    my second raspberry has just passed away
    Duet Web Control
    9
    102
    5.9k
    • arhiundefined
      arhi @spllg
      @spllg I'd love to get my hands on that pi to figure out why they died, I guess I'm not the only one :). Are those RPI 3B or ?
      spllgundefined 1 Reply Last reply Reply Quote 0
      • arhiundefined
        arhi
        ah rpi4, have you tried powering it trough the 5V on the header and not trough the usb ? (stand alone, not connected to duet)
        • spllgundefined
          spllg @arhi
          @arhi i have powered the pi from the duet using the header but did not succeed powering the duet from the rpi using the header.
          • spllgundefined
            spllg @arhi
            @arhi
            i'd love to get my hands on that pi to figure out why they died, I guess I'm not the only one :). Are those RPI 3B or ?
            would you like to buy it?
            btw: duet 3 running in stand alone mode seems to over extrude quite a bit - at least my extrude settings ceased to work - had to lower it to 80%.
            • arhiundefined
              arhi @spllg
              @spllg said in my second raspberry has just passed away:
              Yes, would be an interesting project to figure out why it died, but it is impossible to get anything in .rs now due to quarantine and police hour. Let's discuss this after this #%$^^&_#@ is over, I'm def. interested.
              • gtj0undefined
                gtj0 @spllg
                Do you have both the 5V->SBC and the SBC->5V pins jumpered? They both need to be connected to power the Duet from the SBC.
                • Danalundefined
                  Danal @spllg
                  i am powering the duet 5v from the rpi via usb (internal 5v enable, 5v->sbc and sbc->5v are open) - a configuration which has been working fro ~2 months.
                  You guys discussed this a little above, and then moved on. This absolutely will not work (as Dave pointed out). The fact that it does work for @spllg would seem to be the key to whatever is killing these.
                  As a "cold read" bystander of this thread, I believe you guys should go back and dive into this quite a bit more.
                  spllgundefined A Former User? 2 Replies Last reply Reply Quote 2
                  • spllgundefined
                    spllg @Danal
                    @Danal sorry, i should have written
                    i am powering the duet 5v from the rpi via usb (internal 5v open, 5v->sbc and sbc->5v are open)
                    instead of
                    if it is not possible to 5v-power the duet using the usb port, how can i 5v-power the duet except from the 24v psu by means of internal 5v enable?
                    • spllgundefined
                      spllg @gtj0
                      @gtj0
                      both? this is contradicting
                      https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
                      which states:
                      'If you want the SBC to provide 5V to the Duet then remove the jumper from 5V->SBC and from Internal 5v En. Place a jumper on SBC-5V*' (which does not work)
                      now i'm even more confused.
                        A Former User
                        The default 5V power configuration is Internal 5V enable - jumpered, 5V->SBC jumpered (the Duet is powering the SBC) , SBC->5V* not jumpered. If you want the SBC to provide 5V to the Duet then remove the jumper from 5V->SBC and from Internal 5v En. Place a jumper on SBC-5V*. NOTE this bypasses the 5V protection and a fault on the SBC may damage the Duet.
                        Does indeed seem to be a typo. SBC->5V(JP5) only connects the 5V_EXT and 5V_INT; you still need the 5V->SBC(JP4) jumper to get the powe from the Pi header and to 5V_EXT. Open JP1; close JP4 and JP5 or use the VBUS/5V_EXT_INPUT input to retain the diode protection?
                        spllgundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        • spllgundefined
                          spllg @A Former User
                          @bearer
                          @dc42 can you confirm that it's a typo - i do not intend to kill another rpi.
                          additional question: (how) is it possible to access the duet via the usb interface when it's powered by the rpi?
                            A Former User @spllg
                            using a serial terminal on the Pi? minicom, screen, echo, cat, socat lots of options but less user friendly on the console. (there are probaly more user friendly graphical alternatives, that could also be used with VcXsrv or even VNC etc)
                              A Former User @Danal
                              This post is deleted!
                              • spllgundefined
                                @bearer
                                pronterface, octoprint, ..
                                my question should have read: how to electrically interface usb interface?
                                  Why on earth would you be running the Duet 3 with a raspberry pi + DSF and use ether of those?
                                  for pronterface ditch the Pi. for octoprint ditch DSF and run octoprint on the Pi.
                                  but if you must you can use socat and virtual serial ports.
                                  • spllgundefined
                                    @bearer
                                    would probably be best to open JP1 in either case though.
                                    is JP1 the same as 'Internal 5V enable'?
                                      yes.
                                      there are diodes to prevent feeding VBUS into the 5v regulator, but given the feedback is outside of those diodes you could risk the internal regulator outputting a voltage higher than 5v if VBUS drops below 5v? which would not self regulate if the JP4 / 5V->SBC jumper is not fitted.
                                      • spllgundefined
                                        @bearer
                                        because i do not feel comfortable with dsf
                                        if i connect the duet to the raspberry by using a standard usb cable 5v and ground will be connected between the two devices - a configuration (as mentioned by you) might have the potential to kill a raspberry.
                                          this is already connected through the ribbon cable (if that is installed?)
                                          and there is no reason supplying power from the usb cable should have any other risk than through the ribbon cable; but both scenarios would probably be better off disabling the internal 5v regulator on the duet.
                                          • spllgundefined
                                            @bearer yes - but what if i want to access the duet using the usb interface? there would be a double connection.
                                            how to disable 'internal 5v regulator'? by removing the 'Internal 5V enable' jumper?
                                            this already has been removed as stated in
                                            spllg 20 Apr 2020, 10:36
                                            (the comma ',' in the paranthes should read 'and')
