control is not working. I will reset my router so stay tunned! lol
            Hmm, routers can be persnickity sometimes. Best to leave the Duet as DHCP and let the router assign one. Hopefully you can get them to coorperate.
            • jcv1977undefined
              jcv1977 @dc42
              @dc42 I did installed that version, but when i use M115 it shows 1.02.
                I think 1.02 is the Duet hardware revision, not the WiFi firmware revision. To check the WiFi firmware revision, send M122 and look for it in the WiFi section of the response.
                • jcv1977undefined
                  jcv1977 @dc42
                  You were right! But it still can't get any dhcp address and i get:
                  WiFi reported error: Timed out while trying to connect to MYWIFI
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 1.25ms; fastest: 0.00ms
                  HTTP sessions: 0 of 8
                  - WiFi -
                  Network state is changing mode
                  WiFi module is trying to connect
                  WiFi firmware version 1.23
                  WiFi MAC address b4:e6:2d:52:ff:37
                  WiFi Vcc 3.30, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 27480
                  ok
                    A Former User @jcv1977
                    how is the signal strength? (proably need to measure with app on phone).
                    which type of encryption is in use?
                    (and its not a vodaphone router is it?)
                    jcv1977undefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • jcv1977undefined
                      jcv1977 @A Former User
                      @bearer I don't think its a signal issue i am literally near the router and the signal is excellent. I use WPA2 Personal and AES encryption. Nope its an Atlantic broadband router, but those are really tight i can't even turn off dhcp jst to test with other router. So i may habe to try another one.
                        should work, any special characters in the key? how did you add the network; ponterface tends to mess up keys f.ex.
                        if you're not aware, you can also configure the duet to be an access point if that helps you out temporarily. (read the to use as AP notes)
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                        jcv1977undefined 2 Replies Last reply Reply Quote 0
                          @bearer said in I am erasing duet but which firmware can I use?:
                          Is the SSID of your access point exactly MYWIFI all in uppercase? SSIDs are case sensitive.
                            A Former User
                            wouldn't a wrong ssid result in "no known networks found" and not a timeout?
                              Yes, it should.
                              @jcv1977 , if you send M587 without parameters via USB, what is the response?
                              • jcv1977undefined
                                @bearer No special characters i just kept it easy not to add possible issues. Yes i tried the AP but with another firmware, it just connected but nothing happened i will try it with the current one.
                                • jcv1977undefined
                                  jcv1977 @dc42
                                  @dc42 Its not the ssid i did all my homework after asking here 😉
                                  After M587 i get:
                                  MYWIFI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                                  Might be a bad wifi module?
                                  • jcv1977undefined
                                    @bearer Well there is some progress! Using AP mode works fine now and i can finally see the web control page. But it can't seem to connect to my router nor having an ip assigned even if i set at the freaking router a static one.
                                    Using macros or manually (using M587 S"MYWIFI" P"MYPASSWORD" I192.168.1.128 the blue light of the esp8266 gets blue, but i can't ping to that IP and i can't get to web control page nothing is displayed. Also in my router 192.168.1.128 is not shown at all and the duet appears with a fixed ip 192.169.1.9 but it can't be ping at and it is not browseable.
                                    I 've already reset to factory setting the router but i dont understand why that fixed IP is still there?????
                                      (using M587 S"...
                                      lets turn on wifi debugging and see if it gives you any more info (doubt it, but worth a try)
                                      send M111 S1 P14 to the duet before M552 S1
                                      you could also perhaps try adding the mac address manually for each IP one at the time?
                                      arp -s 192.168.1.128  b4-e6-2d-52-ff-37
                                      ping 192.168.1.128
                                      arp -d 192.168.1.128
                                      then try
                                      arp -s 192.169.1.9  b4-e6-2d-52-ff-37
                                      ping 192.169.1.9
                                      arp -d 192.169.1.9
                                        A Former User
                                        hang on; is that a typo or the actual address?
                                        192.168.1.128 vs 192.169.1.9
                                        if a typo, un-typo my commands above, if not a typo run route print on the computer.
                                        • jcv1977undefined
                                          jcv1977
                                          It was a typo, could not delete ips manually. And the debugging returned:
                                          Debugging enabled for modules: WiFi(14)
                                          Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
                                          ok
                                          ok
                                          ok
                                          WiFi: mode : sta(b4:e6:2d:52:ff:37)
                                          WiFi: add if0
                                          WiFi: wifi evt: 8
                                          WiFi: scandone
                                          WiFi: ../src/SocketServer.cpp(353): found network DIRECT-0c-HP M29 LaserJet
                                          WiFi: ../src/SocketServer.cpp(353): found network NETGEAR64
                                          WiFi: ../src/SocketServer.cpp(353): found network ATTBCVg3dS
                                          WiFi: ../src/SocketServer.cpp(353): found network ATTevrXIVS
                                          WiFi: ../src/SocketServer.cpp(353): found network MYWIFI
                                          WiFi: ../src/SocketServer.cpp(353): found network 8831B2
                                          WiFi: ../src/SocketServer.cpp(353): found network NY Giants 2.4
                                          WiFi: ../src/SocketServer.cpp(353): found network AC4F3D
                                          WiFi: ../src/SocketServer.cpp(353): found network VIZIOCastDisplay0071
                                          WiFi: ../src/SocketServer.cpp(353): found network NETGEAR76
                                          WiFi: ../src/SocketServer.cpp(353): found network NETGEAR50
                                          WiFi: ../src/SocketServer.cpp(353): found network DIRECT-C5-HP OfficeJet 3830
                                          WiFi: ../src/SocketServer.cpp(353): found network Area 51
                                          WiFi: ../src/SocketServer.cpp(353): found network Torresnunez
                                          WiFi: ../src/SocketServer.cpp(353): found network Bchehade24
                                          WiFi: ../src/SocketServer.cpp(353): found network NETGEAR78
                                          WiFi: ../src/SocketServer.cpp(353): found network belkin.fac
                                          WiFi: ../src/SocketServer.cpp(353): found network belkin.fac.guests
                                          WiFi: ../src/SocketServer.cpp(353): found network ARLO_VMB_1570254913
                                          WiFi: sleep enable,type: 2
                                          WiFi: STUB: dhcp_stop
                                          WiFi: scandone
                                          WiFi: state: 0 -> 2 (b0)
                                          WiFi: state: 2 -> 3 (0)
                                          WiFi: state: 3 -> 5 (10)
                                          WiFi: add 0
                                          WiFi: aid 2
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: connected with MYWIFI, channel 6
                                          WiFi module is connected to access point MYWIFI, IP address 192.168.0.128
                                          WiFi: ip:192.168.0.128,mask:0.0.0.0,gw:0.0.0.0
                                          WiFi: wifi evt: 0
                                          WiFi: wifi evt: 3
                                          WiFi: pm open,type:2 0
                                          It has to be something between the wifi module and the freaking router they just don't like each other.
                                          I changed the ip also to check but still nothing.
                                          A Former User? jcv1977undefined 2 Replies Last reply Reply Quote 0
                                            ? permissions or wrong command? might need to run as admin.
                                            thats probably food for @dc42 he knows more about RRF than i do about networks ^^
