    I am erasing duet but which firmware can I use?
    Firmware installation
    1.4k
      A Former User @jcv1977
      @jcv1977 said in I am erasing duet but which firmware can I use?:
      WPA2 Personal and AES encryption
      should work, any special characters in the key? how did you add the network; ponterface tends to mess up keys f.ex.
      So i may habe to try another one.
      if you're not aware, you can also configure the duet to be an access point if that helps you out temporarily. (read the to use as AP notes)
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
      jcv1977undefined 2 Replies Last reply Reply Quote 0
        @bearer said in I am erasing duet but which firmware can I use?:
        WiFi reported error: Timed out while trying to connect to MYWIFI
        how is the signal strength? (proably need to measure with app on phone).
        which type of encryption is in use?
        (and its not a vodaphone router is it?)
        Is the SSID of your access point exactly MYWIFI all in uppercase? SSIDs are case sensitive.
          A Former User
          wouldn't a wrong ssid result in "no known networks found" and not a timeout?
            Yes, it should.
            @jcv1977 , if you send M587 without parameters via USB, what is the response?
            • jcv1977undefined
              jcv1977 @A Former User
              @bearer No special characters i just kept it easy not to add possible issues. Yes i tried the AP but with another firmware, it just connected but nothing happened i will try it with the current one.
              • jcv1977undefined
                jcv1977 @dc42
                @dc42 Its not the ssid i did all my homework after asking here 😉
                After M587 i get:
                MYWIFI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                Might be a bad wifi module?
                • jcv1977undefined
                  @bearer Well there is some progress! Using AP mode works fine now and i can finally see the web control page. But it can't seem to connect to my router nor having an ip assigned even if i set at the freaking router a static one.
                  Using macros or manually (using M587 S"MYWIFI" P"MYPASSWORD" I192.168.1.128 the blue light of the esp8266 gets blue, but i can't ping to that IP and i can't get to web control page nothing is displayed. Also in my router 192.168.1.128 is not shown at all and the duet appears with a fixed ip 192.169.1.9 but it can't be ping at and it is not browseable.
                  I 've already reset to factory setting the router but i dont understand why that fixed IP is still there?????
                    (using M587 S"...
                    lets turn on wifi debugging and see if it gives you any more info (doubt it, but worth a try)
                    send M111 S1 P14 to the duet before M552 S1
                    you could also perhaps try adding the mac address manually for each IP one at the time?
                    arp -s 192.168.1.128  b4-e6-2d-52-ff-37
                    ping 192.168.1.128
                    arp -d 192.168.1.128
                    then try
                    arp -s 192.169.1.9  b4-e6-2d-52-ff-37
                    ping 192.169.1.9
                    arp -d 192.169.1.9
                      A Former User
                      hang on; is that a typo or the actual address?
                      192.168.1.128 vs 192.169.1.9
                      if a typo, un-typo my commands above, if not a typo run route print on the computer.
                      • jcv1977undefined
                        jcv1977
                        It was a typo, could not delete ips manually. And the debugging returned:
                        Debugging enabled for modules: WiFi(14)
                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
                        ok
                        ok
                        ok
                        WiFi: mode : sta(b4:e6:2d:52:ff:37)
                        WiFi: add if0
                        WiFi: wifi evt: 8
                        WiFi: scandone
                        WiFi: ../src/SocketServer.cpp(353): found network DIRECT-0c-HP M29 LaserJet
                        WiFi: ../src/SocketServer.cpp(353): found network NETGEAR64
                        WiFi: ../src/SocketServer.cpp(353): found network ATTBCVg3dS
                        WiFi: ../src/SocketServer.cpp(353): found network ATTevrXIVS
                        WiFi: ../src/SocketServer.cpp(353): found network MYWIFI
