    my second raspberry has just passed away
    Duet Web Control
    9
    102
    5.8k
    • spllgundefined
      spllg @Danal
      @Danal sorry, i should have written
      i am powering the duet 5v from the rpi via usb (internal 5v open, 5v->sbc and sbc->5v are open)
      instead of
      i am powering the duet 5v from the rpi via usb (internal 5v enable, 5v->sbc and sbc->5v are open)
      if it is not possible to 5v-power the duet using the usb port, how can i 5v-power the duet except from the 24v psu by means of internal 5v enable?
      • spllgundefined
        spllg @gtj0
        @gtj0
        Do you have both the 5V->SBC and the SBC->5V pins jumpered? They both need to be connected to power the Duet from the SBC.
        both? this is contradicting
        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
        which states:
        'If you want the SBC to provide 5V to the Duet then remove the jumper from 5V->SBC and from Internal 5v En. Place a jumper on SBC-5V*' (which does not work)
        now i'm even more confused.
          A Former User
          The default 5V power configuration is Internal 5V enable - jumpered, 5V->SBC jumpered (the Duet is powering the SBC) , SBC->5V* not jumpered. If you want the SBC to provide 5V to the Duet then remove the jumper from 5V->SBC and from Internal 5v En. Place a jumper on SBC-5V*. NOTE this bypasses the 5V protection and a fault on the SBC may damage the Duet.
          Does indeed seem to be a typo. SBC->5V(JP5) only connects the 5V_EXT and 5V_INT; you still need the 5V->SBC(JP4) jumper to get the powe from the Pi header and to 5V_EXT. Open JP1; close JP4 and JP5 or use the VBUS/5V_EXT_INPUT input to retain the diode protection?
          spllgundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • spllgundefined
            spllg @A Former User
            @bearer
            @dc42 can you confirm that it's a typo - i do not intend to kill another rpi.
            additional question: (how) is it possible to access the duet via the usb interface when it's powered by the rpi?
              A Former User @spllg
              @spllg said in my second raspberry has just passed away:
              using a serial terminal on the Pi? minicom, screen, echo, cat, socat lots of options but less user friendly on the console. (there are probaly more user friendly graphical alternatives, that could also be used with VcXsrv or even VNC etc)
              spllgundefined 1 Reply Last reply Reply Quote 0
                A Former User @Danal
                This post is deleted!
                • spllgundefined
                  @bearer
                  pronterface, octoprint, ..
                  my question should have read: how to electrically interface usb interface?
                    Why on earth would you be running the Duet 3 with a raspberry pi + DSF and use ether of those?
                    for pronterface ditch the Pi. for octoprint ditch DSF and run octoprint on the Pi.
                    but if you must you can use socat and virtual serial ports.
                    • spllgundefined
                      @bearer
                      would probably be best to open JP1 in either case though.
                      is JP1 the same as 'Internal 5V enable'?
                        yes.
                        there are diodes to prevent feeding VBUS into the 5v regulator, but given the feedback is outside of those diodes you could risk the internal regulator outputting a voltage higher than 5v if VBUS drops below 5v? which would not self regulate if the JP4 / 5V->SBC jumper is not fitted.
                        • spllgundefined
                          @bearer
                          because i do not feel comfortable with dsf
                          if i connect the duet to the raspberry by using a standard usb cable 5v and ground will be connected between the two devices - a configuration (as mentioned by you) might have the potential to kill a raspberry.
                          You guys discussed this a little above, and then moved on. This absolutely will not work (as Dave pointed out). The fact that it does work for @spllg would seem to be the key to whatever is killing these.
                            this is already connected through the ribbon cable (if that is installed?)
                            and there is no reason supplying power from the usb cable should have any other risk than through the ribbon cable; but both scenarios would probably be better off disabling the internal 5v regulator on the duet.
                            • spllgundefined
                              @bearer yes - but what if i want to access the duet using the usb interface? there would be a double connection.
                              how to disable 'internal 5v regulator'? by removing the 'Internal 5V enable' jumper?
                              this already has been removed as stated in
                              spllg 20 Apr 2020, 10:36
                              (the comma ',' in the paranthes should read 'and')
                                A possible problem I can see with powering the Duet from the Pi via USB is that the Pi may decide to shut off the USB power to the Duet, if that happens, then the Pi will be powered but the Duet won't be. This will cause current to flow from the SPI pins of the Pi to the Duet. There are current-limiting resistors in that interface, but they are only 100 ohms in order to allow a high SPI speed. It could be that the Pi is trying to feed too much current into those lines.
                                Better to power the Pi from the Duet directly or vice versa using the jumpers provided.
                                spllgundefined A Former User? 2 Replies Last reply Reply Quote 0
                                  @bearer said in my second raspberry has just passed away:
                                  I confirm that to power the Duet 5V from the Pi, you need to have both SBC->5V and 5V->SBC jumpers in place.
                                  EDIT: I have updated the documentation.
                                  • spllgundefined
                                    spllg @dc42
                                    @dc42 ok - so the jumpers '5v -> sbc' and 'sbc -> 5v' must be set and i should not try to access the duet using it's usb port - right?
                                    A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                                      disconnect the ribbon cable if you feel the need to try usb, to alleviate dc42s concern about the spi signals.
                                        A Former User @dc42
                                        @dc42 said in my second raspberry has just passed away:
                                        not sure if it applies to all versions of the Pi, but some do seem to turn off USB power when powering off and rebooting.
                                          dc42 administrators @spllg
                                          Accessing the Duet using its USB port will be safe provided that you have the jumpers in place so that the Duet is not dependent on USB power. But you shouldn't normally need to use the USB connection, because everything except for flashing firmware using Bossa can be done over the SPI connection.
                                          Make sure that all PSUs powering the Duet, Pi or anything connected to the Pi that have mains ground connections are plugged into the same mains distribution block.
                                          Whilst I have come up with a possible explanation for why the Pi might get damaged when powering the Duet form USB, it may not be the correct explanation for the failure of your 2 boards. Are you using the official Pi PSU?
                                          spllgundefined 1 Reply Last reply Reply Quote 1
                                          • spllgundefined
                                            spllg @dc42
                                            @dc42 yes, i'm using the official pi psu.
                                            btw: using the duet3 in standalone mode seems to have network issues.
                                            • i could not upload a gcode file (23m) - the upload was interrupted an the text 'network problems' (or something like this) was displayed in the lower left corner. when i repeated the upload it worked fine.
                                            • the connection was lost when the machine was printing and i had no chance to reconnect. waited for the print to finish and had to reboot the duet. this happened twice.
