    How do I configure my default fan?
    979
    • maroondsundefined
      maroonds @droftarts
      @droftarts Fan control shows up but only for my part cooling fan. The fan turns on when I connect it to the always on pin but I'd like it to only turn on when the temperature is above 45c since it's kind of loud.
        droftarts administrators @maroonds
        @maroonds Can you post how your fans are set up at the moment? You can also check by sending M106 P[fan number], though this doesn't tell you what pins it's using.
        maroondsundefined 1 Reply Last reply Reply Quote 0
        • maroondsundefined
          maroonds @droftarts
          @droftarts said in How do I configure my default fan?:
          M106 P[fan number]
          here is my fan setup
          droftartsundefined 2 Replies Last reply Reply Quote 0
            @maroonds I meant in your config.g. Copy the text from config.g and paste it into your reply.
            • maroondsundefined
              maroonds @droftarts
              @droftarts Oh my bad..
              ; Configuration file for Duet Maestro (firmware version 2.03)
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 22 2020 01:05:56 GMT+0200 (Mitteleuropäische Sommerzeit)
              M550 P"My Printer" ; set printer name
              M552 P192.168.1.69 S1 ; enable network and set IP address
              M553 P255.255.255.0 ; set netmask
              M554 P192.168.1.254 ; set gateway
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S0 ; disable Telnet
              M552 S1 P192.168.8.101
              M569 P0 S1 V0 ; physical drive 0 goes backwards X
              M569 P1 S1 V0 ; physical drive 1 goes backwards Y
              M569 P2 S0 ; physical drive 2 goes forwards Z
              M569 P4 S1 ; physical drive 3 goes forwards E
              M92 X80.00 Y80.00 Z400.00 E393.00 ; set steps per mm
              M566 X420.00 Y420.00 Z12.00 E180.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X24000.00 Y24000.00 Z720.00 E7200.00 ; set maximum speeds (mm/min)
              M201 X2000.00 Y2000.00 Z500.00 E5000.00 ; set accelerations (mm/s^2)
              M906 X850 Y850 Z600 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M204 P1000 T2000 ; Set printing and travel accelerations
              M208 X-5 Y-5 Z-5 S1 ; set axis minima
              M208 X235 Y230 Z260 S0 ; set axis maxima
              M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X-33 Y1 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X10:210 Y10:210 S20 ; define mesh grid
              M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4725 C7.060000e-8 R2200 ; set thermistor + ADC parameters for heater 1
              M106 P0 A22 H-1 S1
              M106 P3 A2 H-1 S1
              M911 S23 R23.7 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                @maroonds From your config.g:
                M106 P0 A22 H-1 S1
                M106 P3 A2 H-1 S1
                You haven't disabled Heater 1, as @dc42 suggested, with:
                M307 H2 A-1 C-1 D-1 ; disable heater 2
                Also, your tool is using F0, which is the part cooling fan.
                For the hot end fan, you don't need to specify it in the tool, as it's going to be set to thermostatically watch Heater 1 anyway. As you don't have any other fans, you may as well call this 'Fan1' or P1. So, change your config.g to:
                M106 P0 A22 H-1 S0
                M106 P1 A2 H1 T45
                M563 P0 D0 H1 ; define tool 0
                Fans that are linked to tools won't show up in DWC until the tool is active. Fans that are thermostatic won't show up at all. Fan visibility can be turned on and off in the 'Current Job > Status' page; click on 'change visibility' in Fans section.
                Is there any reason you're not using the other PWM fan pins?
                • maroondsundefined
                  maroonds
                  I had to change my pwm ports because I shorted the ones I was previously using.
                  Btw. I tried it with your adjustments but my hotend fan is still not turning on when my heater reaches 50 degrees.
                    @maroonds You made the changes to config.g, saved it, then reset the Duet? Run M98 P"config.g" and see if it generates any errors.
                    What happens if you send:
                    M307 H2 A-1 C-1 D-1
                    M106 P1 A2 H-1 S1
                    • maroondsundefined
                      maroonds @droftarts
                      @droftarts It doesn't create any errors and after I pasted the other commands nothing happens and the fan still doesn't turn on at 50 C
                        @maroonds Can you post a picture of your board showing wiring? How are you connecting the fan to E1 HEATER, on the pins or screw terminals? Have you checked polarity?
                        The command from my previous post, M106 P1 A2 H-1 S1, should turn it on full speed straight away, to test. To be thermostatic controlled, needs to be M106 P1 A2 H1 T50. But it needs to be working with the first M106 command, before setting it to thermostatic control. See gcode dictionary to understand the settings: https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
                        maroondsundefined 2 Replies Last reply Reply Quote 0
                        • maroondsundefined
                          maroonds @droftarts
                          M106 P1 A2 H-1 S1
                          Screw terminals. I checked the voltages with a multimeter and it has around 0.5V with this command sent: M106 P1 A2 H-1 S1
                          And yes the polarity is right
                          • maroondsundefined
                            maroonds @droftarts
                            @droftarts This was my setup on RRF3 (now I'm on 2.05.1):
                            M950 F3 C"e1heat"
                            M106 P3 H1 T35 S1
                            M950 F2 C"nil"
                            M950 F0 C"fan2" Q500
                            M106 P0 I0 C"5015" S0 H-1
                              @maroonds try S255 . Any reason you rolled back from RRF3? Where the fans not working? Setting the part cooling fan with P0 and not thermostatic or bound to a tool should put it under slicer or manual control.
                              As this is a Maestro, I’m not sure if pin A2 is correct for Heater 1. It should be. @dc42 ?
                              maroondsundefined 1 Reply Last reply Reply Quote 1
                              • maroondsundefined
                                maroonds @droftarts
                                @droftarts I don't know what I did wrong yesterday, but now it's working.
                                At least this command: M106 P2 A2 H-1 s255
                                But how can I make it thermostatic controllable?
                                This is my current setup:
                                M106 P0 A22 H-1 S1 ; Part cooling fan
                                M106 P3 A2 H1 T45 ; Hotend fan
                                M307 H2 A-1 C-1 D-1 ; Disables H2
                                  dc42 administrators @maroonds
                                  @maroonds said in How do I configure my default fan?:
                                  The M307 command must come before the M106 P3 A2 command.
                                  • maroondsundefined
                                    maroonds @dc42
                                    Now everything is working! Thanks @droftarts @dc42