                        WiFi: ../src/SocketServer.cpp(353): found network 8831B2
                        WiFi: ../src/SocketServer.cpp(353): found network NY Giants 2.4
                        WiFi: ../src/SocketServer.cpp(353): found network AC4F3D
                        WiFi: ../src/SocketServer.cpp(353): found network VIZIOCastDisplay0071
                        WiFi: ../src/SocketServer.cpp(353): found network NETGEAR76
                        WiFi: ../src/SocketServer.cpp(353): found network NETGEAR50
                        WiFi: ../src/SocketServer.cpp(353): found network DIRECT-C5-HP OfficeJet 3830
                        WiFi: ../src/SocketServer.cpp(353): found network Area 51
                        WiFi: ../src/SocketServer.cpp(353): found network Torresnunez
                        WiFi: ../src/SocketServer.cpp(353): found network Bchehade24
                        WiFi: ../src/SocketServer.cpp(353): found network NETGEAR78
                        WiFi: ../src/SocketServer.cpp(353): found network belkin.fac
                        WiFi: ../src/SocketServer.cpp(353): found network belkin.fac.guests
                        WiFi: ../src/SocketServer.cpp(353): found network ARLO_VMB_1570254913
                        WiFi: sleep enable,type: 2
                        WiFi: STUB: dhcp_stop
                        WiFi: scandone
                        WiFi: state: 0 -> 2 (b0)
                        WiFi: state: 2 -> 3 (0)
                        WiFi: state: 3 -> 5 (10)
                        WiFi: add 0
                        WiFi: aid 2
                        WiFi: cnt
                        WiFi:
                        WiFi: connected with MYWIFI, channel 6
                        WiFi module is connected to access point MYWIFI, IP address 192.168.0.128
                        WiFi: ip:192.168.0.128,mask:0.0.0.0,gw:0.0.0.0
                        WiFi: wifi evt: 0
                        WiFi: wifi evt: 3
                        WiFi: pm open,type:2 0
                        It has to be something between the wifi module and the freaking router they just don't like each other.
                        I changed the ip also to check but still nothing.
                        A Former User? jcv1977undefined 2 Replies Last reply Reply Quote 0
                          ? permissions or wrong command? might need to run as admin.
                          thats probably food for @dc42 he knows more about RRF than i do about networks ^^
                            A Former User
                            it be interesting to see the debug for that without I192.168.1.128 (i.e. let the duet (try to?) obtain the dhcp lease) and while you're at that, do run route print from the computer just so we can confirm its all on the up and up.
                            • jcv1977undefined
                              jcv1977 @jcv1977
                              @jcv1977 I did run the arp command as admin, and the commands were accepted but the ip was still on the router pool.
                              This is debbugging result with dhcp i just cut a whole lot of Network scan failed :
                              ok
                              ok
                              ok
                              WiFi: state: 5 -> 0 (0)
                              WiFi: rm 0
                              WiFi: pm close 7
                              WiFi: del if0
                              WiFi: usl
                              WiFi: mode : null
                              WiFi: wifi evt: 1
                              WiFi: STA disconnect: 8
                              WiFi: wifi evt: 8
                              WiFi module is idle
                              ok
                              WiFi: add if0
                              WiFi: wifi evt: 8
                              WiFi: scandone
                              WiFi: ../src/SocketServer.cpp(353): found network NETGEAR94
                              WiFi: ../src/SocketServer.cpp(353): found network NETGEAR21
                              WiFi: ../src/SocketServer.cpp(353): found network Internetmine
                              WiFi: ../src/SocketServer.cpp(353): found network ACCA31
                              WiFi: ../src/SocketServer.cpp(353): found network ARRIS-FD86
                              WiFi: scandone
                              WiFi: add 0
                              WiFi: aid 2
                              WiFi: cnt
                              WiFi:
                              WiFi: dhcp client start...
