    [HELP] How to use DueUI without a Duet using chrome
    DueUI
    3.5k
    • Dario02undefined
      Dario02
      Hi, I would like to create a good looking GUI. I don't own a duet for now so I have created a Apache webserver on localhost and then I tried to connect and it works. Then I tried this:
      Duet hostname or IP address: http://localhost/
      DueUI config file URL:
      D:\Apache24\htdocs\dueui_config_default_standalone.json
      But I don't see any UI showing up....
      • gtj0undefined
        gtj0 @Dario02
        @Dario02 I just realized that DueUI won't start at all if it can't find a Duet to connect to. Give me until tomorrow and I'll fix that so you can run it in test mode without a Duet. Sorry about that!
        Additional Info:
        The config file URL must also be via the webserver so something like http://localhost/dueui_config_default_standalone.json
        This is because browsers no longer allow applications to load files directly from the local filesystem.
        Your filesystem layout should look something like this...
        D:\Apache24\htdocs\
        | - css/
        | - fonts/
        | - js/
        | - dueui.html
        | - dueui_config_default_standalone.json
        Then to access DueUI, the URL would be http://localhost/dueui.html
        and the config URL would be http://localhost/dueui_config_default_standalone.json
        If you use the Chrome debugger <ctrl>-<shift>-i you'll get more information if something goes wrong.
        Dario02undefined 1 Reply Last reply Reply Quote 0
        • Dario02undefined
          Dario02 @gtj0
          @gtj0 Oh here we go! Don't worry, happy to have helped you discover this ahah.
          • gtj0undefined
            gtj0 @Dario02
            @Dario02 I just pushed up a new release that has a "Test Mode" button under Settings. When it's turned on, you don't need a Duet to get the GUI to display.
            You may have to clear cookies/data for "localhost" to get the Settings page to show up again.
            Dario02undefined 2 Replies Last reply Reply Quote 0
            • tech-ratonundefined
              tech-raton
              For testing purpose, what should be written in the url for a config file in my computer?
              I didn't have any apache server
              • Dario02undefined
                Dario02 @gtj0
                @gtj0 Ok I'll let you know soon
                • Dario02undefined
                  Dario02 @gtj0
                  @gtj0 Could you make a tutorial to configure a server for test mode? I'm trying to get it done but I don't know the files I have to put in my localhost server document folder
                  • Dario02undefined
                    Dario02
                    This post is deleted!
                    • gtj0undefined
                      gtj0 @tech-raton
                      @tech-raton said in [HELP] How to use DueUI without a Duet using chrome:
                      Unfortunately, browsers no longer applications to access files on a local computer but there are extensions you can add to your browser that can turn it into a mini http server. The one I use most often when I need a quick web server is ...
                      https://chrome.google.com/webstore/detail/web-server-for-chrome/ofhbbkphhbklhfoeikjpcbhemlocgigb?utm_source=chrome-app-launcher-info-dialog
                      That's for Chrome-based browsers only of course.
                      Here's a more generic way to set up a test server...
                      https://developer.mozilla.org/en-US/docs/Learn/Common_questions/set_up_a_local_testing_server
                      • gtj0undefined
                        gtj0 @Dario02
                        @Dario02 said in [HELP] How to use DueUI without a Duet using chrome:
                        That's a good idea. I'll add that to the wiki. For now see my reply above.
                        Dario02undefined 1 Reply Last reply Reply Quote 1
                        • Dario02undefined
                          Dario02 @gtj0
                          what now?
                          ctrl+shift+i:
                          dueui.html:1 Uncaught SyntaxError: Unexpected identifier
                          at DOMEval (dueui-vendor-bundle.js:124)
                          at Function.globalEval (dueui-vendor-bundle.js:358)
                          at text script (dueui-vendor-bundle.js:9877)
                          at ajaxConvert (dueui-vendor-bundle.js:9013)
                          at done (dueui-vendor-bundle.js:9483)
                          at XMLHttpRequest.<anonymous> (dueui-vendor-bundle.js:9785)
                          • Dario02undefined
                            Dario02
                            I don't know how but now it works xD.
                            I have activated all the buttons ahahha and it crashes. Then I started again the server and now it works, finally I can see the simulator 🙂
                            • Dario02undefined
                              Dario02
                              is there a way to set an image for a logo and icons to buttons?
                              • gtj0undefined
                                gtj0 @Dario02
                                Sure!
                                You can place an image anywhere using the "image" widget.
                                You can also place arbitrary HTML anywhere with the "html" widget.
                                For buttons, you can add an icon from the set available from Google Material Icons using the "icon" attribute.
                                You can also place your own html in the "value" attribute like so:
                                	"id": "restart",
                                	"type": "button",
                                	"enabled": true,
                                	"style": {
                                		"width": "96px",
                                	"classes": "btn btn-warning",
                                	"value": "Restart <img src='my_restart_icon.png'/>",
                                	"actions": {"type": "gcode", "gcode": "M999"}
                                • Dario02undefined
                                  Dario02 @gtj0
                                  @gtj0 what about custom icons? For example I made some images that I would like to use for buttons, any example? If you tell me that you will make a tutorial for everything on wiki I can wait that you finish
                                  • gtj0undefined
                                    gtj0 @Dario02
                                    Just put them in the same directory as the top level html file and you can use the button example above. "value": "<img src='/my_icon.png'/>"
                                    Now the button will display the icon instead of text.
                                    • Dario02undefined
                                      Dario02 @gtj0
                                      @gtj0 ok thank you, another question is how can I manage containers? For example to create a barmenu etc. I suggest you to write all this stuff in the wiki 😉
                                      • Dario02undefined
                                        Dario02 @gtj0
                                        @gtj0 Just put them in the same directory as the top level html file and you can use the button example above. "value": "<img src='/my_icon.png'/>" doesn't work, maybe I didn't understand correctly, an example for '/my_icon.png' please
                                        • Dario02undefined
                                          Dario02
                                          ok i had to resize the image... is there a way like on css to self crop the image specifying the size in pixel or in percentage?
                                          Another problem is that by setting an image as value this is not centered and remains some colored margin....
                                          • gtj0undefined
                                            gtj0 @Dario02
                                            @Dario02 You have complete control over the styling with the "style" attribute. Almost anything you can do in CSS you can do with "style". See the example in https://github.com/gtjoseph/DueUI/wiki/Element
