Duet 3 Mainboard 6HC et Raspberry PI4 :DCS is unavilable.
ok this is the phots of PT100 wiring on the daughterboard .@Danal
@Azul said in Duet 3 Mainboard 6HC et Raspberry PI4 :DCS is unavilable.:
daughterboard
could be dust or light, but looks like there is something on the edge of U2 - do either of those get warm?
@bearer the Duet 3 temperature is around 41 the Pi too get warm
@bearer is there a procedure to connect Duet 3 to an Ethernet Network.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
@bearer this version is for duet 2, not 3?.i want to connect my duet3 to an Ethernet Network
it does say duet 3 so I'm inclined to think it is duet 3 - it also says that its pretty much the same as running RRF3 on a duet 2 so I guess it doesn't matter all that much as long as you get the pin names correct in the config.
HI i have a Duet 3 v1 and a Raspbeery pi4. i hace successed to connect my Duet 3 (Mainboard 6HC) with Raspberry Pi4 to control a motor and acquire data from endstop but the problem is when i have connected a daughterboard with a PT100 to My duet 3 the connexion is off and this error message appears ''DCS is Unavailable", wich leads to noc access DWC.@dc42
Please confirm that you are plugging the daughter board into the Duet 3 the right way round so that the holes for the standoff peg in the main board and daughter board line up. Assuming that they do, I think the daughter board is probably faulty and you should ask for it to be replaced.
@dc42 thanks, the problem is solved. i have just reinstalled the firmarware.
