Duet3D not connecting to the computer (Please read carefully)
Are any of those for a phone or a tablet that requires data transfer to a PC?
Yes, the longest is a data for shure as well as the short one
And you've tested them with a data device and that USB port and it works?
Most of them i used for pictures and video transfer from my phone to the computer and work with other boards that i have
Have you tried connecting it to your network with a config file set copied to the SD card?
So you connect the Duet 3 to the PC with the cable.
Do you hear the USB device detected sound?
Does anything show up in device manager when it is connected?
What LEDs light up on the board?
Have you pressed the erase button?
Is the jumper fitted to the erase pins?How far do you get in this list of steps?
Can you point me to the files? I would like to download a fresh updated copy and try again, I'm doing it via usb because i don have a raspberry pi
@Reaperrhs said in Duet3D not connecting to the computer (Please read carefully):
This is why I don't think you've actually read this link.
Is first time, i follow a different link thatvwas given to me on the old post, but i follow all the steps you mentioned, no sound
Nothing on yhe device manager, the pin was fit, and the lights are the same on the picture -
Do you have Bossa installed on your PC?
Yes. Yat as well
And nothing shows up in Bossa with these steps?
To update via USB (using a Windows host):
You will need to install Bossa 1.9.1 from https://github.com/shumatech/BOSSA/relea... on your PC.
Place a jumper across the ERASE pins on the Duet 3 and power it up to erase the firmware. The Bossa port should appear on your PC (if it doesn't, try pressing the Reset button).
The erase jumper is located in the center of the board near the large CPU chip.
Remove the ERASE jumper, load Bossa and select the correct COM port. It should identify the device as ATSAM70x20.
Check the Erase All, Boot to Flash and Lock boxes
Download the latest RRF V3 from here: https://github.com/dc42/RepRapFirmware/r...
Browse to the firmware binary, and select Write.
When that completes, select Verify.
When that completes successfully, press the Reset button on the Duet 3 to restart the Duet in normal mode.@Reaperrhs said in Duet3D not connecting to the computer (Please read carefully):
Which picture?
I try that several times, doesn't work
@Reaperrhs, have you installed the Windows driver for Duet? You can find it in file DuetDriverFiles.zip which is available at https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC9 and in some earlier releases. You need to unzip the package into a temporary folder, then double-click on the .inf file.
I am in communication with Filastruder about your board.
@Phaedrux said in Duet3D not connecting to the computer (Please read carefully):
it doesn't sound like thats worth while pursuing after
i place the jumper and erased and still not working,
i format my memory card by mistake and lost all files
@dc42 the only thing left to is to connect the board to the network using an ethernet cable but unfortunately, I cant files to do that
The common denominator in this problem is what?
I will tell you, and I'm sorry if brutal honesty is not what you want to hear.
The problem is not the board's it's you.
@CaLviNx all this happen after i try to connect the board to the ethernet port, I swap the memory card by accident, don't forget it comes with the problem out the box, is impossible to make a mistake just by connecting the board via USB to the computer, DELETE A FILE? IT HAPPEN TO ANYONE AFTER BEING TRYING FOR A WEEK
I'd like to ask those not directly helping solve this issue to please avoid commenting. The goal here is to help a user get their printer working again, anything not in service of that goal should be withheld.