                              WiFi: wifi evt: 0
                              WiFi module is idle
                              WiFi: rm 0
                              WiFi: pm close 7
                              WiFi: del if0
                              WiFi: usl
                              WiFi: mode : null
                              WiFi: Fatal exception 28(LoadProhibitedCause):
                              WiFi: epc1=0x4000df2f, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000033, depc=0x00000000
                              WiFi:
                              WiFi: Exception (28):
                              WiFi: epc1=0x4000df2f epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000033 depc=0x00000000
                              WiFi:
                              WiFi: ctx: sys
                              WiFi: sp: 3ffffc90 end: 3fffffb0 offset: 01a0
                              WiFi:
                              WiFi: >>>stack>>>
                              WiFi: 3ffffe30:  3ffeface 3fff4d4c 40223f10 40105dd8
                              WiFi: 3ffffe40:  40216def 00000006 00000005 402298d9
                              WiFi: 3ffffe50:  00000033 00000010 40217705 3ffee6bc
                              WiFi: 3ffffe60:  3fff4d4c 00000000 3ffe9ff8 3fff516c
                              WiFi: 3ffffe70:  3fff4d4c 4021762d 3ffee6bc 4020b004
                              WiFi: 3ffffe80:  3ffe9ff8 00000002 00000022 00000000
                              WiFi: 3ffffe90:  3fff4dce 3fff4ec4 00000000 00000000
                              WiFi: 3ffffea0:  3ffe9ff8 3ffe9ff8 00000033 4021957b
                              WiFi: 3ffffeb0:  3ffeedc0 40219174 4020b004 3ffeedc0
                              WiFi: 3ffffec0:  40218cf0 402344e0 3ffee740 00000000
                              WiFi: 3ffffed0:  00000001 00000001 00000000 00000000
                              WiFi: 3ffffee0:  402191af 3ffeeeb8 3ffeeeb8 40106df4
                              WiFi: 3ffffef0:  4021b11c 3ffeeeb8 ffff8000 00000001
                              WiFi: 3fffff00:  3ffee740 4021b0e0 3ffee6bc 00000002
                              WiFi: 3fffff10:  40219164 40219138 3ffee740 00000002
                              WiFi: 3fffff20:  40219103 3ffee6bc 00000002 40106c5e
                              WiFi: 3fffff30:  402196b4 3ffee6bc 3ffee838 4020b004
                              WiFi: 3fffff40:  402190e1 3ffee838 00000003 3ffee838
                              WiFi: 3fffff50:  40218e84 3ffeee78 3ffef5a0 f3ecd39c
                              WiFi: 3fffff60:  60000600 0000010f 00000001 00000000
                              WiFi: 3fffff70:  4022dfa9 3ffef5d4 3ffef5a0 f3ecd39c
                              WiFi: 3fffff80:  4022dfee 3fffdab0 00000000 3fffdcb0
                              WiFi: 3fffff90:  3ffef5b0 3fffdab0 00000000 00000005
                              WiFi: 3fffffa0:  40000f49 40000f49 3fffdab0 40000f49
                              WiFi: <<<stack<<<
                              WiFi module is idle
                              WiFi reported error: no known networks found
                              WiFi module is idle
                              WiFi reported error: network scan failed
                              WiFi module is idle
                              WiFi: ⸮nP|!-1K5⸮К⸮⸮XK!⸮~)Q*!⸮⸮ "pkt⸮E,-⸮@⸮⸮P⸮1%(⸮yh=⸮nzA⸮ )i⸮⸮P1⸮N⸮⸮fP1⸮N⸮R⸮t⸮1Z⸮Q⸮
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi: epc2:0x00000000 epc3:0x00000000 excvaddr:0x00000033 depc:0x00000000
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi: add if0
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                              WiFi: wifi evt: 8
                              WiFi module is idle
                              WiFi module is idle
                              WiFi module is idle
                                arp on the computer won't affect the router, just where the computer will send and IP packet; i.e. trying to force the computer to direct the packets to the duets mac address for either address. bit if ping failed then moot point.
                                would probably need big cheese to evaluate the debug info (or maybe run wireshark if your wifi adapter can do promiscuous mode capture, but few on windows does)
                                jcv1977undefined 1 Reply Last reply Reply Quote 0
                                • jcv1977undefined
                                  Great!
                                  We will wait for him!!!! Thanks Bearer!!!!
                                  • jcv1977undefined
                                    jcv1977 @dc42
                                    @dc42 I think i found it! Evidently there is a bug:
                                    https://forum.duet3d.com/topic/15207/duet-wifi-wlan-vs-wpa2-connection-error/8
                                    https://forum.duet3d.com/topic/14993/cannot-connect-duet-wifi-to-new-wifi-router
                                    @bearer You aked me if its a vodafone and its not, but in one of the post it says its an Arris router and mine is Arris too. I gues this freaking router has something that is not compatible. Just for starters i can't turn off dhcp nor update the router's firmware wich is BS. So i guess by now i'll just use it on AP mode until y buy a proper UNIFI Gear.
